#113 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Can't do anything about this. It will happen with how the Procede and the esc are setup. Just don't stall. ![]() Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#114 |
@TM Woot! Thanks bro.
As for the deceleration... I'll work on this. I had this happen to me twice and I think I have an idea on how to fix this. But I'm a little worried it will affect the performance. It may not. Can you tell me exactly how it happens and I'll look at the Procede map. Or a recording from the oft may help too. Sent from my iPhone using Tapatalk
#115 | |
Drives: DGM BRZ 6MT
It's more noticeable in lower gears, say 2nd. Just accelerate at partial or WOT with the ESC activated and then let off of the throttle. It doesn't have to be let go instantly, just semi-quickly.
#116 | |
Do you think it's too much boost or not enough? Sent from my iPhone using Tapatalk
#117 | |
When we had the brake not as aggressive in earlier revisions if you went wot and then got off the throttle to decelerate quickly in gear the car would lurch forward until the brake slowed the compressor. Same thing goes if you WOT really quick and then clutch in to neutral.... throttle plate will close and the engine can stall if the compressor runs too long. |
#118 | |
Drives: DGM BRZ 6MT
#119 |
Time Traveller
#120 | |
PROcede ESC User Software!
If this is the issue; There's an easy fix. Shiv had it setup that the esc prespools when shifting gears. We can disable this at lower rpms so that way when you hit the gas and then let off it won't prespool but I'm not sure if we would want to change that for higher rpms. 1 issue though. I don't have my laptop and I'm no where near it for a while (very long while) I can walk someone through it though. @TM it's not the esc it's the Procede prespoolinf for gear shifts. Sent from my iPhone using Tapatalk
#121 |
Drives: DGM BRZ 6MT
What exactly is the procede prespooling? I was under the impression that the compressor is physically moving.
#122 | |
If you hammer the throttle and then shift gears on the old switch the compressor would come to a stop and then switch back on when you hammered the throttle again. With the Procede when you lift off the gas to shift gears it keeps the esc spooling because it knows you are about to shift. Problem is when you are in a low gear in traffic. Sent from my iPhone using Tapatalk
#123 |
Drives: DGM BRZ 6MT
Yeah, that's what thought you meant when you said it was prespooling. I just misunderstood the last sentence.
So it seems like the prespooling helps when you're actually shifting, but it doesn't know when you're actually about to shift or just letting go of the throttle to decelerate. Sent from my iPhone using Tapatalk
#124 | |
And I think when most of us are having issues is in traffic. I know the two times I did it was when I accelerated to avoid being rear ended and then stopped quickly to not read end someone else. It would be a quick and easy fix for anyone to log into the Procede software to fix though. So let me know if anyone wants to try. Sent from my iPhone using Tapatalk
#125 | |
Drives: DGM BRZ 6MT
If you walk me through it, I can try to adjust the map via the software, but I can't be sure when I can test drive the map loaded on my car, though. It's not easy finding street parking these days, and I don't want to lose my spot unless I will be driving for an extended period of time.
#126 |
@DAEMANO or @WRB5titch can I walk you guys through it? It will take a few minutes.
We need to modify one row. Sent from my iPhone using Tapatalk
| What does your user name mean? | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 355 | 05-01-2016 08:52 AM |
| OFT: New firmware and new user software | Shiv@Openflash | Software Tuning | 9 | 10-15-2014 02:45 PM |
| EcuTek End User/Retail Tuning Software Release! | Dustin@Dynosty | Forced Induction | 27 | 12-19-2013 09:17 AM |
| user tags | scottmcphee | Site Announcements / Questions / Issues | 3 | 04-11-2013 03:15 PM |
| User name | trueno86power | Site Announcements / Questions / Issues | 7 | 11-28-2012 12:48 AM |
