#71 | |
#72 |
Drives: FRS
I am not sure if I mentioned this before, but I got my suspension installed, corner balanced and aligned. I ran the car on stock tires and it was awesome. Decided to upgrade to lightweight wheels and MPSS and it was actually the tire/wheel change that, some how, made the VSC way more sensitive. Same suspension and alignment, but as soon as I swapped tires and wheels it started acting up....
I went to the alignment shop today and they had no idea what could be causing it. They said they would put the car on the rack and re check my alignment if I wanted. Still hoping the VSC re set will fix it. Will be doing it over the weekend . |
#73 |
Drives: 2016 FR-S
Have you tried disconnecting the battery for a few minutes?
#74 |
Drives: 2015 Raven FRS
Ya, I've also done a lot of track days and not seen this problem before either.
#75 | |
Are you possibly overdamped and getting some wheel skip?
#76 | |
Drives: '13 Firestorm FRS
#77 | |
Drives: FRS
Coilovers are set very soft. |
#78 |
Drives: FRS
#79 | |
For everyone having this issue, is VSC actually more intrusive or is the car breaking traction easier?
#80 | |
Drives: 13 GBS BRZ
I'm on RCE Tarmac 0's, 17x9 wheels with 245/40 PSS's. Alignment is F/R -2/-1.5 camber 0/.02 toe in. |
#81 |
Bizarre... in "normal" or sport mode I can definitely feel slip before the VSC steps in.
#82 | |
Drives: FRS
#83 |
Drives: FRS
Has anyone tried disconnecting their battery for a few mins? Seems like a good idea to try anyway...
#84 |
Drives: 2013 brz limited
| How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely | Sigh-on-Rice | DIY (Do-It-Yourself) Guides | 58 | 03-02-2015 01:48 PM |
| Vehicle Stability Control | twostroke | BRZ First-Gen (2012+) — General Topics | 15 | 07-13-2014 11:10 AM |
| Stability Control? | ashtray | BRZ First-Gen (2012+) — General Topics | 27 | 01-24-2013 05:32 PM |
| TPMS, LSD and Stability Control | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 11-05-2012 04:12 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 11:20 AM |
