Old 08-17-2015, 11:53 PM   #43
steve99
Drives: FT86
Originally Posted by SDP View Post
It is the original as far as I know. It says flash complete and 1 dtc read, I clear it and after that it shows 5 dtc' cleared and shows as follows:
UO122
UO131
UO100
UO122
UO131
And says they cleared. But if I run a dtc check only UO100 cleared. As far as not coming out of programming mode...from what I've read that when you flash the ECU, it turns off all other ECM's and such, which it has done, problem is it doesn't turn them back on after I'm done! May just need to be something Perrin and I work with Ecutek to figure out.
Check battery volts
check fuses
check any plugs socket wiring you touched or moved
remove battery cable then press brake pedal leave for five minutes then reconnect, check both battery terminals and earth connections.
sounds like somthing on CAN bus is not happy it might be just one module effecting communication on the buss
if you have techstream run can buss diagnostics
pretty sure techsstream will work with ecutek cables
Old 08-18-2015, 11:07 PM   #44
SDP
Drives: 2015 BRZ Limited
Checked all that good stuff and no progress. I've got Ecutek connecting remotely in the morning, I'll up date everyone on what was found.
SDP is offline   Reply With Quote
Old 08-18-2015, 11:55 PM   #45
steve99
Drives: FT86
Be interested to see what they find , it does look like a corrupt or incomparable rom has been flashed somehow.
Old 08-19-2015, 06:58 PM   #46
SDP
Looks like I missed a fuse! The 140a fusible like was blown on the battery terminal. Pulled a noob move and didn't disconnect the negative before FI install and when it disconnected the alternator I shorted the circuit! *head hung low in shame* $13.50 and two days and I'll be up and running!
Thank you for the advice everyone!
Old 08-19-2015, 07:13 PM   #47
SDP
I want to thank Chris Cone at Perrin Performance and Mervyn at Ecutek for all the effort they put in to helping me!
iPod Keeps resetting, hanging; etc... Anyone else seeing this Max1957 Electronics | Audio | NAV | Infotainment 5 03-17-2014 08:41 PM
Learning to track in the rain buzznasa Northern California 14 02-10-2014 04:21 PM
Advance Mutiplier resetting on restart? feldy Software Tuning 122 11-05-2013 10:08 AM
Learning to drift FRS-Jonathan Tracking / Autocross / HPDE / Drifting 4 05-16-2013 04:50 PM
