Old 07-26-2015, 10:41 PM   #15
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
get some instant detailer spray and use that before using a clay bar. clay will give you swirl marks. when all is said and done get your car paint protected with Opticoat Pro.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 07-26-2015, 11:58 PM   #16
Originally Posted by WhiteFRS69 View Post
i would start off with little to no pressure at all,
IMO get some polish instead, wont cause any damange to the paint (I.E. Swirls) like clay bar will, but than again, its a new car so im sure the paint isnt that contaminated
start off with little to no pressure with the clay bar and just make sure the surface is well lubricated, dont use regular water, use a quick detailer or a dessinated clay bar lub
The only reason I recommend clay bar is in case the mark is a residue of some kind. May wipe off with some polish but will come off for sure with a clay bar if it is a mark made by plastic or something that left a film.
Old 07-27-2015, 12:17 AM   #17
Hotrodheart
Hotrodheart's Avatar
Originally Posted by Devante View Post
Took my week old FRS to get tinted yesterday.
They messed up my paint.
I washed it the night before. Woke up in the morning and didn't notice anything. Took it in to get tinted and picked it up and as soon as I got home, I saw this white, hazy line in the driver's back fender. I tried to wash it again this morning and it didn't go away.
They also put a few divets in the rubber trim on the roof on both sides.
I'll probably talk to them tomorrow.
Do tint places used any kind of chemical that may have caused this? I noticed there was a lot of dried spray all over my paint. I assumed it was water.
Also, what can I do about the damage? How can I/they/someone get rid of this line? I have pictures but the best way I can explain it is kind of a milky white line with maybe some light milky haze around it.
Also, I'm not sure how to handle the tint place. I mean it's really my word against theirs if they don't take responsibility for it.
Thanks for any advice.
Calmly walk in, state your complaint, and open fire.
Hotrodheart is offline   Reply With Quote
Old 07-27-2015, 01:17 AM   #18
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Bummer. Heat gun/torch damage? Somehow? Have you tried to apply any type of paste or 'stuff' to get it out?
For anyone taking their car in for repair/check up etc... who gives a sh!t about it (because I know some people dont care because they are rich as hell and others see the twins as worthless), I recommend to always photograph their car in front of whomever they are delivering the keys to. 4 pics can be enough. Even welfare dependent peeps get a free phone nowadays. No excuse. Not that it'll fix any issue that may arise, but it will offer for a basis of argument.
Old 07-27-2015, 01:46 AM   #19
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Take it to a professional detailer. To see if they can correct it. Looks more like a paint defect.
Instagram: stimson
Old 07-27-2015, 02:15 AM   #20
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
What clay are you using clay should not leave marks if used properly.
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
Tcoat (07-27-2015)
Old 07-27-2015, 09:33 AM   #21
stevesnj
stevesnj's Avatar
Take it to a body shop and have them take a look.
My 2016 Build thread
Old 07-27-2015, 09:52 AM   #22
Demandred7
Demandred7's Avatar
Drives: 2018 Camry XSE V6
Sometimes WD40 works wonders on residue and shouldn't harm the paint.
Demandred7 is offline   Reply With Quote
Old 07-27-2015, 10:30 AM   #23
Shady195
Drives: '13 10 Series FRS #1203
I see it, dones't look like a scratch at all, looks like residue of some sort.
Clay bar/Polish should get rid of it. Almost wondering if its just soap/water that somehow got there and left, could leave a milky haze like that depending on what they used.
Shady195 is offline   Reply With Quote
Old 08-12-2015, 08:39 PM   #24
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
bump
Just noticed that same mark on the passenger side. Really weird that I have just noticed it for the 1st time and I've had the car for 2yrs.
sprintertrueno86 is offline   Reply With Quote
Old 08-12-2015, 08:53 PM   #25
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
Originally Posted by sprintertrueno86 View Post
bump
What color is yours?
Devante is offline   Reply With Quote
Old 08-12-2015, 09:02 PM   #26
sprintertrueno86
Drives: 2018 BMW M2
WRB and my car is opticoated for 2yrs as well so the mark was there all along....or somehow it just suddenly showed up.
Old 08-12-2015, 09:42 PM   #27
Devante
Devante's Avatar
Sorry I'm dumb. I can't figure out what WRB is.
Siiiiiiiiiiiigh ok I didn't want to admit this but I will because I don't want you stressing out over this.
Mine turned out to be a reflection. YES A REFLECTION.
Somehow the sun hits that part of above the fender where it curves in just right at certain parts of the day and makes it look exactly like in my pictures and video.
If you shield the area from the sun, it won't change the 'mark' at all. No matter where you stand, the mark doesn't change shape or anything.
However, if you put your hand riiiiiiiight against that concave section, you'll block the reflection.
It's the strangest reflection I've ever seen but it's just the sun.
Sorry for all the wasted time guys.
By the way, once I found this out accidentally, not only did I test it by blocking the concave area but I turned my car around and got the same mark on the opposite side. Literally the same shape and length.
Tldr: it was just the sun.
The Following User Says Thank You to Devante For This Useful Post:
sprintertrueno86 (08-12-2015)
Old 08-12-2015, 09:44 PM   #28
sprintertrueno86
Drives: 2018 BMW M2
Oh good...that is a strange reflection as it doesn't flow along the fender bulge. It really does looks like a blemish.
NW Tint Shop Directory DarrenDriven Northwest 102 04-17-2018 10:10 PM
tint shop in around Fairfax County incubus1995 Mid-Atlantic 13 04-29-2014 06:38 PM
Tint Shop In GTA ArKiTeCkT CANADA 80 04-24-2013 08:46 PM
Tint Shop crazyprac Mid-Atlantic 12 04-17-2013 09:54 PM
Best Tint Shop in SoCal Jeffboyarrdee Southern California 16 11-10-2012 01:20 PM
