Old 06-16-2015, 10:35 PM   #29
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Sorry for reviving the dead but I need some help. I'm installing sway bars and the end link length is something that always troubles me. I've installed the sway bar with the car on jackstands, all 4 sides. Is this the correct way or must the suspension be loaded at regular ride height to avoid any preload? One of my endlinks is slightly longer than the other in order to not have any preload, why in the world is this so? I have white line adjustable end links btw. if I had not allow the suspension to drop I wouldn't have noticed the end links hit the control arm, the distance isn't the same at full drop as opposed to loaded suspension. Thanks
@Hotchkis
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 07-01-2015, 06:19 PM   #30
cowdog360
Drives: 2014 BRZ Limited
Thanks for the super clear instructions. Did my Perrin 19mm front swaybar in about 2 hours. Just drove it up on ramps, used a jack to raise hte car a little while leaving the tires on the ramps. Honestly, the part that seemed to take the longest was removing and re-installing the two covers.
cowdog360 is offline   Reply With Quote
Old 07-21-2015, 09:12 PM   #31
FutureFT86
FutureFT86's Avatar
Drives: 13 Scion FR-S
@Hotchkis
Good question, i'm wondering this also! Seeing as the only way I can adjust my swaybar is with the car on jackstands I wonder how preloading works with the adjustable endlinks.
FutureFT86 is offline   Reply With Quote
Old 07-22-2015, 12:42 PM   #32
yomny
yomny's Avatar
Do so in jack stands, when the suspension is loaded(car on floor or ramp) the bottom part of the endlink will be farther away from the control arm so you won't know for sure if it hits when suspension droops. i did it on ramps and when I raised the car and put it on jack stands, the endlink hit the control arm, adjusted while on stands once more and it was perfect afterwards. I learned the hard way.
The Following User Says Thank You to yomny For This Useful Post:
FutureFT86 (07-23-2015)
Old 08-29-2015, 02:47 PM   #33
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Maybe I missed it somewhere, but what's the torque specs for the bolts on step 3R? (rear bushing brackets)
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 01-30-2017, 10:27 PM   #34
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
Thanks for this DIY. I installed mine on the weekend. It took longer than expected, but I wouldn't have been able to do it without your instructions and pictures. My first sway bar install done!
Prmspen is offline   Reply With Quote
Old 06-13-2017, 11:37 AM   #35
Cueman
Cueman's Avatar
Drives: In Perfect Control At All Times
I just picked up a rear sway bar to try on my street class auto-xer, and am a bit confused by the bridge plate.
Is there supposed to be a cutout in the chassis side mount for the bridge plate to fit in? I can't find one on my car. The bridge plate doesn't seem to sit flush to anything.
I've currently installed the bar without it... although I noticed that the retaining collars can't sit flush to the bushing because there isn't adequate clearance to chassis mount.
Cueman is offline   Reply With Quote
Old 06-14-2017, 12:34 PM   #36
Nitro22
Nitro22's Avatar
Drives: Scion FR-S (Hot Lava)
The rear mount on the subframe should have a "valley" that the booby on the bridge plate takes up. What year is your car? Do you have any pictures of the mount?
Thanks,
-Aaron
Nitro22 is offline   Reply With Quote
The Following User Says Thank You to Nitro22 For This Useful Post:
Cueman (06-14-2017)
Old 06-14-2017, 02:09 PM   #37
Cueman
Cueman's Avatar
Thanks,
-Aaron
Thanks for your response!
Mine is a 2015, so surely I'm not the first. Odd. I'll take it apart and snap some pics.
Old 06-15-2017, 08:10 PM   #38
Cueman
Cueman's Avatar
Replacing a TRD rear sway bar, I realized I had the TRD reinforcement plate installed. If TRD thought the plate was needed for their bar, it's surely a good idea for the Hotchkis, so I just left it on and put the Hotchkis bridge plate back in the box.
Old 06-15-2017, 09:31 PM   #39
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
I'm planning on installing my front sway bar on my car on Sunday and will be reusing my stock endlinks.
Any tips on loading the front suspension when installing the end links? I'll be working on jackstands so I'm not sure how to proceed. Just don't want any clunking going on. I'm on stock suspension.
ApexEight is offline   Reply With Quote
Old 07-26-2017, 09:27 PM   #40
ApexEight
Does anyone know what thread pitch the 10mm and 12mm skid plate bolts are?
Are the 12mm bolts for the metal skid plate and the 10mm for the transmission one or the opposite?
Thanks!
TRD Door Stabilizer Kit AL008 Australia Classifieds 3 03-17-2013 08:53 PM
FS; TRD DOOR STABILIZER photomike Brakes, Suspension, Chassis 1 03-07-2013 04:05 AM
EOI - TRD Door Stabilizer kit AL008 AUSTRALIA 2 02-28-2013 02:21 AM
TRD Door Stabilizer scioneric Canada Classifieds 15 01-22-2013 08:49 PM
Rear Sway Bar Stabilizer Bracket Bolt replacement? Books Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-19-2012 03:55 PM
