Old 06-10-2015, 10:58 PM   #15
Poodles
Drives: 2015 Series.Blue
There's always that electric supercharger...
Old 06-11-2015, 12:00 PM   #16
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
Dream20b (06-11-2015)
Old 06-11-2015, 12:36 PM   #17
Dream20b
Y u do dis?
Why not both?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 06-11-2015, 12:51 PM   #18
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Never been disappointed with my choice of a supercharger. I've had it for over a year with no issues. Daily drivability and reliability is not an issue.
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
Old 06-11-2015, 12:52 PM   #19
STV3
Señor Member
STV3's Avatar
How big was the difference in you gas mileage?
STV3 is offline   Reply With Quote
Old 06-11-2015, 01:25 PM   #20
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
I have had 3 different FI setups on the 86 platform. I first started out as one of the first Innovate kits with a JDL EL header, Greddy axle back on the stock pulley and e85. The car responded very well down low and mid range. The top end struggled a little but wasnt a big deal to me for what I used the car for. Mpg on ethanol for daily driving was down to roughly 18mpg at best not even really going WOT on the car. I moved to a JDL single scroll, EL manifold, PTE DBB 5558 w/ full 3in exhaust on flex fuel. The car had amazing power throughout the rpm band. Mpg's were anywhere between 19mpg-29mpg depending on fuel and driving habits. The down fall for me was the heat that came with the kit in the hot AZ desert. Due to an engine failure from pushing the stock block to the limits, the turbo came off and was sold. I am now on a custom wastegated Vortech V3 setup, 2.87 pulley, 2.5in catback and pump gas. The vehicle drive ability on this setup is literally like stock. My max boost setting on 91oct pump piss is 10psi with very little timing in it. The wastegate helps a lot with a meatier tq curve and am able to adjust boost levels via the EBCS on Ecutek. I have zero heat issues, IAT's are good and it pulls nicely all the way to redline. Mpg is around 24-25 right now which isnt bad.
Moral here is I have had way to many setups and never can make up my mind but hopefully it's some insite on what there is. PM me for any further details on each.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
The Following User Says Thank You to evo4g63 For This Useful Post:
aslanteye (06-11-2015)
Old 06-11-2015, 01:55 PM   #21
aagun
Drives: 86
go turbo
aagun is offline   Reply With Quote
Old 06-11-2015, 02:15 PM   #22
kbogarto
Drives: 2013 BRZ limited WRB
If you want a reliable DD. don't go forced induction. Otherwise get the best tuner you can find.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
The Following User Says Thank You to kbogarto For This Useful Post:
wparsons (06-12-2015)
Old 06-11-2015, 02:36 PM   #23
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
^Sage advice there...
The Following User Says Thank You to BigFatFlip For This Useful Post:
kbogarto (06-13-2015)
Old 06-11-2015, 03:33 PM   #24
LS1M
Drives: 2015 BRZ
I would like more information on how you put an electronic boost controller on a Vortech. What kind of wastegate is it? Is it actually exhausting the unwanted boost or are you using it to bypass the compressor? It also sounds like you're tuning this yourself?
LS1M is offline   Reply With Quote
Old 06-12-2015, 01:43 PM   #25
evo4g63
evo4g63's Avatar
PM'd
-2016 Subaru WRX
Old 06-12-2015, 07:14 PM   #26
stevo585
Drives: White 2014 BRZ
Originally Posted by sw20kosh View Post
Header + FP + E85 done
What I did. Definitely makes the car more peppy and fun. I also cut nearly a second off my quarter mile time.
stevo585 is offline   Reply With Quote
Old 06-13-2015, 12:15 AM   #27
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
You don't strike me as someone with strong mechanical knowledge. This car is your DD and therefore I am assuming you don't have lots of disposal income either... Like me. Do yourself a favor, keep reading, dreaming and reading. The more you read the more you will steer yourself away from this treacherous roadway tuning a car will take you.
What will you do if one morning you fire up your car and the check engine light comes on? What? Take everything off you car and bring it into the dealer and play that game? What if its totally trashed but you still owe $20k on a car that doesn't work? Just imagine the nightmare. If you want more power sell it and but a wrx or something. Of, make your wife by a 2015 wrx 6 speed and have the best of both worlds. .. Like i did.. Ps I like the 86 more
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 06-13-2015, 07:38 AM   #28
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
PM'd
I would like to know this information as well.
Super plus Turbo PLEASE MOVE TO FORCED INDUCTION Captain Snooze Forced Induction 2 01-24-2014 08:21 PM
Turbo+super firl21 Forced Induction 8 04-16-2013 12:51 PM
would you turbo or super charge your BRZ/FRS? chenshuo Scion FR-S / Toyota 86 GT86 General Forum 45 03-04-2013 11:13 AM
Turbo or Super Charger Ryan86 AFRICA 7 11-21-2012 09:14 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 08:23 PM
