Old 07-29-2015, 04:00 PM   #939
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Originally Posted by Vracer111 View Post
But then an 86 and Mustang got married and had offspring:
Why do I get the feeling this will handle poorly!
SUB-FT86 is offline   Reply With Quote
Old 07-29-2015, 06:29 PM   #940
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Back lights are ugly. And there's too many 'racers' switching from FRS and 370z for mustang's here. It's 7/10 for me in terms of looks and a car I'd buy, but still not right for my garage.
Old 07-29-2015, 06:47 PM   #941
Bergen23
Drives: '15 Halo FR-S
Reading through this thread is icing on the cake for me. I'm looking to trade my FR-S in for an Ecoboost next summer
Will be following this for future updates
Bergen23 is offline   Reply With Quote
The Following 3 Users Say Thank You to Bergen23 For This Useful Post:
drewbot (08-06-2015), MAPerformance (07-30-2015), raven1231 (08-06-2015)
Old 07-29-2015, 06:56 PM   #942
jdmblood
jdmblood's Avatar
Drives: white subaru brz
Holy shit 500whp for a 4 cylinder is impressive. that mustang must move.
keep up the good work.
jdmblood is offline   Reply With Quote
The Following User Says Thank You to jdmblood For This Useful Post:
Old 07-29-2015, 08:12 PM   #943
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
Can't wait till they send Chris Harris a GT350R to review.
P@ul is offline   Reply With Quote
Old 07-30-2015, 10:34 AM   #944
M1K3
M1K3's Avatar
Drives: vrooom...
Now that's what I want to see!!!
M1K3 is offline   Reply With Quote
Old 07-30-2015, 01:25 PM   #945
MAPerformance
Drives: Asphalt FRS
Be sure to hit me up! I will take care of you on pricing
MAPerformance is offline   Reply With Quote
The Following 2 Users Say Thank You to MAPerformance For This Useful Post:
Bergen23 (07-30-2015), raven1231 (07-30-2015)
Old 07-30-2015, 05:41 PM   #946
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
curious as to wonder what that slight dip is at 4.5k? possible fuel hiccup?
Old 07-30-2015, 08:21 PM   #947
Bergen23
Just finished up reading this thread in more detail, and hooooooooly cow. It has pushed me that extra notch to go this route. Even doing a part out of my car now . Hook a brother up with a discount on your stuff and I'll spread the word for you guys up in the great white north
The Following User Says Thank You to Bergen23 For This Useful Post:
raven1231 (07-31-2015)
Old 07-31-2015, 11:43 AM   #948
MAPerformance
Drives: Asphalt FRS
Pretty exciting man! You will really like the car once you mod it. I will make sure to hook you up sir. We can discuss some options when you are ready Just wait until we get our built engine in, a 6766, and turn it up!
Bergen23 (07-31-2015), raven1231 (07-31-2015)
Old 07-31-2015, 02:25 PM   #949
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
I had no idea this platform was so robust. Subbed. 2015 Ford Supra?
xxBrun0xx is offline   Reply With Quote
Old 08-04-2015, 01:36 PM   #950
MAPerformance
Drives: Asphalt FRS
Well, as most of you know we have been hard at work developing cylinder heads, fuel system upgrades, and built shortblocks. All these products are finally coming together and we are getting closer and closer to the testing phases. I will be using this thread to update, as often as possible, our quest for a 700whp, 10 second Ecoboost Mustang.
If you haven't seen our Ecoboost Cylinder Head development thread, I highly suggest you head on over there and have a read. Some really good information over there, and good results. Here is a quick glimpse:
*the surface isn't decked that is how it comes from Ford. We don't deck until we are ready for final assembly*
Now, lets go over what that chuck of ported aluminum is going to be going on. We have been working with Darton for custom sleeves for the 2.3 block over the past month. After 3 revisions we finally settled on a set of sleeves that are going to work for our application. I won't be sharing pictures of the sleeves themselves or the block until it is ready for assembly. Once full machining is done, cleaned, and ready I will get you pictures of under, in, and around the block. For now, we need to keep it underwraps!
Pistons. These play a key part in our quest, so they needed to be exactly what we wanted. JE Pistons delivered, and delivered well. We opted for a full custom piston instead of an off the shelf solution, as off the shelf pistons weren't available in our configuration.
Specs:
  • 10:1 Compression
  • True Asymmetrical Design
  • 9310 Wrist Pins
  • Ceramic Coated crown
  • Skirt coating
  • Forced Pin Oiling
  • Provisioned for +1mm valves and higher lift
As you can see in the picture above we kept the factory style fuel cavity in the piston crown for concentrated burn. It has been radiused (radiis) out to eliminate hard edges for potential hot spots, which also offset the compression that was increased when we lessened the volume of the outer crown dish. On the factory piston there was a "moat" style edge just before the edge of the piston. This was another area for hot spot concerns especially because we retained the fuel cavity. We had the depth of the moat decreased a few cc's to help. Also assisting in hot spot protection is the crown coating (light gray film in pictures). Whatever steps I can take to prevent detonation during tuning at this power level, is going to be performed.
This image has been resized. Click this bar to view the full image. The original image is sized 1200x575.
Here you can see the rest of our internal selections. Starting from the top left and moving down, then finishing on the right. Here is the list of components:
  • Pistons
  • Timing gear for pinned crank
  • Balance shaft delete kit
  • Piston rings
  • Tri-metal race bearings
  • Wrist pins
  • I-beam Rods
The timing gear in the picture is a custom piece from a company in IL we collaborated with. We shipped them our crank and they pinned it and provided us the new timing gear, key way, and balance shaft components. The bearings are from King, which we use in every engine that leaves our shop. Last but not least we come to the rods. These are off the shelf I-beam rods from Manley that we lightly machined to provide desired bearing clearance. The engine will go through our normal machining process which is 100% done in our facility. Having all the machines to machine, clean, and assemble our own engines cuts down significantly on time, and allows us to have full control of our quality. We have very high standards when it comes to our shortblock offerings, and we couldn't trust anybody to provide the same level of detail.
This image has been resized. Click this bar to view the full image. The original image is sized 1000x563.
This image has been resized. Click this bar to view the full image. The original image is sized 1000x672.
In some cases this means we have to build our own tooling to achieve the final product we desire. What we have above is our custom cylinder head pressure tester plate, and our torque plate which any machinist can purchase from our site. The pressure tester bolts to the cylinder head with a factory Ford MLS head gasket in between and pressurize the combustion chamber to double check our valve machining. This also helps in making sure the sealing surface is optimal, to a point however as we can't replicate the exact combustion scenario the cylinder head will ultimately see during operation. The torque plate is used during the honing process. It simulates the cylinder head being bolted onto the engine so the cylinder walls are in their "stressed state" during machining. If you machine and engine without a torque plate the taper and round of the bore will be distorted once the head is bolted on, which can cause the piston to wall clearance to be off and potentially cause damage.
This image has been resized. Click this bar to view the full image. The original image is sized 1042x625.
Now, we move onto the fuel system. We posted in a few other threads we were working on an Auxiliary fuel supplement system. This isn't ground breaking technology at first glance as it has been around for I would say 20 years now, but when you combine old school technology with new school mentality you get, well...this. A complete plug and play, E85 safe auxiliary fuel system. This very kit we have on our build will be available to you in a painless package. It will include throttle body plate, fuel rail, injectors, fittings, pre-assembled hoses, injector driver software/hardware, and instructions. No modifications to your factory fuel system will be needed, simply disconnect, and reconnect. The system is only running when it is needed, as it is boost activated. We will be offering a baseline E85 tune with the kit, but if you are pushing the factory fuel system with any other fuel the ability to tune it yourself or have us E-tune it is available.
We hope this kit will provide enough fuel to reach our goal, but if not a 4-port injection system is on standby to support over 1000whp. With the ability to swap out injectors on the production throttle body plate from 580cc injectors up to 2000cc injectors I think big power is going to come easy, and safely. We will have to keep an eye out for any fuel puddling symptoms if we have to increase injector size. However, I think with our injector angle design, and our atomization strategy we shouldn't run into any issues if we bump up to 2x 1000cc injectors. Time and testing will tell!
The next update will revolve around our suspension, wheels and tires, and driveline upgrades. We have some items on the way, so expect an update soon!
The Following 6 Users Say Thank You to MAPerformance For This Useful Post:
Calum (08-05-2015), DAEMANO (08-04-2015), funwheeldrive (08-04-2015), Noble713 (08-14-2015), roddy (08-05-2015), ScoobsMcGee (08-04-2015)
Old 08-04-2015, 06:27 PM   #951
MAPerformance
Drives: Asphalt FRS
Well, it happened...The stock engine has finally let go. I don't know details as of yet, but I do know fire was involved I will keep you updated as I find out more info. Time to throw our built block in!
The Following 5 Users Say Thank You to MAPerformance For This Useful Post:
bumppinKota (08-04-2015), DAEMANO (08-04-2015), kch (08-05-2015), roddy (08-05-2015), ScoobsMcGee (08-06-2015)
Old 08-05-2015, 07:56 PM   #952
MAPerformance
Drives: Asphalt FRS
So sadly it wasn't that actual engine that hit it's weak point unfortunately. We were messing around with external throttle body injectors controlled by a separate fuel box which failed to shut off the fuel during a dyno run and actually caused it to hydro lock itself, causing a rod to escape. Oh well, these things happen in testing.
The Following User Says Thank You to MAPerformance For This Useful Post:
Calum (08-05-2015)
2015, couldhavehadav8, ecoboost, ford, mustang
Mustang at it again! (Shelby GT350) FX86 Off-Topic Lounge [WARNING: NO POLITICS] 18 10-26-2016 09:46 PM
2013 Mustang GT or wait for 2015 Mustang GT or new model 370Z (390Z)...??? JayNutter Other Vehicles & General Automotive Discussions 48 01-13-2013 11:03 PM
1966 Ford Mustang T-5R Wes B. Other Vehicles & General Automotive Discussions 33 12-11-2012 10:38 PM
2011 Shelby Mustang Enhancement Detail OTD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 05-24-2012 07:24 PM
Your thoughts of the Ford Mustang Abflug Other Vehicles & General Automotive Discussions 31 08-25-2011 11:15 AM
