Old 06-01-2012, 02:54 PM   #15
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Originally Posted by Superhatch View Post
I'm assuming this is for the FRS since the BRZ uses the LEDs for DRL?
There are plenty of studies that show DRL implementation dropping multiple car accidents (2 people involved, not indicating 3+) by 10-30%! http://www.ibiblio.org/rdu/DRLs/studies.htm
I know it might not look "cool" but the facts surrounding the use of them are hard to argue against.
Its all relative and estimated in those studies. Tons of variables to boot (Newer cars had better stopping distances with new brakes/tires/ABS ect ect ect.
Do you really pay more attention to a car because of some dim glow in the headlights? I see cars just fine, government mandates can and have ruined driving experiences.
Its good for dumb asses and drunks that forget to turn their headlights on in shit conditions/night.
chulooz is offline   Reply With Quote
Old 06-01-2012, 03:12 PM   #16
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
And a study that shows they have no effect (unless your driving a small truck apparently):
4. NHTSA’s most recent study finds no significant benefit to daytime running lights. It’s a little hard to track down, but NHTSA technical report HS 811 029 (pdf) states:
This is the third statistical analysis conducted by NHTSA to evaluate the effectiveness of daytime running lights (DRLs)…the analysis found that DRLs have no statistically significant overall effects
NHTSA’s study did find that daytime running lights reduced light truck crashes about 5%, but otherwise they had no statistically significant impact on safety.
That being said I would leave them alone on any car I owned.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 06-01-2012, 03:48 PM   #17
old greg
Rocket Surgeon
Drives: PSM GGA OMG
On the other hand, it makes it impossible to flash your headlights at those drunken dumbasses to let them know that they forgot to turn their headlights on.
old greg is offline   Reply With Quote
Old 06-01-2012, 03:49 PM   #18
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
http://www-nrd.nhtsa.dot.gov/Pubs/811029.pdf
The study is pretty easy to find. Reading through it now. Thanks for the link.
Superhatch is offline   Reply With Quote
Old 06-01-2012, 04:00 PM   #19
Superhatch
AIM4APX
Superhatch's Avatar
Ratio of Odds Ratios
Ratio of odds ratios, R, is the ratio of these two odds ratios, i.e., R = R1 . The value of R
R2 represents the relative odds of daytime target crashes involvements between DRL-equipped vehicles and non-DRL vehicles.
The hypothesis is that if there were no observed DRL effects, these two odds ratios would be identical. Therefore, if DRLs had no effects on daytime target crashes, the value of R would be
1. If DRLs had a positive effect, the risk of DRL-equipped vehicles involved in the daytime target crashes would be expected to be smaller than that of non-DRL vehicles and R would be less than 1. On the contrary, if DRLs had an adverse effect, R would be greater than 1.
Based on this statement (the formula can be found in the pdf) and the table on page viii which shows that the fatal car accidents for cars with DRL is -9.3. This means that cars with DRL actually have a 10% higher likelyhood of killing someone!
Take these out right away!!!! :P
...granted this contradicts the studies in all other 18 countries that currently have DRL laws.
Old 06-01-2012, 04:07 PM   #20
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I've found that those dumbasses are too stupid to translate the light flashing anyway!
Old 06-01-2012, 04:56 PM   #21
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
my take on DLR has always been for those cases of dusk and dawn.
when it's light enough for you to just drive the car but since the lights are off you're harder to see for other people.
i also drove a car with shitty lights for so long i don't even know when they are on or off, but for somebody else even a faint glow is warning enough. THere are some dumbass drivers out there that need all the warning they can get.
The Following User Says Thank You to 7thgear For This Useful Post:
_F-R-S_ (12-22-2012)
Old 06-01-2012, 05:31 PM   #22
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
WTF? The FR-S DRL's operates the high beams at a lower voltage via a resistor?
I though they were a separate light bulb, oh well. Dammit Scion!
tripjammer is offline   Reply With Quote
Old 06-01-2012, 05:33 PM   #23
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
This is what a lot of cars use, especially Toyotas.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 06-02-2012, 02:02 AM   #24
DarrenDriven
NW Region Moderator
OK, so I pulled my DRL fuse today and the DRLs still came on. WTF? I triple-checked that I pulled the right fuse... so I guess I will be pulling that resistor 100%!
Old 06-02-2012, 02:42 AM   #25
OrbitalEllipses
Drives: Attitude
Originally Posted by Longhorn248 View Post
Just want to point out that since DRL's are considered a "safety feature", removing them or making them inoperable is technically illegal. With that being said, I don't think anyone will encounter any problems for doing it, just wanted to make everyone aware just in case. Nice pics for the DIY btw.
Might not pass a state inspection depending on state and on the inspector. since as Longhorn pointed out, it is technically illegal.
Old 06-04-2012, 03:47 AM   #26
fistpoint
Drives: Supercharged Golf Cart
They aren't required by law yet are they? If not, then there is no reason to assume it's illegal.
fistpoint is offline   Reply With Quote
Old 06-04-2012, 10:08 AM   #27
Jeff Lange
Jeff Lange's Avatar
Not sure which fuse you pulled, but there is no "DRL" fuse.
The only fuse that directly affects DRL is the MPX-B fuse, but pulling that wouldn't disable the DRL, it would just prevent you from ever having high-beams.
There are 3 good ways to disable DRL:
1. Remove the resistor, as was shown in this DIY.
2. Replace the DRL relay with a SPST relay that does not have the NC circuit. (4 pin instead of 5 pin).
3. Depin/cut the green wire coming out of the engine fuse box that runs from the engine fuse box to the DRL resistor, or the black wire at the junction near the firewall.
Changing the relay type is the easiest way to go, but costs money. Removing the resistor is harder, but free. Not sure why you'd cut the wire when you've got 2 other choices.
Jeff
The Following User Says Thank You to Jeff Lange For This Useful Post:
FRSpdDmn (06-06-2012)
Old 06-04-2012, 11:02 AM   #28
Longhorn248
Hook 'em
Longhorn248's Avatar
After doing a bit more research it looks like it's going to be country dependent. DRL's aren't mandatory in the US, however they are permitted and considered safety devices. I'm fairly certain that removing safety devices on cars is illegal, but couldn't find any actual statutes to back that up. So it may or may not be illegal to disable them, but like I said before, I don't think anyone will have get into trouble for it.
Longhorn248 is offline   Reply With Quote
