Old 07-03-2015, 02:45 PM   #1
mstoochn
Drives: 2015 WR Blue Sport Tech BRZ
Drivetrain chatter decellerating - 2015 brz M/T
Hello,
I've started a new job recently and every morning I drive into under ground parking, I find when I am driving down the ramp in 2nd gear doing (18-25kph) i periodically hear.. what I could describe best as perhaps a scratching/grinding noise you might here if you jammed a pop can in the flywheel mixed with a diesel engine.
Is this normal?
Thanks!
2015 WRB BRZ Sport Tech M/T
mstoochn is offline   Reply With Quote
Old 07-03-2015, 03:04 PM   #2
That sums up the noises these cars make pretty accurately I would say.
DustinS (07-03-2015), Wes (07-03-2015)
Old 07-04-2015, 02:53 AM   #3
radroach
Drives: car
Normal. I hear it more when it's cold out, not an issue when it's warm though.
Old 07-04-2015, 03:34 AM   #4
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
yes, normal! Had it checked by dealer. Normal.
Old 07-04-2015, 08:21 AM   #5
alan.chalkley
Drives: 4wd zooks
If i roll down a very steep hill in first or second without applying brakes the manual transmission makes some interesting music.
Perfectly normal for these cars and if i listen carefully my manual corolla makes the same noises , only i think it has more NVH insulation.
alan.chalkley is offline   Reply With Quote
Valvetrain chatter on KW SC FRS nlowell Issues | Warranty | Recalls / TSB 4 05-03-2015 12:20 PM
Flywheel Chatter samisons Issues | Warranty | Recalls / TSB 13 12-05-2014 10:30 AM
Drivetrain chatter on cold mornings? jm1681 Issues | Warranty | Recalls / TSB 7 10-24-2014 11:48 AM
Diff chatter when cold? BRZrkr BRZ First-Gen (2012+) — General Topics 1 06-23-2014 10:17 AM
Odd Chatter Noise? Chrisposey Forced Induction 5 05-05-2014 10:37 PM
