Koji_Online
Old 06-29-2015, 10:25 PM   #603
jelly
Drives: looking for one.. :(
Just did this mod (after 2 weeks of learning stick in this car) and MAN starts are so easy now. Such a simple, great adjustment. The hardest part was honestly figuring out which way the stupid nut turns.
jelly is offline   Reply With Quote
Old 07-01-2015, 07:02 PM   #604
luelanski
Drives: 2014 FRS
Hey all.
I recently removed the clutch spring and adjusted the clutch pedal height right below the brake.
Now I can shift smoother and easier, especially from 1st to 2nd gear.
However, with this set up, I noticed that the clutch pedal has slight play now, while not depressed. If I go under the clutch pedal and push up, it comes up just a little, probably less than 1 centimeter, because the spring is not there anymore to keep the clutch up. I'm worried that the clutch may be "riding itself" because I'm able to lift it up a little when its not depressed.
I did the same with with the brake pedal and the gas pedal and there is no play at all.
Has anyone come across this?
Also, my car is leased. Should I put the spring back in before returning the car?
luelanski is offline   Reply With Quote
Old 07-01-2015, 07:04 PM   #605
mb_
Ex-MR2 owner
Drives: Scion FRS
Did this while I was doing the clutch spring mod. My MR2 had a low engagement point which I missed but now I don't miss it that much anymore!
Originally Posted by luelanski View Post
Hey all.
However, with this set up, I noticed that the clutch pedal has slight play now, while not depressed. If I go under the clutch pedal and push up, it comes up just a little, probably less than 1 centimeter. I'm worried that the clutch may be "riding itself" because I'm able to lift it up a little when its not depressed.
I noticed that there was a little bit of play as well but I took a closer look and came to a conclusion that the spring is what eliminated the play.
As for your leasing situation, I'd put it back if you can but depending on your dealership, I don't think anyone will notice that there's suppose to be a spring there.
mb_ is offline   Reply With Quote
Old 07-01-2015, 07:15 PM   #606
luelanski
Drives: 2014 FRS
thanks, i have been driving it for over a month like this, and i havent had any problems, but i just wanted to clear my head about the clutch play.
can u push up the clutch pedal from the bottom and it moves up ever so slightly?
Old 07-01-2015, 07:49 PM   #607
Never mind the arrow in this picture. I took it from earlier in the thread.
As long as the spherical part I painted green is butted up against the clip on the inside edge of the yellow, you're ok.
If the play is irritating, you can take up some with the cruise cancel switch. Just make sure you don't push in the green part.
keithr (07-10-2015), luelanski (07-10-2015), N234 (12-29-2015)
Old 07-01-2015, 11:09 PM   #608
JB86'd
JB86'd's Avatar
Drives: JAWS
If I'm not mistaken having that freeplay on top of the clutch is good indication that your clutch is not riding itself. I'd be worried if I took the clutch spring out and didn't have that freeplay at the top.
Edit: Nevermind. I realize what you're getting at now. Being able to pull up slightly on the pedal could mean the clutch is slightly engaged. I've done the clutch spring removal and height adjustment, and slave cylinder swap. I can pull up slightly on mine too but I'm almost positive it's normal.
JB86'd is offline   Reply With Quote
The Following 2 Users Say Thank You to JB86'd For This Useful Post:
axelo (08-04-2015), luelanski (07-10-2015)
Old 07-10-2015, 04:33 PM   #609
luelanski
Drives: 2014 FRS
Ive researched and i've come up with the conclusion that you are correct. the spherical part painted green is butted up against the clip on the inside edge of the yellow, so even if I can pull up on the clutch pedal slightly, its not engaged because the spherical part painted green is always sealed completely against the clip on the inside edge of the yellow.
also, I have more than 2000 miles with this setup. surely if the clutch was riding itself for 2k miles i would have noticed a problem by now, and i dont have any problems.
thank you for clarifying.
The Following User Says Thank You to luelanski For This Useful Post:
keithr (07-10-2015)
Old 07-26-2015, 12:16 AM   #610
Howardwei
After adjusting the clutch engagement point with a competition stage4. My clutch engagment point randomly change sometimes. It would engaged as soon as a lift the foot on clutch just a little. But then sometimes it goes back to normal. Does anyone have this problem?
Howardwei is offline   Reply With Quote
Old 08-02-2015, 09:08 PM   #611
xingxingtjf
Drives: Subaru BRZ
Should have done this long time ago! Thanks OP
xingxingtjf is offline   Reply With Quote
Old 08-04-2015, 08:31 PM   #612
axelo
Drives: Whiteout frs
Yeahh
This is so easy its ridiculous..I've done clutch spring removal (harder to remove than this) and it haves the expected to have wobble up top....so upon turning easily master cylinder rod until both brake and clutch pedal are at same height was the spot for me...and its great...and this weekend i did trd quikshift and mtec shifter springs So i'm having so much fun and confidence now in the shifts....now a shorter clutch pedal...
I highly recomend this set up for agressive driving and to be the best (and fastest) hooligan you can be jeje
I think i'm gonna get in trouble with the police....
Be safe and thanks to all
Edit: cruise control senson works properly despite being away from clutch pedal... Didnt have a 14 ratchet....
axelo is offline   Reply With Quote
Old 08-15-2015, 07:19 PM   #613
fridayfrs
Drives: Frs
I just finished this mod this afternoon and I agree it helps shifting a ton. I noted something that may be what is mentioned in posts above but wanted to see what you guys think. I haven't removed the clutch spring.
When I shift the clutch pedal occasionally pops up a little bit making a thunk. The clutch is fully out and my foot is off of it at this point. The cruise switch isn't holding anything in so I can't figure out what may cause this binding. Any suggestions on what to look at? It isn't a constant thing which has me stumped.
Thx!
fridayfrs is offline   Reply With Quote
Old 08-15-2015, 08:14 PM   #614
Thx!
Does that binding seem to happen from down in the pedal cluster, or is the throwout bearing hanging up?
Old 08-15-2015, 08:28 PM   #615
fridayfrs
Drives: Frs
I'm not sure I'd know the difference but I'm thinking the pedal cluster. It didn't do this before this mod so thinking pedals.
Thx
Old 08-15-2015, 08:50 PM   #616
Thx
I'm inclined to go with you on that. Unfortunately, the only way to figure it out will be to get down on your back and operate the pedal by hand.
clutch adjustment, clutch helper spring
power steering feel adjustment brillo Engine, Exhaust, Transmission 29 11-06-2017 04:41 PM
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 11:17 PM
Any (easy) way to stiffen up the feel of the clutch? Partial Stall Engine, Exhaust, Transmission 41 07-19-2012 03:17 PM
My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* wanger Scion FR-S / Toyota 86 GT86 General Forum 5 06-02-2012 02:41 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 04:48 PM
