#3641 | |
Drives: Raven 6 speed Manual FRS
Well obviously those people are wrong if they are behind you!
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel. |
#3642 | |
C-Street AutoX
I've been up front with my full setup the entire time, but everyone seems to gravitate towards Strano bars and 225's. I'm on the tall tires, Koni's half a turn from full stiff front and rear, 29F 30R These tires don't seem as sensitive to pressures as old Rivals were though. I'll bet you four dollars you hit the limiter at nationals.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate |
| The Following User Says Thank You to SeanRTR For This Useful Post: | TMF (08-12-2015) |
#3643 | |
Drives: Toyobaru FRZ
One thing I'd like to add is that the course was slow enough to where the ND could stay in 2nd gear. The current popular belief is that the ND's short gearing could hurt its competitiveness. Apparently stock ND's do between 52 and 55mph in 2nd, depending on tire. It got to 55mph using the tire in the article. A course that required a shift to 3rd on the ND but could be left in 2nd to the NC could have altered the results. Since National level courses tend to be faster than your typical local, shifts to 3rd would certainly be required if using an ND. In any case, the ND looks to be a pretty incredible performer. A non-Club beating a fully prepped and well driven NC is no joke. Very curious to see where they put it. |
#3644 | |
Drives: '14 FRS TT5
#3645 | |
Drives: 2014 FR-S
#3646 | |
C-Street AutoX
Haven't proved anything yet....still may need $5000 shocks. But I'm not spending any more money on shocks than what I got with my under cambered 50k mile Koni inserts. +.078 was a bummer this weekend. Potocki's and Ferchak drove really well. I'll load video later tonight. If you have the front 21mm TRD front, I'd just leave it. I'm buying tires tonight..... My 235's look decent (120+ runs), but everyone says full depth tires are slower...I think these people are just crazy. I'm buying new tires today and testing them this weekend on concrete, I'll report my findings.... just need to determine 225/45/17 or more 235's... Wilmington (at least day 2) was definitely a 225 course. Makes me wonder if I should actually have both sizes on hand for nationals.
#3647 |
Was really surprised to see that Harvey passed you on Sunday. I did enjoy seeing 3 different cars in the trophies though, have to appreciate how well balanced CS seems to be right now.
I think the 235's worked well for Day 1, I pinged the limiter once before the huge sweeper and felt like the shift point in the finish was about perfect, but they were definitely not doing much for me on Day 2 (plus I drove like absolute crap) Funnily enough Mike Eckert and I were working on shock adjustments all weekend, and wound up a feeling like 1/4 turn from full stiff in the rear and 1/2 from full stiff in the front was where the car felt best. Pretty close to where you said you were. I'm also not on the TRD springs, have a smaller front bar, and the OEM rear. I was so psyched to be within .3 of Fenter on Saturday, unfortunately he was obviously having a slightly off day, because he pulled way ahead on Sunday. I have to say that the running first heat on Saturday was a little challenging. The car had no rear grip first run and we softened the rears significantly only to crank them back up Over the next few runs. Next time I'll just drive through it and know that the rear grip will come in as the dust gets swept off.
#3648 | ||
Drives: '14 FRS TT5
About the front bar, I just found yesterday that the TRD front is in fact 21mm...and I'm assuming the Perrin 22mm on soft is going to be pretty darn close. Has anyone tried the staggered setup with 225's in front and 235's in the rear? I'm about to have my 225's flipped, but I'm tempted to flip 2, and buy 235's for the rear. Ideally, you'll get the sharp turn-in and slightly higher top speed, but only give up the low-end torque. Tough for me to say as I haven't had a chance to test the 235's. I'm also curious if the staggered setup would throw off the balance and create a need for adjusting tire pressures and/or koni settings. Seeing as I don't have any good events (well, perhaps one) prior to nats, I might just stick with my current setup. I doubt I'll be in contention for winning CS anyway, but I'd at least like to finish in the top half! Quote:
Random side note: I worked at a local track event last week and got in some free track time. I had the stock tires on as I was trying to conserve my stones for nats...holy drift fest! It was amazing how that loss of grip really allowed the low hp to rotate the rear end on command. |
#3649 |
C-Street AutoX
I won the Peru match tour last year (against Harvey) with my staggered setup, 225/45/17 front, 245/40/17 rear, BFG Rivals. I didn't think this setup made my car understeer despite people telling me it would. 235 in the rear only should be fine I'd think, I may even try this this weekend. The car is much more fun to drive with less grippy tires. Again, part of why I think the grip of the RE71R makes this car kind of brainless to drive quickly.
#3650 | |
Drives: '14 FRS TT5
And I definitely understand what you mean. Even though it was "slower" on stock tires, it was a blast to drive. I do agree that this car is brainless/easy to drive quickly, however I think that makes the whole field much more competitive and tightly spaced. I think in order to take a win, the driver is going to need to be spot-on with every steering input, throttle lift, braking point, etc. It may be easy to drive fast, but I think it will be tough to win. For comparison sake, my ~400whp STI was tougher(?) to drive fast, but it covered up my mistakes. With that car, it was about throttle management and braking as late as possible into each turn. In the FRS, there is still throttle management, but instead of "how much throttle can I give it"...it becomes "how long can I hold full throttle, and lift as little as possible." And don't touch the brake unless you need weight transfer! If you want more of a challenge, perhaps a CSP FR-S? Might cost a few pennies though. Otherwise the C5 Z06 has double the hp, is still competitive in AS, and should be a hair tougher to drive fast
#3651 |
Drives: 2013 FRS
Yes, this is funny (not haha funny though). I also landed at 1/2 turn from full stiff front and 1/4 turn from full stiff rear, though I do tweak the rear on occasion depending on pavement type.
#3652 |
The Stig's German cousin
If that's working for you guys, great. But when we dyno'd my Konis we started at full soft, and after seeing the graph at halfway to full stiff we said "yep, we've seen enough here" and took it off the dyno. I've ran them in that range ever since.
#3653 |
i'm sorry, what?
Drives: Canada
^have you ever dynoed any bilsteins to compare?
#3654 |
Drives: '14 FRS TT5
Quick question...no issue with running a harness (like the Schroth Rallye 3) in Street class, correct? Is anyone running a harness? I've had harnesses in my last two cars and I kind of miss it.
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
