Old 08-21-2015, 08:43 PM   #435
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by why? View Post
Yea, show the UEL car that is not only illegal to drive in nearly every state, but on most racetracks too. If he can get pulled over for noise down south, everyone in carb country is pretty much screwed, and since most racetracks have noise restrictions, no chance of using his setup on racetracks.
Did you even bother reading the previously quoted posts?
Even though it's totally irrelevant to the original question... The long tube EL is considered illegal as well.
Old 08-21-2015, 08:51 PM   #436
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
Originally Posted by ATL BRZ View Post
Long tube EL sounds like doodoo in my opinion
UEL sounds amazing though, as you know
@Anthony
Sent from my SAMSUNG-SM-N910A using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
The Following User Says Thank You to FLIPs_FR-S For This Useful Post:
Anthony (08-22-2015)
Old 08-21-2015, 09:04 PM   #437
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Yes, I read the entire thread. You missed my point. I don't mean "considered illegal," I meant that Anthony was pulled over for noise violations in Mississippi. They don't have laws for that down there. That is how loud his car is. That means that his setup is probably illegal on every single racetrack in the USA, since they all have noise restrictions now. It also means his setup is probably is illegal in most states. Not "technically" illegal, but impossible to actually drive on the streets because it attracts the attention of everyone in 5 square miles.
It doesn't matter how "nice" or "great" the car sounds if you literally can't take it anywhere.
And yes, you did take the entire thread off topic. But that is kind of what we do here. It is part of the enjoyment of talking about the 86 platform.
I am sure there are actually people using UEL headers in carb states and getting away with it because they don't set off every car alarm on the street when they rev the engine.
why? is offline   Reply With Quote
Old 08-21-2015, 09:07 PM   #438
Andrew025
Andrew025's Avatar
His car has no muffler or cats.
The UEL doesn't make a difference. It's going to be loud as shit regardless because he is straight piped, not because he has an UEL header.
Old 08-21-2015, 09:37 PM   #439
CSG Mike
CSG Mike's Avatar
Have you ever set foot on a racetrack before?
A general noise complaint is indeed different from a specific "car too loud" violation.
CSG Mike is online now   Reply With Quote
Old 08-21-2015, 09:54 PM   #440
SPCorBUST
SPCorBUST's Avatar
@CSG Mike
I didn't want to pollute the owner's thread with these questions. But just for informational purposes, does CSG have pricing on the available pulley upgrades?
And hypothetically speaking, how would a motor be built/set up to maximize the smallest available pulley? e.g. valves, pistons, those sort of items, not bolt ons, like Flex Fuel, full exhaust, etc. Any differently than a turbo built block?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 08-21-2015, 10:44 PM   #441
FuzzyFunk
Drives: FRS Monogram
Took some close up pics when I got home.
Look at all that free space! LOL
FuzzyFunk is offline   Reply With Quote
The Following 15 Users Say Thank You to FuzzyFunk For This Useful Post:
BatStig (08-22-2015), BigFatFlip (08-21-2015), Breeeep (08-23-2015), Budo (08-22-2015), Calum (08-22-2015), civicdrivr (08-22-2015), CSG Mike (08-21-2015), G-awesome (08-22-2015), mou (08-22-2015), Phantobe (08-21-2015), Porcupint (08-22-2015), raven1231 (08-22-2015), shiumai (08-23-2015), SuperDave (08-25-2015), Toyota86.ir (02-11-2016)
Old 08-21-2015, 10:48 PM   #442
CSG Mike
CSG Mike's Avatar
Originally Posted by SPCorBUST View Post
@CSG Mike
I have no idea what the pulleys cost, but I would expect them to be fairly inexpensive.
*Just* the smallest available pulley? You'd be able to get away with just rods, I'd think. You'd be going from ~60% of the SC's capacity to ~80%. You'd need to get a larger crank pulley to get more out of the SC, and the overhead is there. Now how the accessories will handle that... well it's similar to revving the engine higher.
Maximizing? Well, rods, bearings, pistons, head work, valves, seats, guides, retainers, valve springs, etc. etc. etc. I could come up with a ridiculous 80k engine that would "maximize" if we want to go way off the deep end of diminishing returns.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Budo (08-22-2015), CxG (01-20-2016), SPCorBUST (08-21-2015)
Old 08-21-2015, 11:06 PM   #443
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Pics of the heat exchanger/radiator area please!
Old 08-21-2015, 11:30 PM   #444
FuzzyFunk
Will do tomorrow! the heat exchanger is almost as big as the radiator!
The Following 2 Users Say Thank You to FuzzyFunk For This Useful Post:
BigFatFlip (08-21-2015), Decay107 (08-21-2015)
Old 08-21-2015, 11:43 PM   #445
BigFatFlip
BigFatFlip's Avatar
Mostly curious on how it mounts to see if certain top mounted oil coolers would work.
Old 08-21-2015, 11:56 PM   #446
FuzzyFunk
The heat exchanger sits right in front of the radiator. So if you want mount it in front of the crash beam, that should work like mishimoto's. The perrin looks like it sits right under the beam based on the pics I see online.
Any particular reason you want a top mounted oil cooler? is one location better than the other? (learning here)
Old 08-22-2015, 12:00 AM   #447
CSG Mike
CSG Mike's Avatar
Which oil cooler are you referring to?
Old 08-22-2015, 12:56 AM   #448
BigFatFlip
BigFatFlip's Avatar
Good to know. I'm a little more comfortable with an oil cooler rigidly mounted on/below the crash beam vs the plastic under tray like the perrin. I can picture a scenario where hitting something and ripping off your undertray can make for a very bad day.
I guess "top mounted" is not quite the way to describe it. I was talking bout JR NA oil cooler, which mounts on a solid bracket.
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
