#15 |
86 Noob
Drives: 2015 Scion FR-S
Kraftwerks Supercharger.
| GReddy Supreme SP Exhaust | K&N Drop in filter | Eibach Pro-kit Springs | B2autodesigns 20&25MM Spacers | OEM style rear diffuser | CS Style Front Lip & Side Skirts | HT Autos Style Rear Spats | Valenti Tail Lights | |
#16 |
Drives: 04' Saab 9-5 Aero
- Rims/Tires ~2k
- ST coilovers ~1k - Header ~1k that or save up a little and go the FI route
_____________________
You know what they say... pick two: cheap, fast, reliable. |
#17 |
Drives: 2015 BRZ series.blue
This thread is fantastic. Learned a lot from Googling adventures off most of the responses here
#18 |
CONGRATULATIONS, Roto'sFRS on your purchase and
....... to .... The Forum.Well, since you ask, I'd round up a co-pilot and head for Jasper NP in Alberta .... then follow the Rockies down until you run out of time or money. humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | LucidMomentum (07-06-2015), strat61caster (06-29-2015) |
#19 |
Drives: 10Series 0945
4.88 is my next mod for my AT. Kodyo does Weir have EVERY single piece needed to have a shop install it?
#20 |
Drives: Scion FR-S
Yes and no. I believe a shop will need to buy new shims to shim the diff/ring gear left to right. These shims are more specialized and I doubt he sell them, I got mine from Toyota. All other shims and parts he sells, including seals, bearings, gears, and spacer. If you're reusing your stock pumpkin, I'd reuse the bearings but still have a shop replace the three rubber seals. I'd recommend getting a solid spacer as well instead of the crush spacer. This also has to be shimmed, but will make your diff mor robust (this spacer sets preload between the two pinion bearings).
#21 |
The Mechanic
Drives: Civic Turbo,FR-S
I did a 4.56 myself its perfect for the car na but ill be selling it to go turbo this yr
#22 | |
Drives: RAVEN
Put it in the bank towards my next new car. My favorite car accessory is a tittle in my name; not the banks. Failing that, I would use the money to drive the FRS to the airport and get on a plane to someplace nice. |
| The Following User Says Thank You to NOHOME For This Useful Post: | strat61caster (07-05-2015) |
#23 |
Granny Shifter
Drives: 2014 FR-S
I'd save the $4,000 and just enjoy the car as is for a while. You've had it for two weeks man!.
Plus that's a nice amount of extra money to have lying around in your pockets seeing as you just bought a car. |
| The Following 3 Users Say Thank You to MokSpeed For This Useful Post: |
#24 |
Drives: '15 Halo FR-S
I'd probably buy a bike. Not going to bother with anything other than what I already have done to my car anymore since making the decision to get another motorcycle
#25 |
Contract? /人◕ ‿‿ ◕人\
If I had 4k extra to spend, I'll use it to pay off my car....
| The Following User Says Thank You to soulreapersteve For This Useful Post: | strat61caster (07-05-2015) |
#26 |
Drives: 2005 Toyota Camry
$4k to spend...
Is the car paid off? Cash or credit? What are your priorities in life? -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | strat61caster (07-05-2015) |
#27 |
Drives: 2015 FRS Asphalt
spend a little of that $$$ then invest bulk of $$$ in stocks.
#28 |
Drives: 2015 Scion FR-S Halo
Obviously I would get hookers and blow
| The Following User Says Thank You to DimSumHero For This Useful Post: | Aozora.BRZ (07-06-2015) |
| Open Flash Question | denellum | Software Tuning | 7 | 03-10-2015 01:05 AM |
| open source software question | GeeTee86 | AFRICA | 15 | 02-15-2015 07:52 PM |
| If you had $10K to spend | jbdrs | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 12-10-2013 02:01 PM |
| Open Flash Tablet Question | davidchoi | Software Tuning | 7 | 10-29-2013 02:58 PM |
| An open question to all the carbon part makers of the world | djliquidsteele | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 03-29-2013 03:23 PM |
