Old 06-03-2015, 04:42 PM   #57
stevemp5
Drives: scion fr-s
I put my four tpms in my spare wheel loll
stevemp5 is offline   Reply With Quote
The Following 2 Users Say Thank You to stevemp5 For This Useful Post:
HyperTech (12-06-2015), Tcoat (12-20-2016)
Old 06-03-2015, 04:55 PM   #58
Timmy_Jones
Spun
Drives: 23' Supra
Not sure if you read the thread or not, but that won't work.
Timmy_Jones is offline   Reply With Quote
Old 06-03-2015, 05:24 PM   #59
stevemp5
Drives: scion fr-s
Sorry my english is bad.. i read how block your tpms light and this is my technic loll.
Old 06-03-2015, 05:33 PM   #60
MalcolmHimself
MalcolmHimself's Avatar
Drives: 2015 BRZ
Does that work for you? The thread says that the wheels must move for TPM to work.
MalcolmHimself is offline   Reply With Quote
Old 06-03-2015, 05:39 PM   #61
stevemp5
Drives: scion fr-s
Yeah work very good, after one year never have light again! This is the DIY a take for that but is in french.. but he have good picture on it. http://www.quebecfrs.com/forums/guid...teme-des-tpms/. Lot of person in my crew run this with no problem
Old 06-03-2015, 08:26 PM   #62
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
takes 2 seconds.
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
Peaty (12-20-2016)
Old 12-06-2015, 12:01 PM   #63
HyperTech
HyperTech's Avatar
Drives: Mazda3 2013 / Scion FR-S 2015
that's mean a pipe with 35 psi pressure with all the tpms inside will work then.
HyperTech is offline   Reply With Quote
Old 12-06-2015, 12:08 PM   #64
KL
Drives: 2013 SWP BRZ
I don't think he's saying that putting his sensors in the spare wheel stops the light from coming on. I'm reading it as he's blocked the light and the sensors are basically stored there.
EDIT: I was wrong, apparently the DIY linked calls for drilling into the spare rim and installing all 4 sensors there. Somehow this works and reads the spare pressure correctly, tricking the TPMS into thinking there are 4 identically inflated tires on the car?
OP's link no work: (http://www.quebecfrs.com/forums/guid...teme-des-tpms/)
That said, I've personally never had my TPMS light come on. I've got sensors in my summers and stocks (winter) and I've had the pressure drop as low as 21 psi in one tire with no light. I habitually check with a gauge anyway so I don't care but it seems odd.
KL is offline   Reply With Quote
Old 12-06-2015, 12:26 PM   #65
stevesnj
stevesnj's Avatar
There's also this that resets the TPMS and allows push button activation of "pedal dance".
I have this and it works amazing. No TPMS light or drilling...lol
http://www.beastronix.com/shop/86nanny-pedal-dance/
My 2016 Build thread
Old 12-06-2015, 01:49 PM   #66
HyperTech
HyperTech's Avatar
you have a brz...its been reported some model of the brz, i dont know witch one exactly, high tech or something like that trim, maybe im wrong, dont have tpms module, but might still have the tpms sensor in the wheel, but doesnt have the tpms module to track the signal. so, no light...
Old 12-06-2015, 01:50 PM   #67
HyperTech
HyperTech's Avatar
do you have to "reset" each time you start the car? how does this things work?
Old 12-06-2015, 05:29 PM   #68
stevesnj
stevesnj's Avatar
You can just keep it on TPMS reset and it will stay with every restart
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
Beastronix (12-14-2015), HyperTech (12-06-2015)
Old 09-04-2016, 12:17 PM   #69
Bradyg1
So just trying to clarify it will only be the light on when I remove the tpms?
No beeping or ding correct? Thanks
Bradyg1 is offline   Reply With Quote
Old 12-20-2016, 11:20 AM   #70
gregman
gregman's Avatar
Drives: Boner Garage
correct.
gregman is offline   Reply With Quote
TPMS Sensors kanundrum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 249 06-21-2019 05:22 AM
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 02:22 PM
Subaru TPMS Nonsense Grimlock BRZ First-Gen (2012+) — General Topics 67 10-07-2013 04:15 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 05:24 PM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 02:06 PM
