Old 06-16-2015, 07:05 PM   #71
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by JDKane527 View Post
Thus far, all the executions of integrated engine oil and coolant radiators have been flawed for this chassis.
Did you see the one Aceheaders showed a couple of months ago? The core was the full length of the radiator. I just hope its still in development as I haven't heard anything about it in a while.
The Following 2 Users Say Thank You to Calum For This Useful Post:
CSG Mike (06-16-2015), kask2_6.0 (06-16-2015)
Old 06-16-2015, 09:23 PM   #72
CSG Mike
CSG Mike's Avatar
shhhhh
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Calum (06-16-2015), celek (06-25-2015), Teclis (06-26-2015)
Old 06-16-2015, 09:30 PM   #73
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Thus far, all the executions of integrated engine oil and coolant radiators that have been released have been flawed for this chassis.
@Calum corrected for clarification
JDKane527 is offline   Reply With Quote
The Following User Says Thank You to JDKane527 For This Useful Post:
Calum (06-16-2015)
Old 06-18-2015, 05:09 PM   #74
Rosticles
Drives: 1966 Mustang, 2013 FR-S
@JDKane527, @Calum
Has anyone every reported on an installation of this system?
It looks like a pretty good version of a laminova-type exchange system. Most of the other radiator/oil-cooler combinations suffer from leaking and this one is based off of the Mishimoto radiator, which I trust to last. I only fear for the additional welding, and I know how FA20club is perceived on this forum.
http://www.ft86club.com/forums/showthread.php?p=1354596
Before I open up a string of vitriolic comments, I know of the issues people have had with FA20Club. I only want to know if anyone has tried THIS component and any feedback from it in particular.
Rosticles is offline   Reply With Quote
Old 06-18-2015, 07:26 PM   #75
Calum
That Guy
Originally Posted by Rosticles View Post
@JDKane527, @Calum
This guy used a bigger core. Read the thread to see the results.
http://www.ft86club.com/forums/showthread.php?t=42511
Here's the original release thread about the FA20crap product.
http://www.ft86club.com/forums/showthread.php?t=52219
What I took from those threads, which when you take a critical look at those heat exchangers (HE) is obvious, is that the HE is too small, the stock rad will be a weak point, and the flow through the HE isn't very good.
But that only means that's a bad execution of the liquid to liquid idea. A larger core, with better flow and a properly sized radiator should still work well.
I feel like I should be joining /r/hailcorporate but from what I've seen aceheaders will also have this product space on lock down. Give it some time to let Mike and the gang finish testing it in the heat of this summer and I'm guessing we'll have a viable product finally.
Disclaimer, I know nothing. Aceheaders and CSG haven't told me anything, I'm just a forum whore.
The Following 3 Users Say Thank You to Calum For This Useful Post:
civicdrivr (06-20-2015), CSG Mike (06-18-2015), DAEMANO (06-19-2015)
Old 06-18-2015, 08:58 PM   #76
CSG Mike
CSG Mike's Avatar
I just arrived at CSG and it is 98F outside.
Disgusting. All hail Air Conditioning!
Calum (06-19-2015), civicdrivr (06-20-2015)
Old 06-20-2015, 01:16 PM   #77
scarfo
Drives: gts 86
Any more info on the install? I've got the ultra radiator going into my car soon
scarfo is offline   Reply With Quote
Old 06-20-2015, 03:38 PM   #78
SPCorBUST
SPCorBUST's Avatar
Did you want instructions on how to operate a hole saw or something? Or a template on how to cut into the car...?
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 06-21-2015, 10:21 AM   #79
scarfo
Drives: gts 86
Skunk2 ultra radiator
No need to be condescending,
FTeightsix how did you go about hooking up your oil lines, I doubt you would have drilled into the chassis.
I've got a treadstone turbo kit on the car aswell, so I'm hoping I can shoehorn the radiator in with the stock fan shrouds.
The Following User Says Thank You to scarfo For This Useful Post:
Strife26 (09-08-2018)
Old 06-24-2015, 05:27 PM   #80
SPCorBUST
SPCorBUST's Avatar
I apologize, I was going for sarcasm, not condescension. Again, apologies if it came across that way.
Old 06-25-2015, 03:34 PM   #81
86SPEED
86SPEED's Avatar
Drives: The silvertrooper 10 series
The customer took the car to a local hose and fitting fabricator here in Vegas. he has been running it for a month and a half or so. as far as i know they did not cut into the car, just used a custom banjo fitting that they modified for better flow. he was going to take some pictures and all but i never got back to him. Last i talked to him he said nothing was leaking. He doesn't have any gauges to check temps, but i dont see why he would have a problem, i daily drove here with the stock radiator and no oil cooler with no problems and 450+ to the wheels on the C38 kit.. Of course it wouldn't make it around a track and i doubt it would make it long aggressively driving though the mountains or canyons. he doesn't drive like that, it was over kill he just wanted it.
-Thomas
86SPEED is offline   Reply With Quote
Old 06-26-2015, 07:04 AM   #82
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
Motor is back in, runs fine NA at the moment.
Still working on ducting for the radiator.
Want to make sure that all the air has to go trough the cooler.
Back offshore now, will update when I am back home and finish it.
English is my 2. language. Typos might occur.
2013 BRZ, kraftwerks supercharged.
Skunk2 Ultra radiator with oilcooler
KW v3 - enkei 17x9 with PSS
Andreas83 is offline   Reply With Quote
The Following User Says Thank You to Andreas83 For This Useful Post:
SPCorBUST (06-26-2015)
Old 06-26-2015, 09:43 AM   #83
scarfo
Drives: gts 86
Thanks for the reply
I fit the radiator then removed it. It doesn't fit with a front mounted internally actuated turbo like the Borg warner efr.
I mean I could make it fit, custom shroud, spal fans etc, but time is a restraint atm. So going to sell it and use an air cooled oil cooler.
Old 06-26-2015, 11:47 AM   #84
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
Just an FYI, skunk do say this: Skunk2’s all-aluminum, full-size Ultra Series Radiator for the FRS/BRZ is a direct-fit upgrade ... Found that at their own site.
Link to their own site: http://eustore.skunk2.com/brz-frs-ul...-radiator.html
But anyway, good luck and I can't wait to see you get your brz back on the road Andreas!
Teclis is offline   Reply With Quote
Skunk2 Header? FirestormFRS Engine, Exhaust, Transmission 69 10-11-2019 10:42 AM
Skunk2 Review. FirestormFRS Engine, Exhaust, Transmission 1 12-31-2014 09:55 PM
Skunk2 BRZ Intake Results! Xero-Limit Engine, Exhaust, Transmission 21 10-20-2014 02:43 PM
New skunk2 frs brz cold air intake 831GT86 Engine, Exhaust, Transmission 17 09-09-2014 05:09 PM
FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) Sportsguy83 Engine, Exhaust, Bolt-Ons 15 05-27-2014 01:18 PM
