#57 |
Drives: 4-Runner Sport - 13' BRZ SportTech
Pardon my ignorance, but what gains are there to be had with wmi on na?
Top Tier Imports - Check out my build journal HERE
#58 |
Drives: 2015 Subaru BRZ Series.Blue
that's what i'm curious about. i've been reading lots of mixed things about wmi on na engines, but nothing that consistently says it's a good or bad idea... so, i'm hoping ptuning can clear things up for me...
#59 | ||
Thats pretty neat
Drives: LOADING......
In a nutshell, you'll gain a better octane rating on pump gas wich will allow you to adjust timing slightly to gain a few ponies. And you might make the intake air a tiny bit cooler, but not drastically. |
#60 |
To be honest, we won't know unless we test it out. WHITE is correct as to what we gain with W/M.
With W/M, we can safely run less fuel (leaner AFR) and more timing on a boosted motor because it raises the effective octane rating of the fuel. The problem with an NA application on 93 is that we're already running the fuel as lean as you would for max power. In addition, we're already so close to or at MBT timing that there is very little room to grow. Guys running 89 or 91 will likely see gains but for 93, we're honestly just not sure. For testing purposes, if you guys are interested and we had a volunteer, we could setup a rig to mount all the necessary hardware outside the vehicle and run a dyno tune on it. The only thing we would need to do is tap an intake pipe for the nozzle. This way, we don't have to go as far as installing the entire kit. |
| The Following User Says Thank You to Ken@PTuning For This Useful Post: | Sportsguy83 (08-17-2015) |
#61 |
Drives: RX-7 / BRZ
Hey guys is the AEM controller your using able to be remotely controlled from in the vehicle? With ecutek allowing multiple maps would it be possible to shit it off/on on the fly with the map switching. I love chacing power but I also have a few tunes that are strictly for my daily drive where the system isn't needed.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#62 | |
#63 |
Drives: 1996 Honda Civic
Bump!
#64 |
Drives: GT 86
Any progress on a RHD version .
#65 |
Drives: Toyota GT86 Pearl White
I'm also interested in purchasing the RHD version of this kit!
I Currently have an HKS V2 Supercharged GT86 running around the sunny island of Malta (Europe) ![]() It would be great to run this kit! i'm very interested in the RHD version |
#66 | |
Drives: S1000RR
We've had a few interest in the last year or so about a RHD version of our Pnp WMI kit but without having a RHD car here in the USA, it's difficult to create the mounting bracket for the WMI bottle which bolts right into the OEM battery location. If you all can solicit at least 10+ RHD owner that is seriously interested in our WMI kit for the RHD 86, we can make up a RHD prototype mounting bracket for one of you to test to verify fitment. MrC |
#67 | |
Drives: WRB BRZ Series.Blue
#68 |
DrivinginDreams...Cloud86
Drives: Toyota GT86
What are the advantages of running this setup over something like Snow Performance?
#69 |
Our kit is meant to be as easy to install into the vehicle as possible. The only fabrication necessary if you're not running our turbo kit is to mount the nozzle on the intake tract (our turbo kit already has a 1/8NPT bung welded onto the charge pipe). The reservoir, controller, and pump are directly bolted into the engine bay, no modification/fabrication necessary.
| The Following User Says Thank You to Ken@PTuning For This Useful Post: | Chad86 (11-07-2015) |
#70 | |
Cognite
Drives: 2013 Whiteout FRS
what does one have to do it order to achieve this? will the systems play together nicely? any additional tuning required? |
| Tags |
| ptuning, water meth |
| PTUNING: PnP Water/Methanol Injection System w/Optional Failsafe | ptuning | Forced Induction | 121 | 09-29-2017 03:01 PM |
| Water Methanol Injection? NA application. | hmong337 | Engine, Exhaust, Transmission | 12 | 07-16-2014 01:19 PM |
| AU GT86 Rear view camera Plug-n-play on Canadian (Pioneer) navigation system ? | Simon99 | Electronics | Audio | NAV | Infotainment | 26 | 04-24-2014 05:38 PM |
| water methanol injection | Silverdub | Forced Induction | 22 | 07-11-2013 04:58 PM |
| AEM WATER METH METHANOL INJECTION KIT | JPxM0Dz | Engine, Exhaust, Transmission | 10 | 04-14-2013 12:03 AM |
