Old 08-13-2015, 05:54 AM   #43
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
I'm trying to get a bit more rear end rotation in my spirited daily driving with stock suspension parts. '14 BRZ
My tires are stock and at 50% or so and wearing perfectly, so I don't want to
change the alignment setup too much.
I'm putting on an adjustable rear sway (Perrin 16mm 30%-100% increase approximately)
And Whiteline top hats that will be set to add .75 degrees additional caster without adding camber. (Total caster would then be 6.5 I believe.)
I'm hoping to get a subtle increase in rotation without any snap oversteer or uneven tire wear.
Seem like a decent plan?
MGPAX is offline   Reply With Quote
Old 08-13-2015, 08:35 AM   #44
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Rear toe has a huge influence on rear end stability: the more toe-in the more stable. From dodgy memory @CSG Mike runs zero toe at the rear but he knows how to drive. Myself 0.5mm a side. BUT don't forget compromise! Reducing toe-in makes rotation easier but affects stability. Adjust little by little.
MGPAX (08-13-2015)
Old 08-13-2015, 11:21 AM   #45
CSG Mike
CSG Mike's Avatar
I run zero on stock or near stock cars in the rear, but myalignment preference will change depending on what exactly is on the car.
As a general rule of thumb, I recommend 0 for stock/near-stock cars for experienced drivers, and 1/16" total toe-in for most modified cars.
MGPAX (08-13-2015)
Old 08-13-2015, 11:46 AM   #46
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I run zero rear toe as well, and a slight bit of toe out up front. Yes, the car will wander a bit on the highway and is very responsive to input at any speed, but I like the ability to get it to rotate at will, and it makes a nice compromise between a super aggressive autocross alignment and one dumbed down for minivans. If I were going to Bonneville, I'd go a little more conservative, but I feel like it really wakes the car up, which is why I bought it in the first place.
The Following 2 Users Say Thank You to venturaII For This Useful Post:
CSG Mike (08-13-2015), MGPAX (08-13-2015)
Old 08-13-2015, 01:13 PM   #47
MGPAX
Still 17!
MGPAX's Avatar
Here's my suspension.
Toe is virtually zero all the way around from the factory.
I'm going to fix the small difference in left right rear toe...which is already
just barely off zero. (Is this just odd or is rear toe always measured from the
back of the car?...as is reverse of front?)
I'll have it checked again once parts are on.
PAX
The Following User Says Thank You to MGPAX For This Useful Post:
stugray (08-13-2015)
Old 08-13-2015, 01:23 PM   #48
wparsons
wparsons's Avatar
Originally Posted by Shankenstein View Post
Roll by itself isn't inherently evil. The side effects of roll can lead to reduced handling.
Redistributing weight (tire loading) can reduce the available grip. Flex in the bushings and chassis can lead to poor geometry.
Too much roll for the suspension geometry can really compromise the contact patch too. On a car with good camber gain, roll isn't so bad. On a car with poor camber gain (or zero, like our front ends) it's pretty bad, and requires more static camber to compensate.
flickr
Old 08-13-2015, 01:57 PM   #49
Racecomp Engineering
PAX
I wouldn't be so happy with that alignment. The rear toe would bother me.
More front negative camber would help your rotation issues as well, even on stock tires.
EDIT: I'm also not sure what you mean by "Is this just odd or is rear toe always measured from the
back of the car?...as is reverse of front?"
- Andrew
Racecomp Engineering is online now   Reply With Quote
Old 08-13-2015, 02:16 PM   #50
MGPAX
Still 17!
MGPAX's Avatar
- Andrew
*This alignment check is the first one since buying the car over a year ago. I thought it was pretty good for stock after over a year of sliding around!
Thanks for your input. And the rear toe is what I'm talking about.
The little picture next to the setting is saying that a positive number is
actually taken at the rear of the rear wheel (rear of wheel's distance from center) thus it is actually toe IN. (Which I always thought was a negative number)
Am I right?
The Whteline top hats have a .5 degree setting to add neg camber. But I thought with all the caster on this car I may be over doing it if I add more camber also. You think I should add the camber also?
Thanks for your input!
Old 08-13-2015, 02:31 PM   #51
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
PAX
I cannot overstate how much camber has transformed my car, I would rethink the tophats you just got and get camber plates, no noticeable impacts to NVH on my car and like I said, transformed from what I would call an understeering pig to something that actually rotates. And I've still got toe-in on the rear because I do significantly more street and highway miles than speedy driving. I'm around -2.5 degrees now, some guys are up over -3.
Even just camber/crash bolts to get you up over -1 degree up front will be a noticeable difference.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
CSG Mike (08-13-2015), MGPAX (08-14-2015), Racecomp Engineering (08-13-2015)
Old 08-13-2015, 02:44 PM   #52
Chad_W
Drives: 2013 BRZ DGM
On other cars I've run zero toe and -1.5 camber upfront and while I really enjoyed the handling, I would wear out the inner shoulders of my tires 30-40% quicker than the outers. How has that alignment held up in terms of tire wear on the BRZ?
Chad_W is offline   Reply With Quote
Old 08-13-2015, 02:53 PM   #53
Gotcha, that makes sense then. We just never really like factory alignments or "in spec" by the book alignments.
Am I right?
Toe in is positive, toe out is negative. I'm not following on the where you measure it thing. I'm trying to find a good picture for you but gotta meet with someone in a sec.
Yes definitely! You will see a big improvement especially on stock suspension. Even 0.5 degrees more than what you have would be on the lower end of what I would recommend. See strat61caster's post.
- Andrew
Old 08-13-2015, 02:56 PM   #54
strat61caster
I'll take wearing out the inner shoulders over many DD miles over wearing out the outer shoulders over a few track miles. I've also planned on buying a set of tires per year on nice 200TW competitive tires in OEM size, so far I think I'll get two seasons out of the ZII's.
I plan on adjusting my camber before and after events, my current setup seems to have little impact on toe when adjusting the camber, takes all of ten minutes to pull the jack out, make the adjustment and put the jack back.
ineedyourdiddly
Ultramaroon (08-14-2015)
Old 08-13-2015, 03:06 PM   #55
-1.5 is not excessive at all IMO for these cars. Consider that from the factory they have about that much or a little more in the rear...while the front is a macstrut set-up with wheels that turn....
- Andrew
Old 08-13-2015, 03:08 PM   #56
stugray
Drives: 2013 GBS BRZ Limited
PAX
I would say that ALL of that is suspect if your RR tire pressure is ZERO PSI
The Following User Says Thank You to stugray For This Useful Post:
MGPAX (08-14-2015)
Reducing Drone Suggestions? JohnAyySays Engine, Exhaust, Transmission 7 04-08-2014 01:20 AM
Reducing squeel after HPDE transition Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 03-16-2014 02:20 PM
Reducing Rasp Admired Engine, Exhaust, Transmission 28 01-25-2014 02:40 PM
Reducing engine compartment temps mike_ekim1024 Engine, Exhaust, Transmission 1 12-11-2013 03:57 AM
Reducing Insurance for hardly used car? ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 6 08-31-2013 07:35 AM
