Old 10-07-2014, 04:41 AM   #85
autobot84
Drives: 2013 Scion FRS
The stock tips are weak. I hate loud exhaust. Looks like I'm going to go for this mod. I want 4.5" tips though ahaha.
autobot84 is offline   Reply With Quote
Old 10-07-2014, 03:17 PM   #86
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Originally Posted by MmmHamSandwich View Post
Same setup as my Si looks like. Thanks for satisfying my curiosity.
Off topic: lol your profile pic/username made me crave a ham sandwich
Jolaessss is offline   Reply With Quote
Old 12-19-2014, 07:05 PM   #87
RickyBobby
Drives: 2013 Firestorm FR-S AT
This thread is getting a bit old and worn but just need a bit of help on choosing which DC Sport tip is the right fit. A post in another thread stated that the FR-S exhaust pipes are 2 1/8" in diameter.
From the descriptions I was going to purchase the EX-1012 because of it's Inlet: 2.25" dimension, but then it says fits 1.5 inch - 2 inch of what??? One poster here said he had to remove the washers to get the EX-1012 to fit. So maybe the EX-1013 or the slightly smaller outlet EX-1010 is the one to get since it Fits: 1.75 inch - 2.5 inch.
EX-1011
Description:
• DC SPORT SS BOLT-ON TIP
• UPC: 757558509010
• Weight: 1.8 lbs
• Dimension: 9"(H) x 3.9"(W) x 3.9"(L)
• Inlet: 2.875 inch
• Outlet: 3.75 inch
• Length: 9 inch
• Fits: 1.75 inch - 2.5 inch
• Resonated: Yes
• Cut: Straight
EX-1012
Description:
• UPC: 757558509027
• Weight: 1.8 lbs
• Dimension: 9"(H) x 3.75"(W) x 3.75"(L)
• Inlet: 2.25 inch
• Outlet: 3.75 inch
• Length: 9 inch
• Fits: 1.5 inch - 2 inch
• Resonated: Yes
• Cut: Slant
EX-1013
Description:
• UPC: 757558509034
• Weight: 1.55 lbs
• Dimension: 9"(H) x 4"(W) x 4"(L)
• Inlet: 2.875 inch
• Outlet: 3.875 inch
• Length: 9 inch
• Resonated: Yes
• Cut: Slant
EX-1010
Description:
• UPC: 757558509003
• Weight: 1.7 lbs
• Inlet: 2.875 inch
• Outlet: 3.75 inch
• Length: 9 inch
• Resonated: Yes
• Cut: Slant
Edit: After reading reviews and questions at Amazon on the EX-1012 and EX-1013 the EX-1012 is too small for the FR-S exhaust pipes. That's why those that purchased it had problems installing it. It's made to fit 1.5" to 2" exhaust pipes. The EX-1013 or EX-1010 is the correct size.
[ame="http://www.amazon.com/DC-EX-1013-Stainless-Resonated-Exhaust/dp/B003D4KA32/ref=pd_sim_sbs_auto_1?ie=UTF8&refRID=1JKNHGC4FCGAH E9EMYVF"]http://www.amazon.com/DC-EX-1013-Stainless-Resonated-Exhaust/dp/B003D4KA32/ref=pd_sim_sbs_auto_1?ie=UTF8&refRID=1JKNHGC4FCGAH E9EMYVF[/ame]
[ame="http://www.amazon.com/DC-EX-1010-Stainless-Resonated-Exhaust/dp/B003D4I89U/ref=sr_1_1?s=automotive&ie=UTF8&qid=1419041783&sr= 1-1&keywords=DC+Sport+EX-1010#productDetails"]http://www.amazon.com/DC-EX-1010-Stainless-Resonated-Exhaust/dp/B003D4I89U/ref=sr_1_1?s=automotive&ie=UTF8&qid=1419041783&sr= 1-1&keywords=DC+Sport+EX-1010#productDetails[/ame]
You can get 2- EX-1013 from Advance Auto for $33.98 + tax with code TRT25, $20. off $50., pickup at store or
2-EX-1010 for $29.89 + tax with code MISSUN43 (expires 12/22), 35% off, pickup at store. http://shop.advanceautoparts.com/web...hedFrom=header
RickyBobby is offline   Reply With Quote
The Following 2 Users Say Thank You to RickyBobby For This Useful Post:
Gunman (12-20-2014), spdfreak (03-14-2015)
Old 12-20-2014, 10:53 PM   #88
I have the EX1017B (Black, Oval shape) and they fit fine, been on since 2012. If you search on Pepboys there was a lot of discussion around the variants when the car came out. Lots of folks bought them.
Old 12-20-2014, 11:28 PM   #89
Gunman
Drives: 2019 Mazda Miata RF
How about a shot from the side, so we can see how far they extend back, (stick out)?
Originally Posted by Felix7007 View Post
DC Sports EX-1013 from Advanced Auto Parts. $27 each.
I had to cut one of my exhaust tips off too. I soaked both bolts in liquid wrench for 10 mins and Very gently unscrewed them. The screw felt like it was coming out ok but when I looked at it, it was twisted off.
Any way, they are installed and looking good. Car is dirty though, Much salt.
Old 03-11-2015, 03:00 PM   #90
Felix7007
Drives: Scion FR-S Black
I do not have a side shot but I stuck them out about a half inch by choice so you can see the DC logo when you look at them from above. You can make them flush no problem.
Felix7007 is offline   Reply With Quote
The Following User Says Thank You to Felix7007 For This Useful Post:
Gunman (03-11-2015)
Old 03-14-2015, 01:55 PM   #91
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
You got me a free clay bar kit. Thanks!
spdfreak is offline   Reply With Quote
Old 04-24-2015, 04:06 PM   #92
PNA
Drives: 2013 BRZ Sport-tech
I removed the 10mm bolt below my original tips, but I can't seem the take off the tip!
Any tips?
Should I just pull harder straight out? I did try already.
Do I need to hit it? If so where?
Is there something more than the bolt that needs go be removed?
PNA is offline   Reply With Quote
Old 04-24-2015, 04:11 PM   #93
FatFree
FatFree's Avatar
Drives: 2013 Asphalt FR-S
Any tips?
Maybe try to twist the tip a bit as you pull it off. It's just that one bolt.
FatFree is offline   Reply With Quote
Old 04-27-2015, 04:42 PM   #94
PNA
Thanks you're right.. twisted right off.
Old 05-27-2015, 10:38 AM   #95
ray_viva
Drives: Scion FR-S
Mine twisted right off too
ray_viva is offline   Reply With Quote
Old 05-27-2015, 12:22 PM   #96
KungFuWaffle
KungFuWaffle's Avatar
Drives: Whiteout
JDM tips for perfectly on the car, just remove and replace
KungFuWaffle is offline   Reply With Quote
Old 05-27-2017, 05:46 PM   #97
stranger things
The Upside Down
stranger things's Avatar
Drives: '13 FR-S
I tried installing aftermarket tips today. I sprayed both bolts w/ WD40, then attempted to loosen each bolt. Well, I loosened each one just a tad, and then the bolt heads broke off.
I don't have a power drill (just a power screwdriver), so I don't think I can extract the bolts. I tried sticking needle-nose pliers in through the back of the exhaust tip to see if I could loosen the bolt, but not enough grip/leverage. I might just end up returning the aftermarket tips and stick w/ the factory ones.
stranger things is offline   Reply With Quote
Old 05-27-2017, 06:50 PM   #98
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
If you don't have the tools almost any muffler shop will fix the screwup and install your tips for like 20 bucks max.
T1R exhaust for the FRS/BRZ ! AJ PwR Engine, Exhaust, Transmission 57 06-22-2013 11:39 PM
AVO Exhaust Blaaaack-BRZ Engine, Exhaust, Transmission 22 10-17-2012 12:28 AM
HKS Exhaust 01s0uljah Engine, Exhaust, Transmission 1 05-18-2012 10:15 AM
Removal of Radio/Infotainment Unit Captain Snooze Electronics | Audio | NAV | Infotainment 6 03-20-2012 08:46 AM
ft 86 exhaust dalli Scion FR-S / Toyota 86 GT86 General Forum 11 09-08-2010 11:16 PM
