Old 05-09-2015, 12:43 PM   #1
Zzzquil
Zzzquil's Avatar
Hear Tire Rotate
I just recently replaced my tires, wheels and suspension (coilovers, rear LCA's, & front camber plates). I'm not sure if this sound was there before the alignment, but I can now hear my tire rotate at low speeds (rather than at high speeds due to road/exhaust noise becoming too loud). I would say its more on the driver rear tires than anything.
Specs:
-225's w/ 18x8.5 & 245's w/ 18x9.5
-Dropped 2"
-Tires are tucked in fender
*-2.5 camber in the front and -2 in the rears with toe angles .02f and .24R
Video of noise:
https://vid.me/MWSe
Zzzquil is offline   Reply With Quote
Old 05-09-2015, 02:09 PM   #2
stevesnj
stevesnj's Avatar
Sounds like something is scraping on something.
My 2016 Build thread
Old 05-09-2015, 05:42 PM   #3
Zzzquil
Zzzquil's Avatar
That is what I was thinking. Either something came loose, going bad, or its scraping on something else. Any ideas to what could be the culprit?
Old 05-09-2015, 06:23 PM   #4
stockysnail
Just the tip
stockysnail's Avatar
Check to see how much clearance you have with the inside of your tire to see if it may be rubbing on the suspension.
Also try raising it up 2" on each side since you have coilovers to see if it's related to how low you are.
What tires did you put on? Some tires make a lot of road noise.
Old 05-09-2015, 06:32 PM   #5
swarb
rock or something stuck in the tire
Old 05-09-2015, 08:07 PM   #6
Zzzquil
Zzzquil's Avatar
I'll give that a try tomorrow and let you know if it solves my problem or not. I'm also getting a somewhat of a high pitch (scratching?) sound when I turn right at low speeds. And here I thought that this upgrade was going to go smoothly...
Tires: Hankook evo v12's
I'll examine the tires for rocks tomorrow. I really hoping it is just a rock stuck in the tire
***I forgot to mention that once I installed the coilovers (KW V3), I had to cut a small portion of the front end links as it was hitting the control arms every-time I went over bumps making a clunking sound***
Old 05-12-2015, 05:03 PM   #7
Zzzquil
Zzzquil's Avatar
It turns out it was my wheel slightly rubbing against the swaybar. My solution is to get Adapters & Spacers to make the wheel give a little more clearance.
Old 05-12-2015, 05:12 PM   #8
swarb
front or rear? What profile tires?
Old 05-12-2015, 05:16 PM   #9
Zzzquil
Zzzquil's Avatar
Front right & Hankook's evo v12
Old 05-12-2015, 05:33 PM   #10
swarb
Specs:
-Dropped 2"
Video of noise:
https://vid.me/MWSe
I am only asking so it can help people in the future. There is a lot of missing information.
1. wheel sizes, including offsets.
2. suspension setup brand, camber plates, alignment etc.
3. tires, including full tire size, width, and aspect ratio.
4. what did you do to fix it and how close is it after fix.
Are you using the stock endlinks for the sway bars?
Rotate my own tires? zinzan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 03-28-2014 01:13 PM
Something you all need to hear. NoMoCouch Scion FR-S / Toyota 86 GT86 General Forum 46 01-07-2014 10:36 PM
Fuel Injectors, are they supposed to rotate around? rb6freak Engine, Exhaust, Transmission 2 12-22-2013 10:02 PM
Dying to hear this!!! sweetfrs Engine, Exhaust, Transmission 8 09-19-2013 10:17 PM
How did you hear about your FRS? bdanisi Scion FR-S / Toyota 86 GT86 General Forum 26 01-21-2013 01:14 AM
