Old 08-05-2015, 09:08 AM   #15
ajc209
Drives: GT86 Cosworth
ppppssssssttttttt Racecomp
Here in Europe Ohlins are selling the dampers without top mounts for a reduced fee.... any chance of a set of rears to match the fronts?
ajc209 is offline   Reply With Quote
Old 08-05-2015, 10:36 AM   #16
toast
Drives: 14 BSP Edelbrock BRZ
Since there isn't a rubber cap where the spring contacts the plate I'm guessing these will increase NVH?
toast is offline   Reply With Quote
Old 08-05-2015, 02:00 PM   #17
Racecomp Engineering
Originally Posted by yomny View Post
Great to have alternatives, these will be made to fit most coilovers systems out there or st/kw or oem?
Tested on OEM and KW/ST/RCE.
Should be fine with brands that use that same thread pitch/diameter. We will likely do special orders for others but have not worked out price or timing.
With a very high quality bearing the increase in NVH is minimal.
Yes stock is best for NVH but these will be quiet and smooth for a long time.
At the moment, no. We have had a few one-off production ready rear mounts, but our production capacity (all in North America ) is limited so we're focusing on fronts. For now. We are very much thinking about it though and may even incorporate a few neat features. Contact us if you're interested.
- Andrew
wparsons (08-05-2015), yomny (08-05-2015)
Old 08-05-2015, 03:51 PM   #18
Pat
Pat's Avatar
Drives: 2023 BRZ
I don't know much about camber plates. It seems to me other plates are specifically for OEM or certain brands of coilovers. Can you explain to me:
1. How does this plate accept both OEM and KW coilovers when others cannot?
2. Are there sacrifices made or compromises of design to ensure this flexibility?
Thanks!
Old 08-05-2015, 04:23 PM   #19
fika84
fika84's Avatar
Originally Posted by FrX View Post
The gear/adjustment mechanism is pretty spiffy.
^^ This. Great design @Racecomp Engineering
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
Racecomp Engineering (08-05-2015)
Old 08-05-2015, 05:33 PM   #20
Thanks!
1. OEM and KW/ST/RCE use the same thread pitch and our included spring perch bushing (aka conical washer) works for both as well. With the KWs you would use the upper spring perch from the coilovers. AFAIK these would work on Ohlins and Bilstein as well.
2. Nope. Some camber plates come with a fancy upper spring perch with roller bearing type option at a much higher cost, but with proper installation and a good quality main bearing this isn't usually needed.
We've been making camber plates for Subarus since 2005.
- Andrew
Old 08-05-2015, 05:38 PM   #21
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
@Racecomp Engineering Andy No specs on the maximum camber adjustment range, yet?
Intent > Content
Old 08-05-2015, 06:10 PM   #22
Approx -3.2 on MOST set-ups.
On RCE T2s (and KW/ST) you can get more...honestly a TON with the plates and the slotted lower mount. More than anyone should need.
- Andrew
Pat (08-05-2015), solidONE (08-05-2015)
Old 08-05-2015, 06:21 PM   #23
solidONE
solidONE's Avatar
- Andrew
I mean just the adjustment on the plates. Most adjustable tops on the market add about -1.5* on top of whatever the strut mounts offer.
For instance, a stock strut with -.5 built in coupled with a adjustable top offering -1.5 of adjustment will end up with -2.0* maxed out.
The geared adjuster is a pretty awesome idea. I had an alignment tech ding up my top plates trying to get to the camber specs I asked for. So you can say I'm looking at replacement options.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Old 08-05-2015, 07:06 PM   #24
Gotcha. In that case you'd gain approx -2.5 to -3.0 degrees.
- Andrew
Old 08-05-2015, 07:37 PM   #25
Pat
Pat's Avatar
Drives: 2023 BRZ
- Andrew
Thanks for the info, Andrew. I've heard good things about RCE's camber plates for other models. They certainly have a good reputation.
That said, I likely have higher expectations than many people. I typically put 20,000+ miles on my car every year, including ten to 15 track days. Also, I live in Colorado and drive the car year-round.
When I modify my car, I want to do it once and do it well. I don't want to have to worry about servicing aftermarket parts on a regular basis. I have heard of people rebuilding (?) camber plates every couple years due to NVH that creeps in.
Given how and where I drive my car, what should I expect for service intervals on camber plates? If you have any wisdom to share with me I'm all ears.
Old 08-05-2015, 09:22 PM   #26
djliquidsteele
Drives: Scion FR-S
Is the caster fixed or adjustable?
djliquidsteele is offline   Reply With Quote
Old 08-05-2015, 09:52 PM   #27
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Another beautiful camber plate design from RCE. These and the original GD Subaru plates look amazing, and work just as well. They look like pieces you'd see as one-offs on someone's big $$$ custom build. I had a set of their lowering plates on my '07 STI. The camber adjustment was silky smooth and never bound up.
Looks adjustable via those gold "keys".
The Following User Says Thank You to Draco-REX For This Useful Post:
Racecomp Engineering (08-06-2015)
Old 08-05-2015, 10:31 PM   #28
wparsons
wparsons's Avatar
That's the camber adjustment, caster would require sliding the whole upper mount forward or backwards.
flickr
Dominant Engineering Custom Bc Coil Camber plates and rear Uca/Upper Control Arms thatcosta Canada Classifieds 2 04-23-2015 12:49 PM
GC Camber Plates and Robispec Street Rear Tophats ReThink Brakes, Suspension, Chassis 0 10-01-2014 11:06 PM
-0.5 for RaceComp Engineering wrxneffect User/Vendor/Sponsor Reviews, Feedback, Comments 3 03-04-2014 05:21 PM
megan racing street series coilovers w/front camber plates 256brz2013 Brakes, Suspension, Chassis 33 07-01-2013 10:39 AM
Racecomp Engineering industrial User/Vendor/Sponsor Reviews, Feedback, Comments 0 05-02-2013 05:17 PM
