Old 07-24-2015, 01:33 AM   #715
GTSRolla34
Drives: 2014 BRZ Limited - 1986 AE86
I just setup Torque Pro on my Nexus 7. I wasn't going to attempt to add Oil Temp as a layout gauge, but then I noticed that it was reporting data in the selection menu. I placed it on the layout and it seems to be giving me a steady stream of oil temp data. It was rading around 195-215 in flowing traffic, didn't spend too much time watching it, but it seemed to be working.
2014 Subaru BRZ LTD - Dark Gray Metalic
1986 Toyota Corolla GTS - CA18DE Powered
http://club4ag.com/forums/viewtopic.php?f=7&t=1247
http://www.86garage.com/forums/viewt...hp?f=40&t=1459
GTSRolla34 is offline   Reply With Quote
Old 08-06-2015, 06:49 AM   #716
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I did on google search in this thread to no avail.
I will be installing a Delicious Tuning flex fuel kit soonish. Can someone tell me if I can activate the ethanol % field in Torque?
Old 08-06-2015, 10:17 AM   #717
steve99
Drives: FT86
highly unlikely ethanol % will work with torque.
my understanding is torque app requests predifined factory pid's, ie the factory ecu will respond to these predefined requests. These are standardized across manufacturers hence torque or other apps can request this standard information from many factory ecu's.
Ecutek flex fuel is a hack or patch on the standard ecu code, its unlikely that ecutek would also patch the ecu obd request routines so the ethanol content was readable via obd requests and hence torque apps. Ecutek hijacks the rear 02 sensor or evap purge connection to the ecu for flex fuel sensor input.
If they did that they would not need to sell you the ethanol readout display kit or bluetooth device to send ethanol readout to your phone/tablet ect :-)
Captain Snooze (08-06-2015)
Old 08-06-2015, 10:29 AM   #718
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
I think the contrary : If you have the PID for the rear 02 sensor or evap purge you can easily convert it's voltage reading to an ethanol % (0-5V = 0-100%)
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
The Following User Says Thank You to banane63 For This Useful Post:
steve99 (08-06-2015)
Old 08-06-2015, 10:41 AM   #719
steve99
Drives: FT86
yes you probably could
although it may not work as ecutek likely disable the normal functioning of these sensor inputs as they would not want the ecu seeing the ethanol sensor inputs as rear 02 or evap purge readings.
but i thought he was referring to the pre designated e% pid in torque app ?
Old 08-10-2015, 12:42 AM   #720
Captain Snooze
Drives: Red Herring
Do I get points for answering my own question?
Delicious Tuning have an Android app for reading ethanol content. Sure, I would have preferred reading the percentage in Torque but this app runs an exceptionally close 2nd.
Old 08-10-2015, 02:31 AM   #721
steve99
Drives: FT86
not sure if youyr aware but a guy in coff harbour throttlehappy tuning has developed a flex fuel patch for A01G rom and can addapt for other roms, he is using brz edit he is on facebook. He does travel a bit to other cities on east coast.
Captain Snooze (08-10-2015)
Old 08-17-2015, 03:14 AM   #722
TCR
Drives: 2013 Toyota 86 GT
I wanted to add shift lights to my Torque Pro display, so I downloaded this RacingMeter plugin, however I can't seem to display the Oil Temp using their customizable display.
Has anyone used this?
https://play.google.com/store/apps/d...ortorque&hl=en
TCR is offline   Reply With Quote
Old 08-31-2015, 07:46 PM   #723
maregt
Drives: Subaru BRZ
Disable / Enable seatbelt beep
Hi everybody,
I found something that should be useful to those hating the seatbelt beep (just the beep, if you hate the seatbelt it's another problem and it's in the head, not in the car )
First of all, proceed at your own risk, I've tested these PIDs on my car (BRZ 2014) but i'm not responsible if you do something wrong or if your car is somewhat different than mine,
To check the current settings add this PID (this should be completely safe as you are just reading):
OBD2 Mode and PID: 21A7
Minimum Value: 0
Maximum Value: 0
Scale factor: x1
Unit type:
Equation: A
OBD Header: 7C0
double check everything and press the TEST button
If the response value is 61A7C0 seatbelt beep is on
If the response value is 61A700 seatbelt beep is off
If the response is different something is wrong, check again PID's configuration and retry
If for some reason your response is different from what expected stop here before messing with your car
If everything is ok add these PIDs
To disable the beep:
OBD2 Mode and PID: 3BA700
Minimum Value: 0
Maximum Value: 0
Scale factor: x1
Unit type:
Equation: A
OBD Header: 7C0
To enable the beep:
OBD2 Mode and PID: 3BA7C0
Minimum Value: 0
Maximum Value: 0
Scale factor: x1
Unit type:
Equation: A
OBD Header: 7C0
Usage is the same, go to the edit page of the PID with the setting you want to write and press TEST
DOUBLE CHECK EVERYTHING before writing value to ECU, i'm not responsible if something stop working as expected (even if you wrote the right values)
Final warning: don't add these pids as instrument, they aren't meant to be
maregt is offline   Reply With Quote
The Following 3 Users Say Thank You to maregt For This Useful Post:
Chimera (09-30-2015), codesplice (10-22-2015), Rosticles (09-01-2015)
Old 10-08-2015, 01:28 AM   #724
socal_48
socal_48's Avatar
Drives: '15 FR-S RS 1.0
any one know if there is a PID for tire pressures monitor?
socal_48 is offline   Reply With Quote
Old 10-21-2015, 03:01 PM   #725
Jonde875
Drives: GT86
I will shoooot myself soon if I dont get this oil temperature PID working on torque pro!
I tried many ways about this but still didnt get it!
OBD2 Mode and PID: 2101
Minimum Value: -40
Maximum Value: 215 (this is just the maximum that this location can support, which does not mean the sensor can read that high)
Scale factor: x1
Unit type: C
Equation: AC-40 (no space between A and C; "AC" is the location within the response)
OBD Header: 7E0 (Auto also works, but seems to take longer)
Says only no data!
I have 2012 GT86 and I tried that default oil temperature too but that not working either. Adapter is ELM 327, Phone galaxy S4 4G+
Jonde875 is offline   Reply With Quote
Old 10-21-2015, 03:18 PM   #726
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Minimum Value: -40
Scale factor: x1
Unit type: C
Says only no data!
I'll share my settings once I get my hands on my tablet, will be a few hours
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to ck-GT86 For This Useful Post:
Alltezza (10-22-2015), Jonde875 (10-21-2015)
Old 10-22-2015, 01:59 PM   #727
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Got to be your adapter. If default setting and the settings on 1st page don't work.
Sent from my XT1575 using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 10-22-2015, 03:27 PM   #728
Jonde875
Drives: GT86
If I setup the oil temperature PID from PID management do I have to add new gauge from real time information to get it viewing or does it appear itself there?
I will try to uninstall it and install it again and see if it starts to work!
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
