| Software Tuning Discuss all software tuning topics. |
***** Lurker
Drives: 2015 GT86 1990 AE92
Hi,
I have a 2015 build 86 and today i married the OFT with the car and it shows up CAL ID A02J. When looking through the Off-the-shelf maps, i only found they have A00J and A01J files. Is there a solution to this? Also at the meantime i tried to log my stock tune, everything seems in order except for IAM values. They are constantly 0 in all 3 logs, from home to the office, office to the gym and gym to home. Could it be the fuel here is so bad that IAM dropped down to 0 throughout the 12k kms i have put it through? Much appreciated. Thanks |
#2 |
***** Lurker
http://www.datazap.me/u/lemonzz/log-...=0&data=1-5-12
http://www.datazap.me/u/lemonzz/log-...4?log=1&data=1 http://www.datazap.me/u/lemonzz/log-...4?log=2&data=1 These are the log files from the A02J tune file. |
#3 |
***** Lurker
It ok guys. I found the tune file i needed. However the IAM at 0 is still a question though..
#4 | |
Drives: FT86
if KC Learned logs ok you can derive IAM from that. look at your log here http://www.datazap.me/u/lemonzz/log-...zoom=1274-1474 look at the log at rpm =6800, load = 1.1, KC Learned = 2.34 or around that area. then look at the Knock Correction Advance Max A table in your tune as below look up the same rpm/load value you get 2.81 if IAM =1 and no FLKC knock then the value in the Knock correction table should match the KC Learned value yours is less so IAM is not 1 or you have FLKC (fine learning knock control ) active which you have not logged If we assume FLKC =0 then IAM = (KC learned value - FLKC) / (Knock correction Max A Value) at the load rpm point IAM = (2.34 -0) / 2.81 IAM = about 0.8 the ECU interpolates values between cells so this is only a rough guide and we dont know what FLKC is (which may not logg correctly either.) see here for more info http://www.ft86club.com/forums/showthread.php?t=61820 Talk to the openflash guys about the logging they should be able to fix it up for you. email or call them. Last edited by steve99; 08-18-2015 at 05:57 PM. |
#5 |
***** Lurker
So i guess the fix would be an update to my tablet? Will give openflash guys an email by the end of today..
#6 |
Drives: FT86
I suspect the OFT guys will have to fix the logging ram addresses the tablet asks the ecu for for your rom type, once they have corrected that and you update your tablet should be ok, but they will need to fix problem first.
#7 |
***** Lurker
Ok. Is shiv the correct person for me to pinpoint it to? Or via openflash website would be a good idea?
#8 | |
Drives: FT86
dont use the forum PM messaging as shiv get so many pm's it just gets lost email shiv at shiv@openflashperformance.com |
| The Following User Says Thank You to steve99 For This Useful Post: | yunheng (08-18-2015) |
| New RPM Calibration TSB... | 5AD86D | Issues | Warranty | Recalls / TSB | 23 | 01-21-2015 11:50 PM |
| changing calibration id | garfull | Software Tuning | 3 | 09-14-2014 01:30 PM |
| Need Map calibration number!! | Taino-BRZ | Software Tuning | 0 | 06-24-2014 11:59 PM |
| Speedometer Calibration!? | AZOOZ_95 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-04-2013 09:07 PM |
| DI pressure sensor calibration? - standalone | ElectronSpeed | Engine, Exhaust, Transmission | 0 | 02-28-2013 12:38 AM |
