Old 08-13-2015, 01:23 AM   #29
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
I'm not a painter, but I think I mentioned earlier that it could be just a slight defect during the painting process. Could be considered normal since other people have experienced it and the nature on the curved surface. I forget the term, but the metallics in the paint may have cluttered/settled in a fashion that makes the odd line when hit with direct sunlight.
The paint on these cars are pretty low quality as is, my SWP shoes cloudy blotches in the sun and my door handle has a certain dark spot as well.
Instagram: stimson
Old 08-13-2015, 01:47 AM   #30
Chie
Drives: 2015 Scion FR-S
Pinnacle pre wax body lotion + some collinite 845 should do the trick
Chie is offline   Reply With Quote
Old 08-15-2015, 07:27 PM   #31
Turbo95eg6
Turbo95eg6's Avatar
Originally Posted by Devante View Post
Sorry I'm dumb. I can't figure out what WRB is.
Siiiiiiiiiiiigh ok I didn't want to admit this but I will because I don't want you stressing out over this.
Mine turned out to be a reflection. YES A REFLECTION.
Somehow the sun hits that part of above the fender where it curves in just right at certain parts of the day and makes it look exactly like in my pictures and video.
If you shield the area from the sun, it won't change the 'mark' at all. No matter where you stand, the mark doesn't change shape or anything.
However, if you put your hand riiiiiiiight against that concave section, you'll block the reflection.
It's the strangest reflection I've ever seen but it's just the sun.
Sorry for all the wasted time guys.
By the way, once I found this out accidentally, not only did I test it by blocking the concave area but I turned my car around and got the same mark on the opposite side. Literally the same shape and length.
Tldr: it was just the sun.
You mean this?
Instagram: stimson
Old 08-15-2015, 08:02 PM   #32
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
Yeah that looks like the same thing. Touch the center of the concave part and it'll disappear. But you have to basically put your finger on the surface where the reflection originates or it won't go away.
Devante is offline   Reply With Quote
NW Tint Shop Directory DarrenDriven Northwest 102 04-17-2018 10:10 PM
tint shop in around Fairfax County incubus1995 Mid-Atlantic 13 04-29-2014 06:38 PM
Tint Shop In GTA ArKiTeCkT CANADA 80 04-24-2013 08:46 PM
Tint Shop crazyprac Mid-Atlantic 12 04-17-2013 09:54 PM
Best Tint Shop in SoCal Jeffboyarrdee Southern California 16 11-10-2012 01:20 PM
