Old 07-06-2015, 08:25 PM   #1
R42o
R42o's Avatar
Drives: Subaru BRZ
Please help - May have added wrong coolant to my BRZ
Hey Guys,
I just bought my certified pre owned BRZ (20k miles) from the dealership on Friday. When I got home I noticed that the coolant was at the low mark in the reservoir. Not thinking anything of it, I filled it with some coolant that I used in my other car that I traded in.
After doing a bit of reading I saw that Subaru uses its own brand of coolant for the BRZ. The manual Says to use Ethylene Glycol based, non silicate, non-anime, non-nitrite, and non-borate. From what I can tell the coolant I added is ethylene glycol based but I don't know about the other chemicals in it (see pictures below).
I'm a bit paranoid because I also read somewhere that if you mix 2 different types of coolant bad things could happen. Do you think I will be ok with the coolant I added, or should I have it flushed and replaced with the genuine Subaru coolant?
subaru manual
http://www.joomag.com/magazine/subar...10946?page=302
upload pic
R42o is offline   Reply With Quote
Old 07-06-2015, 08:56 PM   #2
Lelantas
Lelantas's Avatar
Drives: '15 BRZ ISM
Generally speaking you should avoid mixing different coolant formulations (usually indicated by different colors), as that decreases the overall lifetime of the coolant.
Seeing as you've already added it though, I wouldn't worry about it. I doubt there'd be any seriously harmful effects (ie precipitates, etc).
For the future, get yourself a jug of Subaru Super Coolant (blue in color). Best price when I bought it was on Amazon.
Lelantas is offline   Reply With Quote
Old 07-06-2015, 10:20 PM   #3
mhughett
Drives: 2015 Crystal White BRZ Limited
I have read that there are basically 3 types of coolant on the market:
1. Inorganic Acid Technology (IAT) which is the "old school" prestone type
2. Organic Acid Technology (OAT) which is the DexCool/VW style
3. Hybrid Organic Acid Technology (HOAT)--this is used by most Asian and European cars, including Subaru
The following was from Popular Mechanics as to whether you can add DexCool to other types of coolant.
Can you mix DEX-COOL™ with other antifreeze products?
Improper mixing of coolants has the potential to cause corrosion issues. Valvoline recommends using the correct antifreeze/coolant for your particular application.
- See more at: http://www.valvoline.com/faq#sthash.soU7pPm6.dpuf
You should never mix DexCool with a HOAT or IAT type coolant.
mhughett is offline   Reply With Quote
Old 07-06-2015, 10:25 PM   #4
nocwage
MMTT
Drives: 2019 Subaru BRZ
Mostly what I have read is that if you mix regular coolant with the super blue you should not expect it to last the 100,000km of the blue and need to change it at regular coolant interval until you go back 100% to super blue.
nocwage is offline   Reply With Quote
Old 07-06-2015, 10:36 PM   #5
stevesnj
stevesnj's Avatar
Drain and flush with distilled water ASAP
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
humfrz (07-07-2015)
Old 07-06-2015, 10:43 PM   #6
raven1231
Nobody knows! So far you learned- its okay, flush it, just change it sooner, it will corrode your engine and I'm sure many more contradicting answers are on the way!
Tcoat (07-09-2015)
Old 07-06-2015, 10:51 PM   #7
R42o
R42o's Avatar
Drives: Subaru BRZ
I guess I'd better play it safe and just get it flushed. Being that I bought this car "certified pre owned" from the dealership, you would think they would check all fluid levels for me before it left the lot. Oh well, live and learn I guess
Old 07-07-2015, 12:39 AM   #8
I suggest you drain, flush and re fill with the recommended coolant.
Why?
So you won't worry about it anymore ........
Humfrz
Tcoat (07-09-2015)
Old 07-07-2015, 01:00 AM   #9
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
Why?
Humfrz
Humfrz has got it.
Being cautious type, I'd recommend you heed his advice. Besides, you've just mixed chemicals together, no one really knows exactly what's going to happen.
Bobblehead is offline   Reply With Quote
Old 07-07-2015, 11:50 PM   #10
OmarYasin
OmarYasin's Avatar
Yeah dexcool is orange stuff normally used in General Motors. I would highly suggest having a shop do a full coolant and engine flush. Once u mix coolants that dont mix they dent to gel or solidify.
Sent from my LGMS323 using Tapatalk
OmarYasin is offline   Reply With Quote
The Following User Says Thank You to OmarYasin For This Useful Post:
Abenaki (07-09-2015)
Old 07-07-2015, 11:51 PM   #11
OmarYasin
OmarYasin's Avatar
There is certain coolants u can mix. Like g05 and the red/violet color but not sure on orange and blue
Old 07-09-2015, 10:56 AM   #12
mhughett
Despite being a different color (yellow), the Zerex G05 coolant is actually very similar to the BMW and Subaru coolants. Both use HOAT technology and have nearly identical spec's. They are very different from the orange Dex-Cool coolants used by GM and VW.
antifreeze, coolant, help me
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
BRZ,STI and WRX added to VIP Program TurboBrett BRZ First-Gen (2012+) — General Topics 97 09-23-2013 02:59 PM
Crutchfield added FRS/BRZ Roundabout Electronics | Audio | NAV | Infotainment 1 03-01-2013 10:01 PM
Added sub... raphymartinez Electronics | Audio | NAV | Infotainment 4 06-25-2012 09:59 PM
anyone added nav to an fr-s? ssmtsx Electronics | Audio | NAV | Infotainment 10 06-12-2012 11:11 PM
