Old 06-01-2012, 02:33 AM   #1
Ishii Motors
Ishii Motors's Avatar
Drives: Scion FRS
DRL Delete DIY
Ok, I hate DRL ( Day time running lights )
So let's turn them off.
It's very simple to do, Just remove the DRL Resistor. Makes the car just that much lighter as well! lol
1. So, access the Front Right Lower panel.
2. Undo the clips and bolt pictured.
(Peel back)
3. Locate DRL Resistor connector
Unplugg and tape up.
4. Remove DRL Resistor
5. Put back together.
Simple.
Ishii
Ishii Motors is offline   Reply With Quote
The Following 12 Users Say Thank You to Ishii Motors For This Useful Post:
chulooz (06-01-2012), civicdrivr (06-01-2012), ESBjiujitsu (06-01-2012), FRSpdDmn (06-06-2012), ft86Fan (06-01-2012), ftc~brz (07-13-2013), Future (06-01-2012), MattR (06-06-2012), rene0023 (05-14-2014), SosaR (05-12-2016), UncleFester (06-22-2012), wdninja (04-01-2013)
Old 06-01-2012, 11:07 AM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I was going to try to figure this out today.... you beat me to it. Thanks for the DIY!
Old 06-01-2012, 11:19 AM   #3
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
I found an easier way for the lazy among us. Go into the fuse panel in the engine bay, pull the big brown fuse that is labelled as 'DRL'. I have been running for weeks without this and it seems to not have affected any other electrics in the car, so it looks like its a dedicated one-purpose-only fuse for the DRL circuit.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
The Following 2 Users Say Thank You to mattles For This Useful Post:
Bullnettles (07-03-2013), Synack (07-16-2012)
Old 06-01-2012, 11:21 AM   #4
DarrenDriven
NW Region Moderator
That is the direction that I was going to go first... Ishii, how did you manage to determine that removing the resistor would accomplish the same thing?
Old 06-01-2012, 11:41 AM   #5
Longhorn248
Hook 'em
Longhorn248's Avatar
Just want to point out that since DRL's are considered a "safety feature", removing them or making them inoperable is technically illegal. With that being said, I don't think anyone will encounter any problems for doing it, just wanted to make everyone aware just in case. Nice pics for the DIY btw.
Longhorn248 is offline   Reply With Quote
Old 06-01-2012, 11:54 AM   #6
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
yeah very interesting you dont like them..... but i guess to each their own. I love day time running lights they save life's!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
The Following 4 Users Say Thank You to ESBjiujitsu For This Useful Post:
jrodz09 (02-11-2013), Rossman (07-15-2012), sroby (03-24-2019), zoth (05-13-2015)
Old 06-01-2012, 01:13 PM   #7
dsgerbc
Drives: BRZ(sold), STI
I can understand disabling them when DRL uses either low or high beam bulb, when it's a standalone system - I'm gonna keep'em. Thanks for the guide anyway.
Old 06-01-2012, 01:20 PM   #8
Ishii Motors
Drives: Scion FRS
The title of the thread is DRL Delete so this is should be considered a permanent cancellation of the DRL.
The DRL system operates the high beams at a lower voltage via a resistor.
The system has a DRL Relay which changes the path to ground for the high beam bulbs.
In a static state the ground is through the resistor. Then when high beam operation is requested it changes to a direct path to ground.
Removing the resistor eliminates the path to ground for the high beam bulbs to run at a DRL power level.
Ishii
Old 06-01-2012, 01:22 PM   #9
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Depends where you are. In many states DRL are not a requirement, and the ability to turn them off is built into the car or can be done via computer. In fact Toyota sometimes even posts DRL disabling instructions similar to this on TIS occasionally.
In some places disabling DRL's is not legal (like in Canada), but in many places it is perfectly fine.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 06-01-2012, 01:23 PM   #10
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
DRLs lower your insurance rates because they make it less likely for someone to hit you. I also never see them. I'm going to keep them.
Don't shop, adopt!
Brett is offline   Reply With Quote
Old 06-01-2012, 01:44 PM   #11
DarrenDriven
NW Region Moderator
Ishii, that was a clever way of doing the delete. In all fairness, most people will probably just pull the fuse, but your method will save weight, too. I'll probably pull my resistor today.
DRLs are mandatory in Canada, but not here the US. I don't like the yellowed, dim, cross-eyed headlight look so those are going... plus I'm going to convert my high-beams to HID so the DRL feature wouldn't work anyway.
Old 06-01-2012, 02:02 PM   #12
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Cool beans, Im not a fan of DRLs either. Safety feature, shmefty feature; lights on when the suns up looks dumb.
chulooz is offline   Reply With Quote
Old 06-01-2012, 02:07 PM   #13
Jeff Lange
Jeff Lange's Avatar
When every car on the road has it, you get used to it, so around here, it looks weird when you see a car without DRL, lol.
Jeff
Old 06-01-2012, 02:11 PM   #14
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
I'm assuming this is for the FRS since the BRZ uses the LEDs for DRL?
There are plenty of studies that show DRL implementation dropping multiple car accidents (2 people involved, not indicating 3+) by 10-30%! http://www.ibiblio.org/rdu/DRLs/studies.htm
I know it might not look "cool" but the facts surrounding the use of them are hard to argue against.
Superhatch is offline   Reply With Quote
The Following 2 Users Say Thank You to Superhatch For This Useful Post:
86WRX (07-03-2013), Fast_Freddy (06-29-2013)
