| Hawaii Aloha! |
Drives: 2013 BRZ Premium Black
Clutch Fork Squeaks
Hi everyone,
So I'm 36k miles and the other day when depressing the clutch pedal I had the sound like a leaking master or slave cylinder, but as it turns out it may be just the clutch fork. This apparently happens a lot on our cars and just wanted to inform you all that you can get marine grease and lather that sucker on the unit.
#2 |
Waited 5 years for this
Drives: '18 MX-5 Club
Mine has been doing that for the last 4k miles. It started when it reached 20k miles. I've been keeping an eye on this thread, but there doesn't seem to be many people with this problem compared to the other problems. The thread gets buried quickly.
How easy is it to do this? I'm debating to bring my car to Servco because this only happens after I drive it for 1/2 hour. They usually take the car early in the morning and don't work on it until later. The noise would go away by then. |
#3 | |
Its exposed. No tools needed. Just wipe away the old gunk with a towel and smudge on the new lube. 30 secs. The logest part of this process is going to the store and buying haha. Ill include pictures in next post
#4 |
Oh after you lupe, the sound will still be there give it about a day for it to work in. Here's the pic.
https://www.facebook.com/photo.php?f...type=1&theater |
#5 |
Hot Lava Lover
Drives: 2013 Scion FR-S- lava
I had this problem and took it into the Toyota shop last week. They lubed it and told me to give it a week or two. The noise went away but is back again. I don't really want to go back to the shop again but looks like I may have to.
#6 | |
Keep putting marine grease on it. It'll go away. |
#7 |
Hot Lava Lover
Update
So the squeaking came back and I took it to the Toyota dealer yesterday. They spent about an hour working on it and I drove away to do some errands. Sure enough, the squeaking came back. I was pissed to say the least and drove it back to the dealer. The technician took a look at it and confirmed that the noise was coming from the inside as opposed to the exposed clutch area. They took an hour researching the issue and the rep told me that the technician spoke to Toyota's engineers and they only found one case where this was an issue. In that case, they opened up the transmission and determined that it was a lubrication issue. He told me that if it was a lubrication issue, it would not be covered under the warranty and I would have to pay for it.
The rep said that it could also be a clutch issue in which case it would also not be covered. He said that they could open it up and if there is indeed a part that is covered under the warranty, then no problem. I asked him if the one case that was a lube issue, did the customer have to pay. He couldn't tell me so I spoke to the service manager. I explained to him what was going on and he said the squeaking was actual common. I was pissed and told him that was not what the rep told me. Any way, he spoke to Toyota and they will cover the charge to open it up and lube the fork or fix any other problems, except if it is the clutch. I said fine, do it. I spoke to a tech at a different place and he said it sounded like the throw out bearing. He said Subaru has had this problem and it was just a matter of replacing it and putting a rubber sleeve around it to protect it. I will find out Monday what happens.
#8 |
Hot Lava Lover
I got my car back today and the tech told me that it was just a lubrication issue. He said the fork was bone dry. They did not charge me for the service and it is now running like a champ.
#9 |
Anyone got this fixed by Servco? Just wondering if anyone already got it fixed by them. I'm taking mine in next week.
#10 |
No point having them take your car for over an hour haha... Just get marine grease ($5) and grease the fork location, just make sure to clean it first. Takes less than 5 mins of work.
#11 | |
#12 |
Hot Lava Lover
warranty
It will most likely keep coming back like mine did. If you are still under warranty, ask them to do a courtesy service. They had to pull out the tranny to get to the fork I was talking about it my recent post. They wanted to initially charge me over $1200 because of the labor. There must have been other issues reported because Toyota USA covered the charge.
#13 |
Fantah,
How did you lube yours? Maybe I'm lubing incorrectly. The longest it lasted is 3 weeks. It usually comes back in a week. I wipe the old lube with a cloth. Then apply a thin layer to marine grease with fingers rubbing around the silver metal part in that picture with red circle. Is that how you did it? Last edited by Sigh-on-Rice; 08-20-2015 at 03:50 PM. |
#14 |
Drives: Ultramarine
Having the squeaking issue too and it sounds like it's coming from inside the cabin
| Rattles/Squeaks in the BRZ? | cammyfive | BRZ First-Gen (2012+) — General Topics | 190 | 01-12-2017 10:24 PM |
| Squeaks when shifting gears/happens every 15 or so seconds while holding speed | Simon99 | Issues | Warranty | Recalls / TSB | 10 | 10-11-2014 03:54 PM |
| door handle/pull squeaks | NRG x FRS | Issues | Warranty | Recalls / TSB | 1 | 11-27-2013 09:38 PM |
| I knew about cabin squeaks before I bought the car but... | NOMNOM | Issues | Warranty | Recalls / TSB | 10 | 05-23-2013 05:00 PM |
