Old 05-22-2015, 08:42 AM   #211
Bergen23
Drives: '15 Halo FR-S
Ya, I know. I even stated "random samples without shopping around". f course you can make either car as costly or as cheap to operate as you wish but on average the operating costs of the Porsche is going to greatly exceed most Twins.
Pretty sure the blinker fluid in the Porsche is going to be far more expensive than on the FR-S. When I had my first oil change done, the dealership told me my blinker fluid needed replacing and they only charged $20. Imagine how much it would be at a Porsche dealership!
Bergen23 is offline   Reply With Quote
The Following User Says Thank You to Bergen23 For This Useful Post:
Tcoat (05-22-2015)
Old 05-22-2015, 09:52 AM   #212
Well as long as they didn't do what they did to me! The fools put the red in the right side and green in the left! Took a $500 flush to fix it.
Bergen23 (05-22-2015)
Old 05-22-2015, 01:52 PM   #213
Re~Mix
Re~Mix's Avatar
Drives: 13' Scion FRS MT
Originally Posted by Jaden View Post
I would imagine that a fully built motor would still put you in below the cost of the first for sure and probably the latter too.
Jaden
Dropping $5-7K on a forced induction setup, another $2.5K on brakes ticks the price of my current FR-S up to almost $40K (given full exhaust, wheels/tires). At $40K i'll take the car sorted out by engineers. I love my tuned FR-S, however it is a bit rough around the edges in a way an OEM car never is.
My current plan is to get some serious seat time in the Cayman S and see how much of an improved FR-S it really is.
07' Z4M Coupe | KW Clubsports | AFE Intake | Stromung Mufflers | UUC Shortshifter | Advan RS
15' 228i MSport
13' FR-S | TRD CAI | TRD Catback | UEL Header | OFT Stg 1 | Rota Grid-V | RCE Suspension | Hankook |
Re~Mix is offline   Reply With Quote
The Following 3 Users Say Thank You to Re~Mix For This Useful Post:
strat61caster (05-25-2015), TemeCal (05-22-2015), Turbowned (06-08-2015)
Old 05-24-2015, 02:17 PM   #214
Turbowned
Turbowned's Avatar
I get 18-19mpg instead of 25-26mpg now... so there's that. It's $300/yr more expensive to insure (your results may vary). Consumables do cost more and you'll want to find a good independent Porsche technician to work on it if you're not handy turning your own wrenches. Obviously you shouldn't trust it to the minimum wage teenagers at Jiffy Lube (not that you should trust your FR-S/BRZ to them, either!)
If you buy a 996/997.1 or Cayman/Boxster with the port injected engine you will want to replace the IMS bearing if it hasn't been done already. The part itself is ~$800 and to pay someone to do it you should budget $2000 including the part. You shouldn't need to do it to the 996/997 Turbo or the 997.2/Cayman/Boxster with the direct injected engine. They are also known for cracking the plastic coolant expansion tanks which can be a bit of a PITA to replace; they turn yellow and crack with age. It's usually good to replace it, the water pump and thermostat all at once if you're dealing with a ~10yr old model. They're also known for having a wire off the alternator that's too small to provide sufficient grounding and it causes voltage drop and hard starting when hot. My car has this problem; it's $99 to fix through Suncoastparts.com
Had my 997 for three weeks now and I haven't looked back (I do miss the gorgeous Galaxy Blue color vs Arctic Silver, but that's it). I got invited to a Porsche driving experience at Thompson Speedway this past week where I got to thrash my 911 and a brand new Cayman S and Carrera 4S on the track; it totally validated my purchase! I have autocrossed my BRZ and driven a GT86 on the Nurburgring before and needless to say the 911 was much more satisfying to drive at the limit (assuming you have the driving skill - the BRZ is a better beginner's car). That being said, the consumable costs associated with racing a 911 are going to be higher than an FR-S/BRZ, stock-for-stock and mod-for-mod. You'll find that mods for the 911 cost as much as double, sometimes triple what they would cost for your average Japanese tuner car (I have no plans to modify mine like I did the BRZ; perhaps a set of OEM X51 headers, Fabspeed cold air kit and a Eurocharged ECU remap to bump the power up to ~380hp).
The 911 is also a much more pleasant car to daily drive. It has a slightly quieter cabin, considerably better stereo, less-notchy shifter, nice exhaust note, better steering feel, and of course, more power and torque. It's less twitchy on the highway and the suspension is slightly more composed although the fat rear tires do crash over bumps and tramline slightly on uneven surfaces. No bluetooth, nav, or satellite radio sucks but I plan to upgrade the head unit in the future.
I don't like the key being on the left hand side of the wheel, though! It's much more logical to insert the key on the right while you close the door with your left hand... Oh well; that's not going away anytime soon
The Following 2 Users Say Thank You to Turbowned For This Useful Post:
Re~Mix (05-26-2015), sprintertrueno86 (05-24-2015)
Old 05-25-2015, 02:32 AM   #215
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
MY2006 of porches had better IMS and RMS then the previous years. I too am looking into buying a 996 turbo or 987.2 Cayman S. The IMS doesn't cost $800. It is easy to install if your replacing your clutch; IMS and RMS are rare at that. MY2009+ no longer have IMS issues as they redesigned their engines.
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
The Following User Says Thank You to blackhawkdown For This Useful Post:
WolfpackS2k (05-26-2015)
Old 05-25-2015, 04:41 AM   #216
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Ive always been a fan of the Cayman's. I knew of the 987.1 IMS problem, which was why I was looking at an 09 for the dreams. Since they haven't been around as long as the 911, I keep hearing that the Cayman hasn't lived up to the Porsche stigma of reliability, which is a good thing. Although yes, consumables are considerably more expensive. But for the car you're buying (3x the price of the 86 when it was new) is understandable. There's even 987.1/2 single(?) turbo kits that make it a GT3RS fighter, but that's a whole different ball game.
Old 05-25-2015, 04:40 PM   #217
blackhawkdown
The 987.1 Cayman S has 295hp while the 2009+ Cayman S has the 3.4L Direct Injection engine 320hpish. The 987.2+ caymans are the refined versions of the later. But just because of that don't disregard the 987.1. The 987.1 IMS issues are very rare at that.
That being said, you can modify parts to increase power in a Cayman or Carrera all day long but you can't make a Mid-Engine Carrera. The RR layout on the Carrera is a turn off for me but a 996 Turbo is one hell of steal. Now only if I can afford the GT4 Cayman.
cdrazic93 (05-25-2015)
Old 05-25-2015, 05:25 PM   #218
serialk11r
Drives: '06 AM V8V Coupe
I think the best bang for the buck right now is the 987.2 base Cayman. I saw a 100k mile 2009 for something like 25k! More typical is like low 30s. The 981s look more high-end but for 30k, the exoticness per dollar is pretty high.
The 2.9L engine isn't DFI but it's the new architecture and makes solid power. It probably can make 280hp easily with light mods. Belt driven PS pump probably should be thrown out and replaced with an electric pump for reliability and some extra horsepower but other than that I couldn't find anything bad about those cars.
Plus, if you want to, you can make it extra lightweight by putting the aluminum Cayman R doors on or some similar replacement.
Old 05-26-2015, 03:28 PM   #219
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
This comment confuses me. The "Porsche stigma" is actually one of great reliability (996 model non-withstanding). Either way, the Cayman is a very highly rated car for long term reliability.
As to OEM pricing, every Porsche owner should be aware of the following two resources:
www.http://sonnenporscheoemparts.com
http://www.suncoastparts.com/
Wholesale prices for OEM parts. Either of these resources will beat the pants off the average local Porsche dealership.
The Following User Says Thank You to WolfpackS2k For This Useful Post:
cdrazic93 (05-26-2015)
Old 06-08-2015, 12:05 PM   #220
Turbowned
Turbowned's Avatar
My starter failed this weekend. I knew it was on its way out as it would take a while to start, but I was hoping I could hold out until I brought it in for the IMS bearing upgrade. Looks like I'm getting the IMS bearing done now! Luckily my indy tech has the parts in stock and the starter won't be much or any extra labor considering he's already in there. $250 for a new Bosch starter (Porsche wanted $1,100 for their starter; get f**ked!), $120 for the updated alternator/starter wiring harness, and a bit under $2,000 for the IMS bearing upgrade. My work gave me a rental in the meantime, so all is well.
$2,000 for the IMS bearing upgrade is cheap insurance against a $20,000 engine replacement.
Old 06-09-2015, 02:36 PM   #221
Champster
Champster's Avatar
Drives: Subaru BRZ 15, 997 Turbo 08, BMW 5
you should keep both. Actually I just bought both BRZ and 997.1 turbo just last week!
Since the roads around here are all messed up, I like to drive the BRZ more often that the 997. There's no need to be super careful about driving the BRZ, where as with the 997 turbo, I have to plan ahead of time about where I'm going to make sure I don't damage the car.
Champster is offline   Reply With Quote
Old 06-18-2015, 04:05 PM   #222
Turbowned
Turbowned's Avatar
That would be nice! Congratulations on the purchases! My daily driver is an RS6, which apart from the terrible fuel economy is a nice, comfortable car that I can take anywhere, but is still very fun to drive!
3,000 miles in 1.5 months of ownership; I need to stop driving this thing so much!
Old 07-01-2015, 11:28 PM   #223
Racecomp Engineering
FWIW.....my Cayman S is for sale ! ( post 63 )
(dont ask what I want to get to replace it)
Myles
Old 07-02-2015, 03:35 AM   #224
cookiesowns
Drives: WRB BRZ Series.Blue
Myles
PM details of the cayman.
cookiesowns is offline   Reply With Quote
GT 86 beats Porsche 911 Carrera MurderRider Scion FR-S / Toyota 86 GT86 General Forum 16 08-12-2014 03:08 AM
2014 Porsche 911 Carrera Opti Coat PRO Hamza7 CANADA 0 05-27-2014 12:43 PM
DetailersDomain.com - revives an 05 Porsche Carrera S DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 02-19-2014 07:38 AM
BRZ vs Porsche 911 Carrera S (Mile high mashup review) daiheadjai BRZ First-Gen (2012+) — General Topics 1 06-04-2013 04:57 PM
Scion Fr-S vs 25K 2002 Porsche 911 Carrera FR CANADA 13 05-18-2012 12:16 PM
