View Poll Results: Have you blown your stock motor with boost?
Yes complete failure needs rebuild 32 5.39%
No been boosting and running strong 188 31.65%
Nope because I am not boosting my motor 374 62.96%
Voters: 594. You may not vote on this poll
Old 05-13-2015, 09:27 PM   #393
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by xxscaxx View Post
No car can handle boost without a good tune if you want to get technical.
You guys are missing the main point...a good tune AND internals is what I was saying...
A good tune is always a necessity for a car boosted by the aftermarket, it's the apparent necessity of internals (even at low boost levels) that seems troubling for the 2013 motors.
Old 05-14-2015, 10:02 AM   #394
xxscaxx
Drives: 2013 SWP BRZ
I know exactly what you are saying, but a good tune is a necessity over anything else. Despite this thread there are many stock motor boosted twins out there that are fine. Hit or miss really. I still think the sample is still too small.
I ran an innovate kit on my brz for close to 15k miles, and now have made the transition to a turbo kit. Will be putting more power down, so i'm crossing my fingers I don't get added to the list. But I already accepted the fact that this motor may one day blow up regardless and am prepared for it in case it does happen. I probably wouldn't have even touched my setup if my car stopped being my daily and I had to drive it everyday.
xxscaxx is offline   Reply With Quote
Old 05-14-2015, 11:07 AM   #395
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
12.5:1 Naturally aspired engine running forced induction
FIFY
Tell a small block Chevy engine builder you're running 12.5:1 + 8psi on pump gas and he either; A. won't believe you, or B. have a heart attack.
Scott@HKSUSA is offline   Reply With Quote
Old 05-14-2015, 11:46 AM   #396
AVOturboworld
Originally Posted by FrX View Post
The car was tuned by James @ HRI. It was pretty conservative. None of the other three cylinders showed any sign of detonation or anything. Previous logging showed solid fueling and no knock. So I doubt it was tune related (except for increased rev limiter).
On the AVO base map (pre-James) it made 250whp at 8psi. Running 5w-30 Redline. Oil temps weren't logged. But as above I was only a few laps in, so they probably weren't very high. Pretty sure it wasn't a lubrication issue.
Ah man, I'm really sorry to see this! Let me know if there's anything you need from us!
We keep the standard rev limit on our base maps and tunes, even Ross's race car sticks to the standard rev limit since he is running a standard block and heads.
Old 05-14-2015, 02:37 PM   #397
solus
Drives: 2014 Scion FRS (Ultramarine)
I seriously doubt any of these engines that have popped are the result of a bad tune from any of the reputable tuners around. They pop for any number of reasons more then likely related to stress... Either too much boost, too much engine stress from tracking, mechanical errrors or a whole myriad of other possible issues. The tune is only one factor in boosting a car. Even a near perfect tune isn't going to save you if your rods are weaken due beating on the car or running ridiculous amount of boost. The reality is that these engine were not designed for boost and getting them to run boost while possible is just opening it to risk. Its a risk i've chosen to take... I'm running AVO kit, 8psi, E85 on stock fuel system... With a tune from Delicious Tuning and a previous tune from Drift Office. I don't track and this is my daily. I know the risk, can you boost it? Yes, can it be reliable? somewhat... Its just risky and up to you to accept that risk.
solus is offline   Reply With Quote
Old 05-14-2015, 02:58 PM   #398
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by IBill4You View Post
Do we have enough failures with details to point to a common theme?
Bearings, people money shifting, rocker arms designed on the back burner.
Old 05-27-2015, 12:36 AM   #399
Kojiro
Drives: 2014 Black BRZ Limited
Just my little input: stock motor, kraftwerks c38 kit, 550cc injectors, tuned
by Moto-East. Around 3k miles put on and still running damn strong.
No issues or CEL, planning on running the smaller 70mm pulley soon.
Kojiro is offline   Reply With Quote
Old 05-27-2015, 02:29 AM   #400
350matt
Drives: toyota mr2/ Toyota GT86
I'd be interested to poll just how far the boosted set of motors have run for ?
as OEM's pass off an engine spec typically with a mix of looong dyno tests like 100hours at full throttle and full rev's or 400 hours mixed running
or the thermal shock test where the engine is chilled down to -10 deg C and then started, idlied for 30 seconds tehn given full power and revs for a minute then stopped and chilled down again - and this process repeated for 100 times
so to say that my motor has done 3000 miles on the road ( where you are rarely on full load for more than 10 seconds at a time) and then say these motors are fine boosted well...........
time will tell gentlemen, its too early to say otherwiseas I don't think anyone has put big miles on a boosted motor yet
350matt is offline   Reply With Quote
Old 05-27-2015, 02:43 AM   #401
Billion
Drives: 2013 Toyota 86
This guy has put a fair few miles on his car running 19psi
http://www.ft86club.com/forums/showthread.php?p=2248340
Billion is offline   Reply With Quote
Old 05-27-2015, 11:28 AM   #402
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
FA20CRAP TURBO KIT
Garrett T3/T4 57 TRIM
25 XXX KM on the turbo
Still good, no cel or anything. No track days, done some drifting though
Scalzo is offline   Reply With Quote
Old 05-27-2015, 11:35 AM   #403
raven1231
Originally Posted by Scalzo View Post
FA20CRAP TURBO KIT
What PSI and power levels are you at?
Old 05-28-2015, 10:57 AM   #404
Scalzo
Scalzo's Avatar
Running 9psi on 94 oct (haven't been dynod)
299whp on e85 @ 7psi
Old 05-28-2015, 11:54 AM   #405
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
@King Tut
Add me to the list...
AVO Turbo Kit - full 3" catless exhaust
-Ecu Controlled boost 10-15psi
-Overboosted to 22psi in 5th gear on the highway and developed a knock (all vacuum lines intact)
-23,000km with no issues up until this
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
Old 05-28-2015, 01:58 PM   #406
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Wastgate clevis bind up? I bet it was fun for the few seconds it lasted.
FrX is offline   Reply With Quote
How much HP can the stock motor handle? FullTuneZN6 Engine, Exhaust, Transmission 34 11-16-2017 01:22 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
FBM 604Hp 472Tq -- Stock Motor Stage 2 Turbo Kit FullBlown Forced Induction 414 07-14-2014 09:52 PM
FRS300 Rebuild Has Begun..Blown Motor to Built Monster FA20Club.com Forced Induction 917 10-20-2013 06:26 AM
Highest HP on stock motor using only 93/94 octane? hmong337 Forced Induction 11 09-09-2013 10:53 AM
