#239 |
Drives: 2014 86 GT
#240 |
Drives: 2014 86 GT
Flashed the v80 A01G E85 rom with EL AVCS tables on my stock 86
here's a 3rd gear pull http://www.datazap.me/u/almando/oft-...om=16350-16482 rich after 3.8v but ok elsewhere? Should I use the type 2 "AT2" MAF scale? |
#241 | |
Drives: Toyota 86 GTS
Multiply 3.91 and above by 0.99. That will get you close to 12.0 With headers it likely wouldn't run rich like that, so when you get headers, go back to my default MAF scale. |
#242 |
Drives: 2014 86 GT
Awesome. Thanks Wayno
Sent from my SM-G900I using Tapatalk |
#243 |
Good on your for having a go yourself. Fellow Queenslander.
#244 |
Drives: 2014 86 GT
Here's a pull with the MAF changes.
For some reason it is richer everywhere. Did I not give it long enough to learn fuel trims properly? http://datazap.me/u/almando/e85-oft-...zoom=3722-3916 |
#245 |
Drives: FR-S 10 #103 AT
@Wayno @steve99
I'm curious how the new values in the O2 sensor scale were determined. Not only were the values changed, the scale itself was significantly altered. I'm mostly curious about the reference scale changes.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#246 | |
http://www.ft86club.com/forums/showthread.php?t=82875
#247 |
Drives: FT86
yes as above ztan rescaled stock o2 sensor using an aftermarket widenband as the reference
#248 | |
You must have an extremely high E content at your station (Doonan, Hearvey Bay, Gladstone?). For my testing all year I've had LTFT of 0 +- 1 with that scale on United E85 from Bald Hills.
#249 |
Drives: 2014 86 GT
Thanks Wayno. Will wait till the trims improve before I do my next pull. Getting my E85 at Doonan.
Loving the power gains btw, do headers get you much more? Do you recommend EL or UEL? Sent from my SM-G900I using Tapatalk |
#250 |
See Australian dyno thread for what uel vs el looks like on oft.
#251 | |
Drives: FT86
below is a reasonable representation of where the differences are that was with stock tune, with tune it just all moves up maybe 10hp ![]() another comparision here http://blog.vittuned.com/just-a-coup...-vs-tomei-uel/ thats on USA petrol which is far better than ours. our crap petrol newters the gains you get, hence great results with E85 . |
#252 |
All right, I'm confused again.
I'm looking at the changed tables and I find the one for requested torque. The two axis are RPM and some representation of the ECU requested torque. The result in the field is the required Throttle Angle. What has me scratching my head is the Requested Torque. There are multiple columns with the same value?!?!? Which one does the ECU use? It makes no sense to me. Can someone explain this set of values? Remember, this is not the first row of data, it's the lookup value across the top. This isn't a change Wayno made, it's in the Openflash tune as well. [Selection1D] 0.0 0.0 0.0 0.0 0.0 0.1 0.1 0.2 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0.9 1.0 1.0 1.0 1.0
| Help uploading 2.06 tunes to OFT | Jimmy817 | Software Tuning | 3 | 12-28-2014 09:06 PM |
| Custom Az Tunes | Juggles | Arizona | 13 | 11-08-2014 10:15 AM |
| EcuTek Tunes | Rio | Engine, Exhaust, Transmission | 1 | 04-29-2014 12:10 AM |
| How long until *other tunes? | ScionFrsFan | Engine, Exhaust, Transmission | 61 | 12-07-2012 05:34 PM |
| Speedhunters - TRD TUNES THE 86 | quik1987 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 69 | 05-22-2012 04:26 PM |
