Old 06-13-2015, 06:25 PM   #1
astar23
Drives: 2013 Scion Fr-s
Endlinks Question
I was installing my coilovers today and during the process the nuts were stripped for the endlinks. One is actually still stuck on the OEM strut assembly. I do have new end links that came with my coilover, just waiting on the nuts. Is it safe to drive the car without end links for a few days while I wait for the parts? Of course I'll be driving as carefully as I can and only to and from work(around 5 miles round trip)
astar23 is offline   Reply With Quote
Old 06-13-2015, 07:01 PM   #2
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
A) Make sure your sway bar is disconnected on the otherside.
B) If it it is the front sway bar, you are going to have significant oversteer, more so if you have a stiffer rear bar from OEM. If it is the rear sway bar, you are going to have a bias towards understeer, but since the car naturally has oversteer, it may be neutral.
C) Just make sure the sway bar is disconnected on both sides. I can't stress this enough.
D) Do not leave the endlink half installed, completely remove it until you have all the nuts you need to install completely.
Do all that and the car should be fine, it just won't handle like you are used to.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 06-14-2015, 12:14 AM   #3
astar23
Yeah I took both endlinks out. You think it would be a good idea to zip tie the sway bar ends so that it doesn't move around?
And thanks for the response!
Old 06-14-2015, 01:32 AM   #4
Turkish
Serial Cone Killer
Turkish's Avatar
Probably not a terrible idea. I don't think that it will be a problem, but it would presumably be safer to do something along those lines.
... his name is...
C'THULHU
WTB FRONT ENDLINKS fr_s Want-To-Buy Requests 2 06-25-2015 08:15 PM
OEM sway bars+endlinks bjun Brakes, Suspension, Chassis 2 05-20-2015 10:37 AM
Alignments and endlinks question radroach Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-02-2014 01:30 PM
WTS BC Coilovers and Endlinks Wilso Canada Classifieds 5 09-21-2014 01:03 PM
Front Endlinks goke186 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-31-2012 02:16 AM
