Old 07-30-2015, 11:38 AM   #15
Zoik
Drives: 2013 black gt86
i need a set of winter tires for the mountains around here (french alps) for 1 to 2 months for the really low temperature period. I would like to go the 205/55r16 route to get more traction
Can anybody tell me if 16" steelies from a Forester S will fit the gt86?
Zoik is offline   Reply With Quote
Old 07-30-2015, 11:54 AM   #16
Timmy_Jones
Spun
Drives: 23' Supra
I have some cheap Motegi 16s and Blizzack WS70s for winter. No problems last winter (yeah, near record fall snow amounts here in Maine). I kind of like the look of a 16" wheel on these cars, too.
Timmy_Jones is offline   Reply With Quote
Old 07-30-2015, 11:59 AM   #17
Bergen23
Drives: '15 Halo FR-S
As long as the bolt pattern is the same, I don't see why not. Not sure of the offset on them either, but I think it should be ok as well. Worst case, you'll need some spacers.
Personally, I just used the OEM wheels, although I should have went with a slightly narrower tire than a 215
Bergen23 is offline   Reply With Quote
Old 07-30-2015, 12:01 PM   #18
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
The 16" steels that TireRack supplies are ET50, which is only a 2mm difference from the stock ET48. The extra sidewall and skinnier cross section of a 205/55-16 makes the winters much smoother riding, and they'll dig in a bit better than a 215/45-17 would, although I bet you'd be had pressed to tell the difference in traction with the same tire brand/model. Ride quality definitely goes up though, which is nice in the winter.
15 inch rims for winter? CBR600RR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 08-12-2023 05:42 PM
Poll: Winter Tires and Rims FRiSson New England 47 12-08-2012 04:15 PM
Winter Rims RandomHero Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-05-2012 09:06 PM
Winter Tires and 17" Rims?? stalon320 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-03-2012 09:33 AM
Cheap winter alloy rims Sport-Tech CANADA 52 04-18-2012 11:30 PM
