Old 08-23-2015, 12:03 AM   #1
wizzo
Drives: 2014 Toyota 86
Issues with camber after new coilovers
Hey everyone,
Installed my ground control coilovers, they are the koni shocks with the double adjustable race inserts in front and the single adjustable race insert in the rear along with the ground control front camber plates.
After installing went down to an allignment shop and was surprised to see 2.7 degrees of negative camber on the passenger side and 1.4 degrees of negative camber on the drivers side. During install everything went smooth, the bolts on the spindle seemed quite tight and there was no chance of play or much movement. Before i go ahead and install camber bolts so i can dial in the 3 degrees of camber i want. What do you think could be wrong, im going to go ahead and remove the driver side shock and inspect it, because on the GC camber plates i would expect nothing less than the 2.7 degrees of camber i have on the passenger side.
Any advice or opinion?
Edit: the car has never been involved in an accident
wizzo is offline   Reply With Quote
Old 08-24-2015, 07:30 PM   #2
Bergen23
Drives: '15 Halo FR-S
Well how much camber do the ground control top hats give? Are they actually adjusted equally?
Bergen23 is offline   Reply With Quote
Old 08-24-2015, 11:36 PM   #3
Turdinator
Señor Member
Turdinator's Avatar
Do the ground control coilovers have a sloted top hole where they bolt to the knuckle?
1974 TA22 Celica
2013 86 GT
Issues with getting camber to -3 in front? Churg Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 03-22-2015 01:01 PM
Camber and toe after coilovers installed ChrisD Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 02-22-2015 12:58 PM
Rear camber assymmetry and alignment issues ofuts Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 02-02-2015 12:46 PM
FS: Coilovers W/ Camber Plates $575 Amir Ghadiri Brakes, Suspension, Chassis 8 03-11-2014 02:22 AM
ST Coilovers; camber. cortrain Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 03-09-2014 06:35 PM
