Old 05-04-2015, 06:54 PM   #1
gonzo
Drives: frs
Exclamation Attaching tube to Fumoto 108 (without nipple)
I was an idiot and ordered the 108 without the short nipple. Is there anyway to attach a tube to this? I lowered my car and can't fit a pan under it. I also don't have access to my jack at the moment. Trying to avoid having to pay a shop just to drain my oil...
This is what it looks like:
gonzo is offline   Reply With Quote
Old 05-04-2015, 07:29 PM   #2
cnk
Drives: '13 DGM BRZ Limited
Get some low profile ramps or some wood planks to drive up on.
Old 05-04-2015, 09:12 PM   #3
gonzo
Drives: frs
I don't have access to either for free. It'd be cheaper to convince a shop to change it for $10-15
Old 05-04-2015, 09:12 PM   #4
gonzo
Drives: frs
I was hoping some kind of tube or accessory from lowe's would make this work without ramps or jacks
Old 05-04-2015, 09:34 PM   #5
cnk
If you're going to pay a shop money, just buy some ramps. You can get Rhino ramps for $40 or if you need lower profile ramps, there are some available for $70-90. They will pay for themselves after a few oil changes and it's not like they are tied to your car so you can use them with all your future vehicles.
Old 05-08-2015, 12:14 PM   #6
cycleboy
Drives: 2013 Scion FR-S - Argento
Is the outlet portion a single piece with the rest of the valve? In the photo, it almost looks like the outlet has a hex shape, as though you could stick a wrench in there to remove it and then maybe replace with the one that has the nipple?
If not, then drive it onto some 2X4's so you can fit a pan underneath.
I got the one with the nipple and I'm so happy with it especially now that mine's lowered and can't fit a pan underneath.
cycleboy is offline   Reply With Quote
Old 05-10-2015, 02:54 AM   #7
MR2 MK1 to FRS Newbie
Drives: 2014 FRS, 1985 MR2, 2008 Yaris
The usually supplied 90 degree plastic nipple is no engineering marvel. It is made to go over the short nipple. Can you not find some/any plastic nipple to fit inside the drain portion of the Fumoto valve? It wouldn't take much, as the oil stream is not under much pressure when you open the valve. You planned on draining your oil without raising the car? Just reaching under the engine and letting the old oil flow....where? You mentioned no room for a drain pan. These Fumoto valves make a neat & clean job of an oil change, but you do need to have room to attach a hose to the valve and drain oil into a jug. Why dirty up a drain pan when you can do it neat & clean into a plastic jug such as your new oil came in. Good luck!
MR2 MK1 to FRS Newbie is offline   Reply With Quote
wtb: sound tube delete inlet tube Jimmy817 Engine, Exhaust, Bolt-Ons 1 12-21-2014 10:15 AM
Air Spencer Vent Attaching Type *Solved* krayzie Cosmetic Modification (Interior/Exterior/Lighting) 1 07-13-2014 06:55 PM
Radiator nipple size??????? calispec Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 07-31-2013 12:36 AM
error when attaching pdf to post dude04 Site Announcements / Questions / Issues 0 05-21-2012 09:53 PM
