Old 06-08-2015, 10:52 AM   #29
Racecomp Engineering
We've run Stoptechs on many of our project cars in the past and we have a front and rear trophy kit on our Project WRX. Dan runs them on his ridiculous GD chassis STI.
Stoptechs are not a rare sight at the track. They work very well.
- Andrew
Racecomp Engineering is offline
AZP Installs (06-09-2015), Hyper4mance2k (06-09-2015)
Old 06-08-2015, 12:36 PM   #30
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Originally Posted by OkieSnuffBox View Post
Legit question, how come melting the dust boot on these is a concern, yet with other things I've tracked with stock calipers the OEM dust boots aren't a problem?
I've been hardcore tracking cars with dust boots for 15 years and never had a concern about the boots cracking. They don't "melt" as as some have alluded; they simply crack on the outer edge.
So, for me, it is not a concern. As far as I can tell, only people that sell race kits make it a concern.
Sleepless is offline
The Following 3 Users Say Thank You to Sleepless For This Useful Post:
ajc209 (06-15-2015), Hyper4mance2k (06-09-2015), JDM4E (11-13-2016)
Old 06-08-2015, 12:40 PM   #31
OkieSnuffBox
Drives: '23 BRZ Limited
- Andrew
Excellent, that's what I suspected. Thanks for confirming.
OkieSnuffBox is offline
Old 06-09-2015, 01:31 PM   #32
CSG Mike
CSG Mike's Avatar
It just means you've never gotten them hot enough to have that type of failure.
Just because you've never done it, doesn't mean someone else hasn't.
CSG Mike is offline
smoke86 (11-25-2020)
Old 06-09-2015, 01:33 PM   #33
CSG Mike
CSG Mike's Avatar
Melting dust boots with ANY car or caliper is a concern. The question is, how hot are you getting your brakes? If you're not getting them hot enough, then you'll never melt or burn off your dust boots.
On the other extreme, I've ran my OEM S2000 calipers without the outer dust boots for nearly 5 years, without issue. If I replace the dust boots, I literally burn them off in one track day. Not melt, or crack, but burn them off and all that is left is ash.
CSG Mike is offline
CxG (08-10-2016)
Old 06-09-2015, 01:51 PM   #34
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
In the realm of this discussion, for these cars (not s2000s or misc race cars) these kits are more than enough even for high levels of skills.
Mike
AZP Installs is offline
The Following 3 Users Say Thank You to AZP Installs For This Useful Post:
ajc209 (07-20-2015), CxG (08-10-2016), Sleepless (06-10-2015)
Old 07-06-2015, 03:43 PM   #35
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Update:
- Brake feel is worlds better than stock (on the same XP12 pads)
- No brake fade (on NT01 and Star Spec tires), despite running faster than ever before (due to some coaching
- After 4 days the pads are less than half worn; used to go through XP12s in 3-4 track days
- More likely to squeal louder than stock calipers with XP12s
CxG (06-24-2016), Pekingduck (11-27-2016), TofuJoe (11-21-2016)
Old 10-17-2015, 03:13 PM   #36
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
UPDATE:
- XP12s lasted 7 days on NA power with TF brake ducts (double what I got with stock brakes and the pads are the same price
- Dust boots look great
The Following 4 Users Say Thank You to Sleepless For This Useful Post:
CxG (06-06-2016), industrial (10-19-2015), JDM4E (11-13-2016), Pekingduck (11-27-2016)
Old 06-06-2016, 04:49 PM   #37
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
UPDATE:
- Another 6+ track days on the XP12s but now with JRSC power Switched to APR duct kit since TF would not work with JRSC
- Dust boots still look fine after 12 track days
- Rotors look good too.
Brake feel is really nice and clearly the brakes are no where close to being over taxed.
Very pleased, and the cost was great too ($1800 and easy to install)
8R6 (06-06-2016), CxG (06-06-2016), Pekingduck (11-27-2016), Racecomp Engineering (06-06-2016)
Old 08-04-2016, 04:00 PM   #38
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
UPDATE:
- 5+ track days on the XP12s
- Dust boots still look fine after 17 track days
The Following 7 Users Say Thank You to Sleepless For This Useful Post:
ajc209 (08-05-2016), Bramick (10-01-2016), CxG (08-10-2016), DarkPira7e (02-05-2018), Lonewolf (11-13-2016), Pekingduck (11-27-2016), weederr33 (11-06-2016)
Old 11-13-2016, 05:14 PM   #39
BTXP.XD
Drives: 14' FRS
Does anyone know if the ST40 calipers are just direct bolt on? Like I can get diff size rotors etc? Thanks guys
NBeyond
https://www.instagram.com/nbeyond__/
Support us for daily cars + upcoming clothing line.
BTXP.XD is offline
Old 11-14-2016, 03:26 AM   #40
Apex-Apex
Apex-Apex's Avatar
No, if they were direct bolt on, how will you space your caliper for the different size rotors?
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline
The Following User Says Thank You to Apex-Apex For This Useful Post:
dj2020 (11-14-2016)
Old 11-21-2016, 09:55 PM   #41
n0thing
Drives: Subaru BRZ
Can you swap in a 1-piece rotor into the ST40? if so, what part#/equivalent?
n0thing is offline
Stoptech Sport Brake Kit goke186 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-28-2012 07:57 PM
FS: Stoptech Brake Lines FRS2000 Brakes, Suspension, Chassis 1 12-17-2012 05:07 PM
Stoptech Sport Brake Kit blkwrxwag Brakes, Suspension, Chassis 9 12-08-2012 04:05 PM
StopTech Brake Kit for the FR-S / BRZ Drift-Office Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 08-24-2012 03:36 AM
