#575 |
Hail Magnet
I have my guess, but what does removing the spring do? I mean what is the physical difference, not just "it improves the feel."
Based on what I am reading, the spring makes the pedal come all the way up, whereas without the spring, the pedal only comes back as far as the clutch spring itself would force it. Only downside is that it could "flop" around at the top of the stroke. Am I close? |
#576 | |
Drives: 2015 FRS 6MT
The reason that the feel is improved is that the factory pedal return spring is powerful enough that it (in my opinion, completely) masks the force from the clutch spring. The slop is really minimal, likely no more than a quarter to half an inch at the top. The perfectionist in me would really like to resolve that slop, even though I don't believe it's enough to cause any functional issues. Truly after a few days I've stopped noticing it as much. |
| The Following User Says Thank You to Subscap For This Useful Post: | xxBrun0xx (05-21-2015) |
#577 | |
Hail Magnet
#578 | |
The only plausible concern (read: incredibly unlikely) would be extra clutch disk wear from the weight of the pedal itself possibly exerting pressure on the hydraulic system and ever so slightly disengaging the clutch. Again - highly unlikely this would actually happen. |
#579 | |
Hail Magnet
...so I think I may look into removing the spring now
#580 |
You're going to love actually having feedback from the clutch! Keep us updated
#581 | |
Alexandrino_Auto
Drives: series.Blue
The Shadetree Project: I turn wrenches
| The Following User Says Thank You to Hyper4mance2k For This Useful Post: | shiro (05-13-2015) |
#582 | |
I'm still playing with ideas to get a super weak spring hooked up to ONLY eliminate the slop. If/when I get around to it, I'll definitely update. |
| The Following User Says Thank You to Subscap For This Useful Post: | Hyper4mance2k (05-13-2015) |
#583 | |
Alexandrino_Auto
Drives: series.Blue
| The Following User Says Thank You to Hyper4mance2k For This Useful Post: | Subscap (05-13-2015) |
#584 |
Drives: 2014 FR-S
FWIW I've had the MTEC spring in for a couple weeks and I'm quite happy with it.
The MTEC is just the right amount of compression, anything weaker probably can't hold up the weight of the clutch pedal. I don't buy into the premature seal failure explanation, though. I wouldn't expect any long-term issues running springless but I don't claim to be an expert on the subject either. |
| The Following 2 Users Say Thank You to kbye For This Useful Post: | Hyper4mance2k (05-13-2015), Subscap (05-13-2015) |
#585 |
Drives: '22 BRZ
The seal failure thing is baloney. The force to push on the master cylinder is coming from somewhere, either the assist spring or your leg...
#586 | |
At factory height adjustment, the clutch assist spring is ever so slightly over center so it pushes the clutch pedal away from the floor. When the clutch pedal is depressed, very early in the arc, the mode changes so the spring, as it decompresses, applies force in the direction of pressing the clutch pedal. It pushes the same direction as your foot. This is why some people who have aggressively lowered their clutch pedals without removing the spring report having to sometimes pull back on the pedal to raise it completely. The device never gets to that neutral point where it no longer applies downward force on the pedal. edit: No. My above statement is BS. The mode does change early in the arc but the motion profile is shallow until well into the pedal arc. The assist spring doesn't do much until the pedal is about halfway depressed. I believe this may also be the cause of some of these premature throwout bearing failures but have no hard evidence to support the theory. edit: Nope. Nevermind. I was wrong.
Last edited by Ultramaroon; 06-10-2015 at 11:18 PM. Reason: uggh... more backpedaling |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Celadrielas (05-13-2015) |
#587 | |
Drives: 2013 Asphalt Fr-S
I actually decided I was going to try to reset this back to stock. I've done my best but I've been driving with a slightly lowered clutch pedal for about a year, so I've forgotten. during a different service, I asked the dealership to see if they could "Check the clutch height for me". My paperwork came back with the folowing note: "There is no clutch adjustment for this vehicle. While slightly lower than other FRS on the lot, there appears to be nothing out of alignment or harmful with the vehicle." --- I guess, to me, that means if it WAS aggressively low, it could be damaging to the vehicle, in theory. Or the toyota mechanic was a complete idiot. But you know... which ever
| The Following User Says Thank You to Celadrielas For This Useful Post: | Ultramaroon (05-17-2015) |
#588 |
Drives: Splash Mountain
I tried to do the clutch adjustment but the 12mm was so damn tight I couldn't loosen it. anyone else have that issue?
| Tags |
| clutch adjustment, clutch helper spring |
| power steering feel adjustment | brillo | Engine, Exhaust, Transmission | 29 | 11-06-2017 03:41 PM |
| BRZ front camber adjustment confirmed | sparks | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 03-28-2013 10:17 PM |
| Any (easy) way to stiffen up the feel of the clutch? | Partial Stall | Engine, Exhaust, Transmission | 41 | 07-19-2012 02:17 PM |
| My Great Experience at Scion of Glendora *LONG, BUT AN EASY READ* | wanger | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 06-02-2012 01:41 PM |
| ATS carbon clutch collaboration model prototype clutch 86 & BRZ | kanundrum | Engine, Exhaust, Transmission | 41 | 02-27-2012 03:48 PM |
