Old 08-15-2015, 03:45 AM   #15
mo420
Drives: '13 Black Toyota 86 (AT)
Hopefully the dealership updated you ECU to the latest revision should be ZA1JB01C (MAN) OR ZA1JB01D (AUTO).
ECU firmware revisions up to A00x had a problem with the Transient ingnition retard settings which contributed to DI seal failure on injectors when accompanied by shifting at redline and poor quality fuel. and ECU firmware A01x or later solved the issue.
Thanks for this info. Spoke to the techs whilst I did my DI replacement earlier at Toyota about ECU updates, they told me there's no need to. They even told me its not possible to customise car's settings like DRL etc through Techstream which I is weird and most probably BS. I'll phone in again on Monday to ask for this and see how they respond.
Is there a way to check for the ECU version myself somehow? I might be able to get hold of an OBD2 scanner would that tell me the version? This car hasnt had any ECU updates since it was bought new in 2013.
Btw whilst on this matter, just curious if anyone knows what else does the B01D update improve on other than the improved injections?
mo420 is offline   Reply With Quote
Old 08-15-2015, 03:57 AM   #16
mo420
Although the injector may have failed for some other reason, there was nothing wrong with the seal. Zero blow-by.
Was wondering if you would care to elaborate more? I'm not fully conversed on the technicalities of the injector but I'm interested to learn. What/why do you think they failed prematurely? Is it the carbon buildup that's causing it? I am assumimg by Zero blow-by you mean no evidence of cumbustion products passing from the chamber outwards through the seal (a failed seal) am I right? Sorry for sounding like a n00b just want to make sure I avoid this from happening again
I am thinking I should run some injector cleaner every now and again to maintain cleanliness. Looking at the amount of carbon buildup on the old ones in quite scary considering my low mileage and the fact that I dont do a lot of spirited driving (hmmm maybe that's why!)
Old 08-15-2015, 04:09 AM   #17
Not at all! The DI system is brand new to me as well. Yes, I not-so-clearly stated the seal did not fail. Got hot, sure, but that thing pokes right into the combustion chamber. it looks normal to me.
I don't think there's anything you can do or should be concerned about. We're not seeing a trend of DI failures. Perhaps it was just the luck of the draw. With any manufactured system there will always be a statistically measurable failure rate.
Old 08-15-2015, 06:08 AM   #18
mo420
Wink
To be honest, I was initially on the illusion that my DIs failed due to the seals - like a lot of reported cases here on this forum. Now that you pointed this out, guess I'll need to find out why it failed - manufacturing defect or otherwise. I've been told a lot of the local 86s have got injectors replaced as well - probably its our fuel. Hopefully these new set of injectors will last for long or if they dont, at least before my warranty expires
The Following User Says Thank You to mo420 For This Useful Post:
Ultramaroon (08-15-2015)
Old 08-15-2015, 04:25 PM   #19
I'd love to hear about it if you can squeeze out some more details.
Old 08-15-2015, 07:55 PM   #20
Fastbrew
Drives: 2014 Pearl White BRZ
Here are my injectors pulled at 21K miles - Replaced with FIC 880s.
Ran on Chevron Supreme 92 octane for that 21K.
This is how they looked when pulled - no cleaning.
Fastbrew is offline   Reply With Quote
Old 08-15-2015, 08:05 PM   #21
Those are <cough> manifold injectors.
Old 08-15-2015, 08:13 PM   #22
Fastbrew
lol - still pretty damned clean
So - his pic is of the low pressure injectors? (blue in diagram below)
Mine are the high pressure system injectors - right? (red in diagram below)
Or do I have it bass-ackwards....
The Following User Says Thank You to Fastbrew For This Useful Post:
Old 08-15-2015, 08:17 PM   #23
I would hope so. If they weren't, you'd have much bigger fish to fry.
edit: Haha... yeah. the manifold injectors are the low-pressure ones. The DI injectors are the high-pressure ones. They have to be because they spray fuel into the combustion chamber at maximum compression and must be able to withstand the hostile environment inside there - just like diesel engine injectors.
Old 08-15-2015, 09:38 PM   #24
steve99
Drives: FT86
The dealers here say the same rubbish, but its probably due to the fact they dont have a specific directive from toyota\subaru to update firmware
Most obd scanners will read the ecu calibration id
for manuals in middle east region 2013 probably will have ZA1JA01J if so thats probably all you need although their is a ZA1JA02J rom out for your region if your car is 700J 900J or A00J then it definitly needs an update for the transient ignition retard this caused heaps of knock on high rpm gear changes especially on poor quality fuels.
their are no performance benifits with later roms just di seal fix and idle stability fixs
usa guys on usa93 fuel is about the best pump petrol on the planet so they dont have as much issues.
see the tactrix link below it has those rom attached at end of post, dealer wont flash those though :-)
Old 07-29-2017, 08:35 PM   #25
hussen
Drives: Toyota 86
Hello,
I think I have same problem (see the following video)
[ame="https://www.youtube.com/watch?v=3AU035Pvkp0"]86 problem - YouTube[/ame]
did you solve the problem totally !?
can you advice me ?
Regards
hussen is offline   Reply With Quote
bogging, ecu, hesitation, slow accelaration, stumble
Engine bogging down FRiSson Issues | Warranty | Recalls / TSB 6 08-14-2015 09:07 PM
Engine Hesitation for 1-2 seconds. phoenixrage Issues | Warranty | Recalls / TSB 9 07-14-2015 06:18 AM
M/T and idling over speed bumps - jerking mstoochn Issues | Warranty | Recalls / TSB 7 04-29-2015 05:45 PM
RPM hesitation on WOT? Yamajee Issues | Warranty | Recalls / TSB 8 01-10-2015 01:43 PM
Engine stumble around 2.5k rpm in cold weather Eyesacky Issues | Warranty | Recalls / TSB 2 11-02-2013 05:50 PM
