Old 06-01-2015, 10:44 AM   #15
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Originally Posted by extrashaky View Post
What issue? Price variation? OP didn't actually describe an issue with the car, only his lack of understanding of how measures and rates work.
Well no,
He actually said " problem is that the gauge didn't fully reach the top to the full mark"
so to me the problem is, he filled the tank but the needle didn't reach the full mark, which when I fill mine it goes past the full mark....
If you wanna read the older threads I'm pretty sure everybody just let it go and it reset itself
I agree he should be using liters (gallons for the us) and go by that way instead of using pricing (obviously because pricing changes day by day)
BlueSky is offline   Reply With Quote
The Following User Says Thank You to BlueSky For This Useful Post:
Tcoat (06-01-2015)
Old 06-01-2015, 01:09 PM   #16
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Damnit! I recently filled up in the US and they use gallons not liters. Will using non metric gas void my warranty?
is it more impressive to say 5 cm or 2 inches?
Metric system, making males feel bigger since 1799.
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
Tcoat (06-01-2015)
Old 06-01-2015, 01:12 PM   #17
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by Phothiraj View Post
So, it usually takes me about $25-$30 to fill my tank from a quarter tank to full. One time i put in $10 dollars to get myself home from out of state and my gas gauge did not move from the quarter tank mark. It continued to go down at a normal rate the way it normally does but i had more gas in my tank than my gauge was actually reading because the next day i go to fill the rest of the tank up and the light was on but it only took me $18 dollars to fill the entire tank to full. So, i assumed since its the first time it'll be okay. Just today i fill up my tank from a the light to test it again and it takes $26 but the problem is that the gauge didn't fully reach the top to the full mark. I had about an eighth of a quarter tank missing. So i was wondering if i have a bad sending unit or possibly what can my problem be.
This is a Japanese car not a German car, never fill the car with only a quarter tank to full otherwise the fuel gauge will end up malfunctioning.
Wait until you hit half full before doing a fill-up. In your case, you should run your tank down until the needle starts to move again below half full.
I know the preppers will flame me on this, but if the asteroid is gonna hit would you really be driving the BRZ instead of your Range Rover to get away?!
krayzie is offline   Reply With Quote
Old 06-01-2015, 02:06 PM   #18
Special_K
Bannιd
Special_K's Avatar
Drives: 2013 DGM BRZ
Whenever my different gauges start acting up, I just disconnect the battery for 10 mins to reset the ECU. Works for the other guages so I'm assuming it will work for the fuel gauge as well.
Special_K is offline   Reply With Quote
Old 06-01-2015, 02:10 PM   #19
Chanpion
Drives: 13 FRS Satin
I've noticed it doesn't register little changes. Think I filled up 7Ls once, didn't register it. I filled up the new day and it registered the current fill + the 7Ls.
Chanpion is offline   Reply With Quote
Old 06-02-2015, 09:52 PM   #20
BuzzR
Drives: 2013 BRZ Limited
I've had this happen twice.
It happens (to me, anyway,) if I add some gas to the tank, but do not fill it completely.
Both times it has re-set when I filled the tank after driving it awhile.
Just a glitch I guess, like the chirping fuel tank.
BuzzR is offline   Reply With Quote
Old 06-03-2015, 12:22 AM   #21
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Where did you buy your gas? Eritrea?
carma143 is offline   Reply With Quote
Old 06-03-2015, 12:28 AM   #22
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Happens on multiple modern cars. I just ignore it, it'll fix itself anyways.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 01:48 PM
faulty a/f o2 sensor sid3way5 Issues | Warranty | Recalls / TSB 5 01-06-2014 12:06 PM
Passenger elec window faulty with flashing switch GavinAnt Issues | Warranty | Recalls / TSB 4 04-04-2013 03:38 PM
Passenger weight sensor faulty? Trashed675 Issues | Warranty | Recalls / TSB 5 01-27-2013 02:20 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
