Old 04-15-2015, 04:16 PM   #673
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by ck-GT86 View Post
Quick update, I tried this formula and the readings were off since I read my temps in F. Removed everything besides "AC-40" and all worked once the car was turned on. Also set the last parameter to "auto"
.ck
If it was already reading in F then you should be good.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following User Says Thank You to Synack For This Useful Post:
ck-GT86 (04-15-2015)
Old 04-15-2015, 05:04 PM   #674
Synack
Boosted
Synack's Avatar
Drives: Sideways
My car is older and has one of the first ECU's and it only reads Celcius AFAIK.
Old 05-09-2015, 07:15 PM   #675
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
I got a new bluetooth OBDII reader over the winter when my other one stopped working and now my oil temperature PID is not working.
It is showing values from 4000 to 25000 and it is rpm based.
Anyone have an answer to this?
ToyoburuBRZ is offline   Reply With Quote
Old 05-10-2015, 01:00 AM   #676
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Anyone with OEM tune care to share what their normal operating range for Manifold Air Pressure (MAP) is? I know at sea level with the engine off it is about 14.7 PSI. With the engine on at idle I'm in the range of 5 PSI (10 PSI of vacuum) and its goes up well past 20 PSI as I redline because I'm boosted. I have an aftermarket 4-bar MAP sensor so I just wanted to see what a stock MAP reads like. Not sure if I need to recalibrate anything.
mit_peid is offline   Reply With Quote
Old 05-10-2015, 10:44 AM   #677
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Took a quick look at my logs, not quite sure what the units are, but I'm reading about 1.7 to 14.2 (psi?) range (up to 6k rpm). Hope that helps.
The Following User Says Thank You to BigFatFlip For This Useful Post:
mit_peid (05-10-2015)
Old 05-10-2015, 11:28 AM   #678
mit_peid
Boosted Noob
mit_peid's Avatar
I think that kind of makes sense. The stock NA engine sucks ~12 PSI of vacuum at idle, and my Rotrex supercharger offsets that by +~3 PSI at idle. My peak reading at around 25 PSI is when the engine no longer has a vacuum and the blower (without the smaller pulley) is pushing about 9 PSI. Someone else can call BS on me but I think that is what's happening. Thanks!
Old 05-11-2015, 09:44 PM   #679
Astroboy
Astroboy's Avatar
Drives: None
Can you regulate knocking on the torque app. If so, Under which display can I see if my car is knocking?
Astroboy is offline   Reply With Quote
Old 05-12-2015, 01:55 PM   #680
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You can download a plug-in for torque that analyzes and tests for detonations (aka knock)
The Following User Says Thank You to SkAsphalt For This Useful Post:
Astroboy (05-12-2015)
Old 05-12-2015, 02:08 PM   #681
Astroboy
Astroboy's Avatar
Drives: None
Where can I do that?
Old 05-13-2015, 12:38 PM   #682
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Knock sensor is on the Google Play Store. Or I think there is a plug-in's browser in Torque itself. One of those two
Astroboy (05-13-2015)
Old 05-29-2015, 12:24 AM   #683
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I know it's been mentioned before in regards to a different car, but how accurate is the boost reading on our car on stock sensors?
Just want to make sure I'm not missing anything before I bug my tuner.
I'm only seeing a max of 5.2 psi when I should be seeing something closer to 9.
Old 05-29-2015, 02:14 AM   #684
raven1231
Are you using the stock map sensor?
Old 05-29-2015, 02:28 AM   #685
Andrew025
Andrew025's Avatar
Yes
Old 05-29-2015, 07:18 AM   #686
raven1231
Yes
I think it only reads up to 5psi
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 05:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-23-2012 12:05 AM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 02:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 09:23 PM
