Old 05-31-2015, 11:29 AM   #43
philstar
philstar's Avatar
Drives: Argento FR-S
Recently just installed a header and flashed OFT stage 2 93 tune.
I recently got P0351 at a drift track day around the end of the day, I cleared it and it did not pop up for a few days driving normally.
Then I was at/close to redline first to second gear, and P0351 popped up instantly again, I have cleared it and hasnt popped up since.
I do not hear any DI seal popping noises.
Any luck you guys with replacing the coil or using heat tape on the coil? If this is due to heat, has the heat already started breaking down the coil and I should get a new one.
Any of you guys have luck using the heat tape?
philstar is offline   Reply With Quote
Old 05-31-2015, 11:29 AM   #44
philstar
philstar's Avatar
Old 05-31-2015, 12:23 PM   #45
Koa
bro phil hope this helps
https://www.google.com/webhp?sourcei...3Aft86club.com
The Following User Says Thank You to Koa For This Useful Post:
philstar (05-31-2015)
Old 06-02-2015, 01:32 PM   #46
sickmint79
Drives: bmw
i installed it thursday and went to gridlife this weekend. however they were 20 minute sessions plus it was rainy out, so i wasn't getting on it nearly as hard as usual. a new coil seems like it can take a bit of a beating anyway before kicking off this error. my oil wasn't as hot as it normally gets but i was still to the point of getting close to or topping out 4th on the long straight; i only did 5 sessions over the weekend though. so perhaps too early to tell for me yet.
i'm not sure if the swaintech ceramic coating reduced overall under hood temperatures, but i am sure it itself is far far less hot when i come off the track (i can touch it) than my prior (oem) header. i just put the gold foil on and will report back with results as i see them. next track day is blackhawk farms with badger bimmers on the 15th (first time there) and doing ab south with gridlife at the end of june, which i'm much more comfortable and familiar with. i think if i make it through that event with no error i will consider the issue resolved.
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 09-10-2017, 05:07 PM   #47
sickmint79
Drives: bmw
how to fix p0351 for brz/frs/86
CEL P0351 Ignition Coil "A" Primary Control Circuit/Open romin Engine, Exhaust, Transmission 468 11-26-2021 05:05 PM
U0115 OBD trouble code vtmike Issues | Warranty | Recalls / TSB 4 08-31-2013 02:24 PM
First Time Out Shooting Forgetful FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 07-23-2013 12:12 PM
86 shooting brake Freeman Scion FR-S / Toyota 86 GT86 General Forum 44 12-07-2012 09:27 PM
trouble shooting tim saylor Other Vehicles & General Automotive Discussions 0 07-01-2012 02:04 PM
