Old 06-15-2015, 09:05 AM   #15
FRSNewb
FRSNewb's Avatar
Originally Posted by Ornelas66 View Post
What is the difference between the H-1 and the D2S bulbs? I thought the Spec D lights HAD to have the H1 light bulbs if you wanted to have HID lights.
Originally Posted by Jake_86 View Post
D2S bulbs do look like they have the proper fitment (witht he little notch cut out)
There is 0 difference when it comes to proper fitment, both fit into the lights.
1993 Mazda MX-3 - *SCRAPPED* / 1999 Plymouth Neon - *WRECKED* / 2000 Chrysler Neon - sold / 2006 Honda CR-V - sold / 2019 Chevrolet Colorado - All Year Round Vehicle / 2013 Scion FR-S - Summer Car
FRSNewb is offline   Reply With Quote
Old 06-15-2015, 12:15 PM   #16
Jake_86
Jake_86's Avatar
i cant get the h1 to fit at all really. the black plastic part (which is slightly more than a half circle on H1) is too small to get caught by the clips. did you use h1 yourself? can you sneak a pic? did you use anything to clip it in(such as the plastic that comes around it)
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
The Following User Says Thank You to Jake_86 For This Useful Post:
Ornelas66 (06-16-2015)
Old 01-19-2017, 06:29 PM   #17
CxG
Drives: Pearl White '13 ZN6
uhm I'm using h1's the clips is annoying to get on, both sides had of the clip had to be done at the same time or the little metal washer would slip out of place.
CxG is offline   Reply With Quote
Old 03-10-2017, 01:17 AM   #18
tofux86
Drives: 2013 scion fr-s ultramarine blue
i just recently got the headlight and hid kit separate. the d2s bulb goes into the AMP > D2S adapters and into the ballast. where am i suppose to connect the other part for the complete circuit.
tofux86 is offline   Reply With Quote
Old 03-10-2017, 01:54 PM   #19
mclovin85
mclovin85's Avatar
Drives: scion fr-s
Originally Posted by Devante View Post
Can I slightly hijack this thread?
If I want these, what all do I need to install them?
I keep reading about D2S, AMP, ballasts, H7 bulbs, etc.
Some I read need the original car to be the HID models. Some come with kits?
I'm about to buy a base model FRS.
I just want these or Winjet headlights, Valenti taillights, fog lights, and an aftermarket front indicator.
I don't want to buy anything I won't be able to use.
Any advice is appreciated!
i dont have after market headlights but i do have switchabacks for my car and you will need a led hyperblink module so they dont blink fast... i also have the winjet fogs and install was fairly easy it also comes with a fog switch so you can turn them on and off, i threw in yellow led's from ijdmtoy in the fogs and they give off a more yellow than a 3k hid bulb.. hope this helped you a little bit
mclovin85 is offline   Reply With Quote
Old 03-10-2017, 06:18 PM   #20
CA86GRL
CA86GRL's Avatar
Drives: 2016 FRS
Originally Posted by FR-S_ATL View Post
I'm looking to switch to HID headlights and found spec d lights. I didn't find any reviews on them and was wondering if anyone has these or knows anyone who does.
http://www.protuninglab.com/hidxe12s...id=56128534817
Thanks
I just installed these this week. They are AMAZING
CA86GRL is offline   Reply With Quote
Spec D Tuning Headlights on BRZ beagoodruslan Cosmetic Modification (Interior/Exterior/Lighting) 38 03-14-2018 02:36 PM
Spec D headlights gdrider77 Cosmetic Modification (Interior/Exterior/Lighting) 2 09-16-2014 03:55 PM
Spec-D headlights on car Jarumie42172 Cosmetic Modification (Interior/Exterior/Lighting) 50 06-21-2014 03:37 AM
Spec D Headlights Ammonia Want-To-Buy Requests 0 06-11-2014 10:21 AM
