Old 07-01-2015, 06:33 PM   #15
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I have the same issue, my passenger door lamp is always on after doing an LED swap...and I remember accidentally shorting the two pins when removing the old bulb with a flat-head screw driver so I know when and why it occurred.
My car is a 2013 and I'm at 50k miles so I am out of warranty as far as I know. At a cost of ~$400 for a new unit, I am going to remove the bulb on both sides and live without both door lights.
Actually, when I have some time I may re-wire them. The switch in the door jam can be used as a switch to turn the light on and off, eliminating the BIU. I'm pretty sure when the door opens, that door switch creates a ground. I wonder if there are any side affects associated with this issue, or if it is limited to only the light being on all the time.
B-R-Z is offline   Reply With Quote
Old 07-02-2015, 01:09 AM   #16
Poodles
Drives: 2015 Series.Blue
Originally Posted by LED86 View Post
Completely agree! Poor design and no fuse just leads to these problems. I only deal with the full LED lamp units because the bulbs are just too risky on this area of the car.
Honestly, there's probably some safety specification for stuff like this that says it's required to be fused. Years down the road this could be a recall...
Who makes/sells full replacement assemblies?
http://www.fteightysix.com/appearanc.../#.VIAb_It0yUk
I've heard that it's possible to repair the module, but I don't know the details. It would require soldering, but I bet it's quite easy once the issue is found.
The Following 2 Users Say Thank You to Poodles For This Useful Post:
B-R-Z (07-02-2015), jawn (07-02-2015)
Old 07-02-2015, 01:29 AM   #17
ryoma
ryoma's Avatar
wow, it sucks that a simple LED can short out such an expensive unit lol. luckily I didn't run into this problem when I swapped in my LED's. dodged a bullet there
Old 07-02-2015, 09:32 AM   #18
B-R-Z
B-R-Z's Avatar
I think it's a result of shorting from touching the +/- contacts when removing the old bulb. I don't see how a bulb change to led would do this.
If anyone has any info on how to repair the module please share. I'll make a DIY out of it.
Old 07-02-2015, 08:48 PM   #19
B-R-Z
B-R-Z's Avatar
Does anyone know exactly which module it is under the dash? Maybe it's just a blown diode or something simple.
Door Unlock Issue TONYpepperon1 Issues | Warranty | Recalls / TSB 20 01-05-2018 08:06 PM
Need help on door lighting phanguy Electronics | Audio | NAV | Infotainment 18 10-30-2014 12:10 PM
Door lock issue BRZ323 Scion FR-S / Toyota 86 GT86 General Forum 3 04-13-2014 11:07 PM
FS: Cool White LED Lighting (dome, door, and trunk lights) fourvalleys Interior Parts (Incl. Lighting) 0 11-18-2013 07:55 PM
Door Rattle Issue DriftEightSix AUSTRALIA 4 06-28-2012 02:11 AM
