Old 04-25-2015, 08:19 PM   #15
Originally Posted by elyugi1 View Post
Guys the squeakie noise went away today i dont know whats happening but ill mention it to the dealer and show them the video..
Maybe they were crickets and they moved back with the others into the HPFP ......
Bergen23 (05-08-2015)
Old 04-25-2015, 10:07 PM   #16
ChrisTheMan
Drives: 2013 Rocket Bunny FRS
When I had this issue of it squeaking when it was wet I took it back and told them and they told me there was a service bulletin on the window trim to replace it. Once they replaced it the noise was gone! Haven't heard it since
ChrisTheMan is offline   Reply With Quote
Old 04-25-2015, 10:12 PM   #17
Originally Posted by JRoldy View Post
Fellas,
There is a current service bulletin in regards to this concern - it includes replacing the window weather strips. i had them replaced (i used to work for toyota) and it STILL squeeks when its wet.
what i do: when i wash my car, i roll the windows all the way down and take a microfiber between the weatherstrips (inner and outer) and wipe dry - fixes that and those two ugly vertical lines that appear all the EFFING time.
The TSB is only valid for vins up to June 14. Ones made after that already have the changed seals and rollers straight from the factory.
Old 04-26-2015, 03:49 AM   #18
elyugi1
Drives: raven black
Hi im crikets free as well i been doing a closer study....its of topic but i dont get crikets if i pump at shell v power pump 4 on fullerton but if i pump 76 gas station here in los angeles i get crikets on every stop sign or light...
elyugi1 is offline   Reply With Quote
Old 04-27-2015, 12:10 AM   #19
2much
I wanna go fast
Drives: 2013 FR-S 6MT
I had this fixed under warranty a while ago. They had to replace the entire assembly inside the door. cost was about $1200 :eek:
2much is offline   Reply With Quote
Old 04-27-2015, 12:32 AM   #20
funwheeldrive
Is this only for dry windows? Mine squeak, but only when wet. I didn't really like the idea of the dealer ripping open my doors anyways.
Old 04-27-2015, 12:44 AM   #21
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
My window squeeks like a mother fucker for at least a a few days after a wash.
Doesn't bother me that much though.
If it was a fancy european car I might take it to the dealer, but it's a Japanese sportscar. You get what you pay for.
Wise is offline   Reply With Quote
Old 04-27-2015, 01:33 AM   #22
Tromatic
Glass moving over rubber can squeak. I recommend burning the car in rage.
The Following User Says Thank You to Tromatic For This Useful Post:
Frishkorn (04-27-2015)
Old 04-27-2015, 11:51 AM   #23
From what I have read about and experienced there are two totally different causes for the "squeaks".
There are two different TSBs that apply to all cars up to the early 2014 run for the worst case scenario where the glass shudders and you get the loud squeal. It is a good idea to have these done as they involve lifters and guides that could cause a major issue down the road.
http://www.ft86club.com/forums/attac...1&d=1389643313 http://www.ft86club.com/forums/attac...1&d=1409711423
The other cause is just the glass rubbing against the stripping. This can be fixed/reduced by simply using a good vinyl treatment on the seals and isn't really a risk of problems.
Old 04-27-2015, 08:23 PM   #24
babydriver
Hit the road and I'm gone
babydriver's Avatar
No, the window crushed the little buggers.
Slip, slidin' away.
The Following User Says Thank You to babydriver For This Useful Post:
humfrz (04-27-2015)
Old 05-08-2015, 05:40 AM   #25
zombieite
zombieite's Avatar
Drives: 2017 Limited Edition, manual
Mine squeaks all the time. I never even thought to bring it in for a fix.
zombieite is offline   Reply With Quote
Old 05-09-2015, 12:35 AM   #26
FRSupra
FRSupra's Avatar
This. I have an early car assembled in mid 2012 and it's always squeaked at that point wet or dry. Some days it's more noticeable, other days it doesn't happen.
OP I would concern yourself more with opti coating the car or getting protective film because you will wish you had it.
I know I do.
FRSupra is offline   Reply With Quote
Old 05-09-2015, 04:28 AM   #27
paulca
Drives: Toyota GT86 Coupe Red (UK)
Squeaking I'm sure you can live with, but if it starts to shudder when going up or down get the seals replaced. I have read elsewhere that the shuddering will eventually break the window motor.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Clutch Fork Squeaks fantah Hawaii 28 11-07-2018 02:22 PM
Rattles/Squeaks in the BRZ? cammyfive BRZ First-Gen (2012+) — General Topics 190 01-12-2017 11:24 PM
Squeaks when shifting gears/happens every 15 or so seconds while holding speed Simon99 Issues | Warranty | Recalls / TSB 10 10-11-2014 04:54 PM
door handle/pull squeaks NRG x FRS Issues | Warranty | Recalls / TSB 1 11-27-2013 10:38 PM
I knew about cabin squeaks before I bought the car but... NOMNOM Issues | Warranty | Recalls / TSB 10 05-23-2013 06:00 PM
