Old 08-13-2015, 10:54 PM   #57
S84kam
S84kam's Avatar
Drives: FBRZS
Originally Posted by supercharged2 View Post
Thanks! Yeah I've been a lurker for a while. I'm still using the harness, I'm just going to modify it a little for the single control.
You'll want Chaetagnath's harness because it uses plugs that mine doesn't. The 8 pin plug for the manual harness (plug 2 on his diagram), and plug 3 for the D29 option connector behind the radio. Plus the conversion plugs for the blower resistor. These plugs make it way more plug and play then mine. Those will be the harder plugs to find but the junkyard is a magical place...
c'mon, get an ohm meter and pin it out for us like has!!
S84kam is offline   Reply With Quote
Old 08-13-2015, 10:57 PM   #58
pleong
Drives: 2013 Whiteout FR-S
I also contacted a local shop that does wiring harnesses to see if they could do it.. Can yall tell I really don't want to do this if I don't have to? Lol
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
Old 08-14-2015, 12:23 AM   #59
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
Here are some of the parts.
Cessblood is offline   Reply With Quote
The Following User Says Thank You to Cessblood For This Useful Post:
Binary_fission (08-14-2015)
Old 08-14-2015, 12:26 AM   #60
Binary_fission
Binary_fission's Avatar
Drives: FRS
I'm going to the dealer on Sat to see how much all that ganna cost as well as if they can install it factory way
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
Old 08-14-2015, 01:58 AM   #61
wootwoot
Drives: FRS
A lot... And they can't.
The Following User Says Thank You to wootwoot For This Useful Post:
DustinS (08-14-2015)
Old 08-14-2015, 02:11 AM   #62
Binary_fission
Drives: FRS
They have to, what if mine brakes and doesn't work? They not going to replace whole car just for ac components
Old 08-14-2015, 11:24 AM   #63
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
The problem is the interior wiring harnesses are different between manual and auto climate cars. It requires a separate custom harness to make the swap work.
Old 08-14-2015, 05:44 PM   #64
Cessblood
Originally Posted by phanguy View Post
i'm actually the first person that purchased the harness from him. i did the install not long after i got it. the only weird thing for me is that the air pushes through the footwell even if i don't want it to, but that's not a huge deal.
he did have a second harness planned to be just for single control, but i'm not sure what came of that. honestly i would recommend people go for the single control because going for the dual control is a lot more involved. you have to completely replace the part that controls the air flow because there is an extra denso unit as well as plastic pieces to separate the airflow. really it's all kind of messy and i'm starting to think maybe i screwed something up in there which is why i get air coming to the footwell...
anyway. it does do what it's designed to do and i have the dual climate in my car and working. the entire dash MUST be removed if you're doing the dual climate since you'll have to swap the pieces. it's a huge PITA. you'll also need to refill your a/c. i was told that i should be able to do it without having the refill the a/c, but i couldn't see any possible way to remove what i needed to without disconnecting the a/c lines leading to the cabin from the engine.
i mean i'm glad i did it, but if i were to do it again, i'd do just the single control harness.
Do you have pictures or videos of your set up?
Old 08-14-2015, 06:49 PM   #65
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
it doesn't look any different from the brz... it looks and acts almost exactly like it except for what i've mentioned. so not sure how useful a video would be to you, but i can make one if you want??
phanguy is offline   Reply With Quote
The Following User Says Thank You to phanguy For This Useful Post:
Cessblood (08-17-2015)
Old 08-14-2015, 07:35 PM   #66
Cessblood
That will be nice.
Old 08-23-2015, 07:43 PM   #67
S84kam
S84kam's Avatar
Drives: FBRZS
Finally pulled the trigger on the panel. Decided to just put the frs hvac switches in and kept the brz bottom toggle switches.
The Following 2 Users Say Thank You to S84kam For This Useful Post:
Cessblood (09-01-2015), tiz22 (08-23-2015)
Old 08-23-2015, 08:09 PM   #68
tiz22
tiz22's Avatar
Drives: 2013 Scion FR-S (Raven) MT
Interesting... So the toggle switches do what exactly? Aesthetic purposes only?
My Car Journal: Raven FR-S w/ TRD Flavour
Click for my AVIC Z150BH Head Unit DIY Install
tiz22 is offline   Reply With Quote
The Following User Says Thank You to tiz22 For This Useful Post:
Cessblood (08-24-2015)
Old 08-23-2015, 08:49 PM   #69
S84kam
S84kam's Avatar
Drives: FBRZS
I wired the 1st switch for my front number camera. And the other 4 or in used for now. Also the led's are functioning as well, I cut the circuit board in half for the switches and led.
Old 08-24-2015, 11:44 AM   #70
DustinS
DustinS's Avatar
@RWDfun
This is where you want to look for a real Dual CC Swap. Really good info in here
Wtb:pnp harness for automatic climate control for frs Sangthing Want-To-Buy Requests 5 01-02-2015 05:11 PM
BRZ limited dual climate control Sangthing Interior Parts (Incl. Lighting) 6 09-12-2014 07:01 AM
Ac knobs for BRZ limited / FRS with dual climate dnizzle Cosmetic Modification (Interior/Exterior/Lighting) 3 08-15-2014 11:43 PM
FS - BRZ Dual Climate Control Unit dvsidboy Audio/Visual, Electronics, Infotainment, NAV 4 01-12-2014 09:52 PM
