Old 06-29-2015, 03:02 PM   #197
erok81
Drives: 2015 BRZ
So that fancy new drain didn't work either? I just got mine. If you're didn't work maybe I won't bother.
But I don't have a pte turbo, so maybe I won't have that issue. My last turbo was pte and it always leaked. Hmm...
erok81 is offline   Reply With Quote
Old 06-29-2015, 03:15 PM   #198
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Originally Posted by yomny View Post
Yep, I've already removed the drain line so many times I'm afraid to damage anything else. Last try is today, got cooper extra high temp gasket silicone. As suggested, applied it and hand tightened it, let it dry and tightened it a little more. Let's see how it goes but worse case I'll pull the turbo and wait for JDL to get a response from precision.
What's the torque on those oil fitting bolts?
Rybot is offline   Reply With Quote
Old 06-29-2015, 03:20 PM   #199
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
I'd say just go the regular method, mine was unheard of till a couple of weeks ago and I'm boosted going on 4-5 months, all day every day driving. It could be one of those things. Just hang on to the flange, it looks like a nice piece and it did hold the oil in longer than the other gaskets. To update my situation, the guys at JDL are getting me an RMA number, precision is going to take a look at the turbo as its under warranty. This is good news to me and speaks very well of the guys over at JDL and their precision dealer. I'm going to remove the drain line completely and inspect everything now that the turbo will be off. I want to make sure when putting things back, everything is as it was the first day it was installed.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 06-29-2015, 03:23 PM   #200
Rybot
Rybot's Avatar
They want the turbo back before you get a new one I assume? If so, how are you gonna dd? Gonna deal with super loud pipes for a week?
Old 06-29-2015, 03:25 PM   #201
yomny
yomny's Avatar
Not sure as there really aren't instructions but if using with silicone, no more than 9ft lbs. if using a regular gasket I'd assume it could be tighter. This is going off several other precision install threads in other forums. I think there's not much to worry, it's either good or bad like in my case but it's not one of those things where a specia recipe has to be used to get it to not leak. When I installed the kit the first time, I tightened the drain flange bolts as tight as I could without trying to break anything or bend the allen key, didn't have any issues but something happened. Hopefully precision could determine the problem.
Old 06-29-2015, 03:34 PM   #202
yomny
yomny's Avatar
Lol no I won't be driving the car, plus I won't have a turbo so I can't really drive it. I'll have to ship my turbo in, not sure if they'll replace or rebuild or what their process is. I'm riding the wife's Mini Cooper lol.
Old 06-29-2015, 03:40 PM   #203
Rybot
Rybot's Avatar
Mini Cooper S?
Either way, sucky day. They'll probably plane the flange if that's even the problem.
Old 06-29-2015, 03:43 PM   #204
nelsmar
I hadn't planned on wrapping the intake, but if I find I need to, I guess it won't be terrible at all to pull it off and wrap it.
I think you are confused on what these different components are. The pipe that was "wrapped" was wrapped in a reflective tape to help reduce radiant heat. This pipe is a charge pipe. It has pressurized air that has been cooled via the intercooler. The turbo charger compresses air which increase the temperature and the intercoolers role is to attempt to get it as close as possible to ambient once again.
Your engine bay is a box with hot components in it. If you are not moving all that is moving the air through the bay is the fans. Which are blowing hot air from the front cooling elements into the bay. This results in a bay ambient temperature that is a fair bit higher than the ambient atmospheric temperature. This may be 10-50F above ambient.
As you are accelerating the velocity and volume of the air increases and the air through the MAF charge pipe (seen above) cools down due to the colder air passing through it. Due to the velocity of the air there is less heat transferred. conduction (not to be confused with radiant).
So looking at the bits above if you are sitting idle for a few moments and that ambient bay temperature starts to rise the charge pipe absorbs heat via methods of conduction and radiation (this pipe is typically black, and black has a very high radiant absorption capability). Due to the low velocity of the air going through this pipe it ends up soaking up the heat resulting in a high intake temperature. At low throttle bits and idle the car starts sucking up hot air. Hot air and hot fuel mixed together combust easier. Due tot his you have to pull timing from the ECU when the intake temperature is over a certain value. On the OEM ECU Map this starts happening at 50c. Here in Phoenix at idle I range 45-60C. So coming off the line and at very low throttle bits when I'm not moving much my car bogs due to the excessive heat. Adding a reflective wrap around the pipe can help reduce the effect by removing the radiant heat exposure and only allowing the conductive heat exposure.
You mentioned the intake pipe. The intake is attached to the turbo and is just a few inches long (if that). Insulating this does very little especially considering this air is going to go through the intercooler.
So yes even if you wrap / coat your hot components you still have a mass amount of heat being thrown into the bay by everything else that makes the car & ac work.
Wrapping the charge pipes is not at all required, and the car will run just fine without it. The difference when really getting aggressive with the car is minimal on that one piece but when people are trying to perfect everything every little bit adds up.
My flickr - Canibeat
Local magazine scout
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
ft86me (06-29-2015), Rybot (06-29-2015)
Old 06-29-2015, 03:44 PM   #205
yomny
yomny's Avatar
Mini Cooper S?
Yep the wife rides in a manual Cooper S, the pull on the turbo isn't as strong as the 86 but it's fun lol. Let's see if they just plane it I hope they plane it good, if that's even possible lol. I really don't want to have to go through this again as I now have to get a new T3 turbo gasket and another one for my downpipe to overpipe.
Old 06-29-2015, 04:21 PM   #206
Rybot
Rybot's Avatar
The emissivity of the black body alone would have a larger cooling effect at idle than any other color, though with the added thickness of insulation, wrap might provide better cooling due to lower emissivity.
I'll pass on the wrap for now since I'm not chasing diminishing returns, but I'd do it for the aesthetic factor moreso than cooling in any case.
Old 06-29-2015, 04:22 PM   #207
Rybot
Rybot's Avatar
The gaskets are pretty cheap though, no?
Old 06-29-2015, 05:04 PM   #208
yomny
yomny's Avatar
Yep, about 20 or so for both. Could also get away with not replacing it but I like to have piece of mind anytime I remove or replace anything.
Old 06-29-2015, 08:08 PM   #209
nelsmar
The gold wrap is not an insulator... No one in this thread has used an insulating wrap (unless i missed a post?)
Old 06-29-2015, 08:22 PM   #210
Rybot
Rybot's Avatar
You didn't miss a post, I guess I just assumed the tape would add a fraction of an inch of insulation, though looking back all that would matter is color and reflectivity.
So I could just wrap the charge pipe in some heat resistant white reflective tape for a better effect? The less radiative heat absorbed during idle, the better? If so, then why gold? Presentation?
I think I may need to do some calculations.
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
