Old 08-16-2015, 09:23 AM   #71
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by djliquidsteele View Post
Is there a downloadable manual somewhere to make sure there aren't any tool I may need to buy before install. I guess specifically I am looking for torque ranges for complete install so I know which torque wrench to buy.
you're torquing to original bolts & nuts.
up 80 lb/ft should be fine
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
djliquidsteele (08-16-2015)
Old 08-16-2015, 12:06 PM   #72
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Here's a very detailed DIY instructions from the Grimmspeed guys with some other TEIN coilovers. http://www.ft86club.com/forums/showthread.php?t=12864
mit_peid is offline   Reply With Quote
The Following User Says Thank You to mit_peid For This Useful Post:
Old 08-16-2015, 09:05 PM   #73
mit_peid
Boosted Noob
mit_peid's Avatar
Do the two rear shocks share the same part #? I shouldn't have a ZN6/ZC6-L correct? Name:  ImageUploadedByTapatalk1439769817.200829.jpg
Old 08-16-2015, 09:26 PM   #74
Createddeleted
Drives: 2014 BRZ - 2004 GLI
Originally Posted by mit_peid View Post
Do the two rear shocks share the same part #? I shouldn't have a ZN6/ZC6-L correct? Attachment 117993
Correct. As R means rear in this instance.
Createddeleted is offline   Reply With Quote
The Following User Says Thank You to Createddeleted For This Useful Post:
mit_peid (08-16-2015)
Old 08-16-2015, 11:32 PM   #75
zc06_kisstherain
Drives: SWP BRZ
ordred mine..cant wait
Old 08-17-2015, 02:42 PM   #76
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Yes. Rear shocks are literally the same (you can verify with your OEM units as well).
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
mit_peid (08-17-2015)
Old 08-17-2015, 07:38 PM   #77
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Any comments on these vs the ST? Someone else asked earlier, as well.
uspspro is offline   Reply With Quote
Old 08-17-2015, 08:06 PM   #78
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I am looking to move to street coils soon and these seem to be the two best options by far. The Tiens do have the tophats though...
2much is offline   Reply With Quote
The Following User Says Thank You to 2much For This Useful Post:
CSG Mike (08-17-2015)
Old 08-17-2015, 08:55 PM   #79
djliquidsteele
Drives: Scion FR-S
I was originally going to get the ST's, but these came out literally a week before I was about to order and they seem hard to beat for the price. Plus these have adjustable damping and camber adjustable plates as an added bonus. With the money I saved by not having to buy camber plates, I spent on LCA's (Also from CSG) so I can get rid of my stock LCA's with adjustable bushings and really get it dialed in right.
djliquidsteele is offline   Reply With Quote
The Following User Says Thank You to djliquidsteele For This Useful Post:
Old 08-17-2015, 09:37 PM   #80
tracerit
Drives: '13 SSM BRZ Limited 6MT
Just placed an order for a set from CounterSpace Garage! I'm going to review some coilover isntall videos tonight and see if I'll be confident enough to attempt it myself.
Regarding alignment, is a corner balance necessary? Or will a regular alignment suffice? This will be a daily driver.
tracerit is offline   Reply With Quote
Old 08-17-2015, 10:21 PM   #81
CSG Mike
CSG Mike's Avatar
Necessary? No. Nice to have? Yes. For a daily driver, you probably will never notice the difference. Just be sure to set up the left/right dampers identically.
tracerit (08-17-2015)
Old 08-18-2015, 10:52 AM   #82
Shady195
Drives: '13 10 Series FRS #1203
As you install, set the preload, set your ride height. MEASURE, MEASURE AGAIN and then maybe take a picture of your measurements and compare to the other side..
Also be sure to torque the locking collars per spec as well. Will save you some possible aggravation
Shady195 is offline   Reply With Quote
The Following User Says Thank You to Shady195 For This Useful Post:
tracerit (08-18-2015)
Old 08-18-2015, 12:54 PM   #83
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
So I have those for now one month.So time for a report
I went through a mountain trip of 3000 km through French alps, Italian alps and Swiss alps. i went through many famous pass and some of the rally famous pass.
My conclusion is that i'm only half happy of those and if I can't find better setting I will go back to OEM.
They are incredible smooth on small bump and make you feel more confortable at low speed but as soon as you increase speed on bad B road and even on high way they get very harsh on big bump making you jump out of your seat. Really!!! do I need harness with those! this happen on B road ( bad road) at speed over 90 mph and on high way ( more smooth road) at speed over 110 mph.
I was really not feeling in confidence when pushing really hard the car on those twisty road on those pass. I felt that on big bump it could not absorb the shock and will throw me away from my target. also on some big compression on bad road not flat the car will hit the floor on the bottom.
I have totaly scratch my miltek exhaust. It also ride a lot on the bump stop i feel I'm hitting then non stop. The car is feel more prone to understeer. Also the car lost a lot of the fun because of less weight transfer. So more difficult to slide in curve's.
In my city I have lot of underground parking and I often touch the bottom of the car Just under my seat area. One time I had to ask guy's to help lifting the car so I could pass as the bottom was on floor and the rear will were slipping coming on top of a ramp in those garage.
The best setting i found to adjust damper in 7 click front and 5 click back. any thing less than 7 click front I feel I lose control on big bump. More than 5 click in the back and I'm almost only riding bumpstop.
They are almost opposite to OEM. The OEM ride hard on small imperfection and absorbe very well big bump. those do exactly opposite wish make me think they are more build for show than efficient.
I use the USA setting from the manual deliver with those FlexZ to set up ride high and preload.
Oem height on my car was from center wheel to fender edge :
Front 367.5mm
Rear 372.5mm
Tein Z with USA setting on car:
342.5mm front and rear so 25mm( 1 inch) drop front and 30mm (1.2 inch) drop rear
I think I don't like it's set up same back and front.
So now to give it one more chance i want to rise the car buy about 15mm back and 10mm Front. But i would also like at same time to get more travel so I guess i have to adjust this hight by giving more preload because if i adjust only by bottom screw for ride hight i will get the car at the level i want but same travel. Isn't it?
This is on GT86 from europe.
PS: I have no idea how those guy with drop more than 1" can be fast on B road without destroying the bottom of their car and their exhaust?
Mars2 is offline   Reply With Quote
Old 08-18-2015, 01:22 PM   #84
churchx
churchx's Avatar
Drives: 2014 GT86
Mars2: i guess you got coilover version for rest of the world, not USDM's?
Tein Flex A DeaconRoc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 138 04-12-2018 06:23 AM
Tein Flex A and Z!!! breadcrumbz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 05-24-2016 04:44 PM
Tein Street flex JM'sFR-S562 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-09-2015 12:04 PM
Tein Flex Z Bigmaxy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-27-2015 04:22 AM
FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut kvnchu Brakes, Suspension, Chassis 26 12-09-2013 02:10 PM
