Old 08-24-2015, 10:26 AM   #1
Wepeel
Drives: '13 BRZ Ltd
Stuck in Open Loop?
Noticed something strange this weekend. I'm running OFT+OFH with the OTS Stage 2 UEL map. On the highway, cruising ~70mph, I glanced at my torque app and noticed meaured AFR's in the low 12's, rock steady LTFT, STFT of 0.0, and a commanded AFR of 14.7. This remained for quite a while, I changed loads and throttle and rpm (even brought the car to a stop and idled the engine), and still saw that it was stuck in Open Loop (STFT of 0.0 and AFR give it away). I could tell that data wasn't hung up (MAF, AFR, other monitors were updating).
Once I restarted the car it was back in closed loop when it was supposed to be. Anyone else seen this happen? Any ideas if there's some condition out there that would trigger constant open loop?
Full mod list - OFH, OFT, catted front pipe, stock OP, stock catback, stock intake, stock filter.
Wepeel is offline   Reply With Quote
Old 08-24-2015, 03:13 PM   #2
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
I honestly don't know all that much about tuning but could it be a few of the prongs weren't fully connected into OBD port? did you mess with the connection when you restarted car? otherwise, I have no clue...
cdq85 is offline   Reply With Quote
Old 08-24-2015, 03:15 PM   #3
JB86'd
JB86'd's Avatar
Drives: JAWS
Have you upgraded your OFT lately with the newest template from the Openflash website?
JB86'd is offline   Reply With Quote
Old 08-24-2015, 04:54 PM   #4
Wepeel
Drives: '13 BRZ Ltd
I did try to unplug and plug back in the OBD adapter and reconnect Torque while cruising in open loop (before I restarted the car), and it still showed the car was in open loop.
No, I haven't upgraded the OFT template in a while. Was there an update to the tune at all?
Old 08-24-2015, 09:46 PM   #5
cdq85
cdq85's Avatar
there was an update but I don't think that would cause the problem you are having. if it was a one time thing, i'd probably chalk it up to just that. if it happens again or frequently, i'm sure shiv or someone would be happy to help.
Old 08-24-2015, 10:42 PM   #6
JB86'd
JB86'd's Avatar
Drives: JAWS
When you log with the OFT, does it show the same thing?
Old 08-24-2015, 11:01 PM   #7
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Looking at trims doesn't prove anything, it's an indication only. You need to log fuel sys status to see OL/CL.
The Following User Says Thank You to Wayno For This Useful Post:
jawn (12-17-2015)
Old 12-17-2015, 03:00 PM   #8
Wepeel
Drives: '13 BRZ Ltd
Okay, so this is definitely happening. What I see, and this happens during highway cruise, is AFR begins dropping. When I look at targeted AFR, it usually starts around 14.2ish. Over the course of an hour or so at 70-75mph cruise, the targeted (and measured) AFR works it's way down to mid 13's. Once it hits a certain point, the car goes open loop, short term trims go to zero, targeted AFR just defaults to a straight 14.7 and measured AFR is around the high 12's.
Any ideas what could possibly causing targeted AFR to drop through cruise and eventually force everything to open loop? Are there any knock parameters or temperature feedbacks that could be driving this?
Old 12-17-2015, 05:20 PM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
Tried setting A/F #3 corrections to 0? I assume IAM is 1? I can't understand why the target AFR would drop.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-17-2015, 07:31 PM   #10
Wayno
Wayno's Avatar
Don't use torque ffs, if you have an oft there's no reason for you to ever plug in a shitty bluetooth dongle.
Old 12-19-2015, 12:31 AM   #11
Wepeel
Drives: '13 BRZ Ltd
I was using OFT.
Old 12-19-2015, 12:40 AM   #12
Wepeel
Drives: '13 BRZ Ltd
Here's just a snapshot of a log I took while this was happening... I didn't get a log when it hit low 13's/high 12's and went to open loop, but when this trip started AFR and targeted AFR were in the mid 14's. In the log it is now at around 13.7, this was about 1.5 hours into highway cruise.
http://www.datazap.me/u/wepeel/cruise?log=0&data=1
Old 05-22-2016, 12:31 AM   #13
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
I know this is reviving an old thread but mine does the same. OFT+OFH
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Old 05-22-2016, 12:40 AM   #14
steve99
Drives: FT86
If you want to eliminate the tune then get a stock rom and use romraider to set the P0420 cel code (cat efficiency) to disabled.
then run the modded stock tune and see if you get same problem.
MAF Scaling - Open/Closed Loop Fueling info steve99 Software Tuning 653 07-10-2024 05:25 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 04:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 06:49 PM
i've been out of the loop! VenomRush Off-Topic Lounge [WARNING: NO POLITICS] 0 02-16-2013 12:25 AM
Who was on the 202 loop SMOKETREES Southwest 5 09-15-2012 12:31 AM
