Old 05-19-2015, 06:11 PM   #3361
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
[ame]http://youtu.be/QuJt8xp06X8[/ame] Can anyone tell me what is this noise that come from SC?? I guess it is a pulley when it get hot
scionfr_s is offline   Reply With Quote
The Following User Says Thank You to scionfr_s For This Useful Post:
zoth (05-19-2015)
Old 05-19-2015, 06:21 PM   #3362
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Cogged belt is too tight.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 05-19-2015, 08:31 PM   #3363
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
Just checked it, it exactly 21mm from the plate to under the bolt head like instructions said,
Old 05-19-2015, 09:11 PM   #3364
SPCorBUST
SPCorBUST's Avatar
Try the Gates belt app, it might help. The frequency you need is in the set of directions for the kit.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following User Says Thank You to SPCorBUST For This Useful Post:
scionfr_s (05-19-2015)
Old 05-19-2015, 09:14 PM   #3365
zoth
zoth's Avatar
Not all belts created equal, you have to find your sweet spot for the belt. It's going to take some time. Trial and error my friend.
The Following User Says Thank You to zoth For This Useful Post:
Old 05-20-2015, 02:08 PM   #3366
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
They should get rid of the 21mm instruction in the manual. I installed mine that way and it was way too tight.
I really wished they put a spring loaded tensioner to rid of all the guess work.
Another issue I had was the pulley came installed on the blower unit but the bolts were semi tight (checked quickly by a small hex key). I was stupid and assumed they were torqued/loc-tite by KW. Pulley fell off 3000km later and luckly only broke the belt and scratched things up. They should have just left the pulley off or torqued them. Either way, KW has good customer service. They replaced my pulleys, belt and fluid for free.
projek_01 is offline   Reply With Quote
The Following User Says Thank You to projek_01 For This Useful Post:
DAN_BRZ (05-20-2015)
Old 05-20-2015, 03:47 PM   #3367
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
How are you checking your belt tension now? The 60hz with the gates app?
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
Old 05-20-2015, 04:25 PM   #3368
vgi
Drives: frs
yep. and standard belt instead of the cogged one. that'd be the kit!
vgi is offline   Reply With Quote
Old 05-20-2015, 04:26 PM   #3369
vgi
Drives: frs
sounds the same as when i got a seized tensioner pulley bearing. KW guys though were awesome and replaced it in no time.
Old 05-20-2015, 04:57 PM   #3370
projek_01
projek_01's Avatar
That app never gave me any constant numbers. I gave up after it kept giving me random frequencies. I just kept adjusting it till I saw minimum belt slap. Still whines a tiny amount at idle and definitely audible at any speed above idle.
Old 05-20-2015, 05:01 PM   #3371
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
That app didnt give me constant numbers. I just kept adjusting it till I saw minimum belt slap. Still whines a tiny amount at idle and definitely audible at any speed above idle.
Okay, same here with the app giving inconsistent numbers. I couldn't figure out a way to correctly hold my phone and pluck the belt.
I think I'm going to have another look at my belt since I can't hear it at all right now. Figured it was just due to switching from smooth idlers to cogged ones.
KW V3
Old 05-20-2015, 05:56 PM   #3372
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
a whine at idle would mean the belt is too loose/tight? i have a whine at idle which gets louder at the rpms climb. ive been messing around with the belt the last few days trying to find the sweet spot.
installing KRAFTWERKS C38 FROM RICKSPECD MOTOEAST TUNE & SKUNK2 ULTRA RAD / SANDWICH PLATE / GRAMS 550cc
JDL UEL PERRIN EXHAUST 2.5" OP 3" CATTED F 3" CATBACK - PERRIN MOUNTS PERRIN PULLEY KIT WHITELINE BUSHINGS WILDWOOD BBK ACT CLUTCH & FLYWHEEL KW V3 MTEC KARTBOY SS SEIBON ROOF SPOILER & FRONT LIP 57XTREME 18x9.5 +40 W/ 255/55/R18 MICHELIN PSS
DAN_BRZ is offline   Reply With Quote
Old 05-20-2015, 05:57 PM   #3373
Triumphrider
Triumphrider's Avatar
Drives: 2013 Scion FRS in white out
At idle I have no whine, but anything above idle you hear it
2013 Scion Frs AT in Whiteout, Borla UEL header, Greddy SP Elite AxleBack. Kraftwerks C38 Supercharger tuned by Moto East and 2 kid seats in the back.
Triumphrider is offline   Reply With Quote
The Following User Says Thank You to Triumphrider For This Useful Post:
zoth (05-21-2015)
Old 05-20-2015, 10:15 PM   #3374
scionfr_s
scionfr_s's Avatar
Drives: Scion FR-S
Tension bolt?it didn't make any different even I'm losing it, tension pulley still spin
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 11:58 PM
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 01:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 01:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 06:27 PM
