Old 08-11-2015, 10:26 PM   #15
wireman957
wireman957's Avatar
Drives: 2015 FR-S MT Steel
I realize I'm a newcomer here, but I am a journeyman electrician for the last 22 years. The color code standard for DC (direct current) wiring is green=ground, black=negative and any other color (in this case red) = hot, or positive. Hi guys!
Last edited by wireman957; 08-11-2015 at 10:29 PM. Reason: possibly confusing and don't want to be. I like this place.
wireman957 is offline   Reply With Quote
The Following User Says Thank You to wireman957 For This Useful Post:
Ramster (08-13-2015)
Old 08-11-2015, 10:31 PM   #16
So two red wires on one and one on the other. Where does the second red wire go?
Old 08-11-2015, 10:33 PM   #17
F3RGY68
F3RGY68's Avatar
Drives: FR-S 10 Series MT, Honda 919
While ground is normally green, I do know green in the dome light is power while red is a ground for the door switch. Just for future reference, and to say it's not always safe to assume green=ground.
F3RGY68 is offline   Reply With Quote
The Following User Says Thank You to F3RGY68 For This Useful Post:
Tcoat (08-11-2015)
Old 08-11-2015, 10:35 PM   #18
Also as I said the standard colour system is frequently pitched out in cars.
You wire green as ground on what ever this is from you are in for a rude shock (no pun intended).
Bach415 (08-12-2015)
Old 08-11-2015, 10:44 PM   #19
Originally Posted by timmydatooth View Post
Whats the worse that can happen if i tap into the wrong wire?
Seriously, guessing is the quickest path to failure. If you aren't confident in figuring out how to be certain, find/make a friend who is.
We can only help so much. You have to make that decision.
Old 08-11-2015, 10:46 PM   #20
wireman957
wireman957's Avatar
That's a really good question. In my opinion, if the manufacturer is doing things correctly, the connector would just be like a splice in the red conductor. Kind of like a standard light switch is just an on-off disconnect between power and the base of a light bulb. Looking at this connector, though, that's tough to tell. A continuity tester (or to be redundant from a previous post, a multimeter) would tell if the two red wires are electrically connected inside the connector. Interesting...Tcoat, you are one of the last people on this forum I'd like to piss off and you are the first to respond to my previous post!
It may be, that if the two red conductors are not internally connected, that the other can be connected to negative. Generally speaking, a light bulb will still work if the hot/neutral or positive /negative are reversed. At any rate, the green should definitely be a ground, unless Subaru/Toyota has completely thrown convention out the window.
Last edited by wireman957; 08-11-2015 at 10:58 PM. Reason: I'm brain-dead from a long day at work. Why did I choose now for my first posts?
Tcoat (08-12-2015)
Old 08-11-2015, 10:56 PM   #21
wireman957
wireman957's Avatar
Okay, wow...I'm smiling big-time. You show a Lucas chart. Years ago, I owned a '57 MGA with Lucas Electricals. There is a reason Lucas was called the Prince Of Darkness. Like I said, in agreement with an earlier post, the best way to tell which is the positive wire is with a multimeter. Check between two wires and when the switch is on figure out which two wires give you a reading of approximately positive 12V. That should show you which is the + wire and which is the - wire. Ground shouldn't even be an issue.
The Following 2 Users Say Thank You to wireman957 For This Useful Post:
S84kam (08-12-2015), Tcoat (08-12-2015)
Old 08-12-2015, 06:53 AM   #22
Dude I wasn't pissed off. It was a real question. It is just way to easy to read everything as sarcasm or mad. I totally agree with your statement that those are the colours for standard for DC wiring but learned the hard way several times that wiring harnesses sometimes (not always) deviate from that standard and wiring by trial and error has nasty results.
Old 08-12-2015, 08:31 AM   #23
wireman957
wireman957's Avatar
I didn't think you were pissed off. Just that I don't want to piss you off. You have a wicked sense of humor and sarcasm from what I've read before posting. And you're absolutely right about wire color conventions going out the window in auto wiring. I've run into situations where I could swear the manufacturer just used whatever color wire happened to be laying around that day. In the fore-mentioned MGA, add that to the fact the system was 12V positive ground and it could REALLY mess you up. I can't see the previous posts right now, but the one that first suggested using a multimeter was right on. They can be had cheap and are worth every penny when trying to trace circuitry.
Edit: In fact, black, being (supposedly) negative should be the normal ground in these cars, so green could very possibly be another positive wire for some function.
Tcoat (08-12-2015)
Old 08-12-2015, 10:44 AM   #24
Hmmmm somebody that actually reads before posting I think we will get along just fine. And don't worry I get over being pissed off fast and some of the guys that pissed me off the worst are now my best cyber buds.
@timmydatooth did you get this figured out yet?
Old 08-12-2015, 11:13 AM   #25
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Hilarious. Tcoat the Internet hitman.
Uh, I was just kidding. Please don't kill my family.
Braces is offline   Reply With Quote
The Following 2 Users Say Thank You to Braces For This Useful Post:
Tcoat (08-12-2015), Ultramaroon (08-13-2015)
Old 08-12-2015, 11:38 AM   #26
http://www.ft86club.com/forums/showthread.php?t=93085
Old 08-12-2015, 02:07 PM   #27
Max FRS
Drives: 2015 Halo FRS Automatic
If you will do a search for "sidemarker", there are posts about making the sidemarker blink and I remember reading one that gave the which color wire in the front signal lights controls run and blink operations. If I remember correctly, the left and right sides have different colored wires doing the same function.
Max FRS is offline   Reply With Quote
Old 08-13-2015, 12:23 AM   #28
Chaetagnath
Drives: Whiteout FRS
Thank you so much! Now while i have your attention guys which one of these wire do i tap in to so that my fogs will be on when i turn on the parking lights? Theres red black and green. I was assuming red but maybe its green...
Probably want to double check with a voltmeter, but I am pretty sure red is turn signal, green is parking light, and black is the ground for both.
Chaetagnath is offline   Reply With Quote
The Following User Says Thank You to Chaetagnath For This Useful Post:
Tcoat (08-13-2015)
How to use the OEM amp Wiring RandomHero Electronics | Audio | NAV | Infotainment 258 07-04-2024 01:34 PM
Wiring in IAT for SD mrk1 Software Tuning 13 04-14-2023 09:15 AM
Wiring for DRL Yap Cosmetic Modification (Interior/Exterior/Lighting) 2 01-19-2015 02:13 AM
LF VA Wiring Help OURO3OROS Mid-Atlantic 0 02-23-2014 09:24 AM
Wiring a sub in a BRZ Shizuma Electronics | Audio | NAV | Infotainment 22 06-08-2013 02:02 PM
