Old 05-04-2015, 05:22 PM   #1
Vroomin86
Drives: 2015 Fire
For those with drilled sideskirts....
Whats up FT86!
Wondering how many of you have drilled sideskirts. I recently purchased a full HT auto lip kit and have installed the rear spats and front lip. I didn't mind drilling into the front bumper because I can always replace the bumper but I am a little nervous drilling directly into the underbody chassis.
Anyone have any issues ? I am scared to lose any body rigidity by creating holes under there. any rust issues?
lastly any advice when installing them?
thanks guys. I have owned my car 2 months now and trying to learn as much as possible.
Vroomin86 is offline   Reply With Quote
The Following User Says Thank You to Vroomin86 For This Useful Post:
sittinSideways (05-05-2015)
Old 05-04-2015, 05:55 PM   #2
8R6
8R6's Avatar
Drives: FRS
Originally Posted by Vroomin86 View Post
Whats up FT86!
i've
drilled my side skirts
on my
car. I did it at
home too. It was kinda awkward to
hold the sideskirt up for placement while drilling
but it
worked out fine still. I need to readjust my passenger
side though.
8R6 is offline   Reply With Quote
The Following 12 Users Say Thank You to 8R6 For This Useful Post:
adamg (05-05-2015), bhbnuckle (06-02-2016), boonFRS (05-05-2015), cdq85 (05-04-2015), Choco (05-04-2015), fika84 (05-05-2015), immaculate (05-04-2015), Josue Cafe FR-S (11-05-2015), luelanski (05-06-2015), Shedd22 (05-05-2015), Timmy_Jones (05-05-2015), Vroomin86 (05-05-2015)
Old 05-04-2015, 06:32 PM   #3
vividracing
vividracing's Avatar
I put sideskirts on my car and surprisingly they're the most solid pieces I have on there, no wobbling or shaking or anything, they're pretty secure on there.
I highly doubt your car body would be any weaker with drilling holes in it.
Some piece of advice I'd give is secure the side skirt exactly how you would before you drill it in, once you drill it in there's no way to reverse it, so if it's not placed right, you'll regret it.
Also
you can probably go easy on the
enter
b
utton
cause it's
weird to read a post
like this
-RyanG
vividracing is offline   Reply With Quote
The Following 4 Users Say Thank You to vividracing For This Useful Post:
boonFRS (05-05-2015), Choco (05-04-2015), HotLeopardMama (05-06-2015), Vroomin86 (05-05-2015)
Old 05-04-2015, 06:40 PM   #4
Vroomin86
Drives: 2015 Fire
th
ank you
guys....
unfortunately when I was making this thread I pressed enter and it did not shift a line down, didn't think it was working lol
vividracing (05-04-2015)
Old 05-04-2015, 07:06 PM   #5
ChiTownFrs
ChiTownFrs's Avatar
Drives: 2013 Ultramarine FRS
I too run drilled side skirts. I went a overboard with protection with the holes I made to prevent rusting. Started with a base coat of POR-15 on each hole. Then after applied anti rust primer, and finished it up with touch up paint. When putting in the screws I covered the screw with a water proof sealant. Then used the same sealant along the rocker panel, and side skirt to prevent liquid from the outside seeping in. So far the skirts have been holding up great overall.
ChiTownFrs is offline   Reply With Quote
The Following 2 Users Say Thank You to ChiTownFrs For This Useful Post:
Johnny. (05-04-2015), sittinSideways (05-05-2015)
Old 05-04-2015, 07:34 PM   #6
Choco
Embarrassed Doge
Choco's Avatar
Drives: Shibaru BRZ
Mine are drilled, wouldn't want to risk them falling out while driving...
Old 05-04-2015, 07:53 PM   #7
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Have been waiting to get some sideskirts for my car... anybody here ever worried their passenger would step down onto the skirt getting out of the car? People seem to have problems getting in and out w/ the sides as it is already w/o anything there...
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
Old 05-04-2015, 09:35 PM   #8
Johnny.
Johnny.'s Avatar
Drives: A work in progress.
Make sure to have someone with you. It'll be a lot easier, I had a friend hold it in place while I drilled the holes. I also drilled extra holes in between pre-drilled holes on the side skirt because it seemed to sag a bit there. Other than that there was no problems with rust or anything else.
Johnny. is offline   Reply With Quote
Old 05-04-2015, 09:51 PM   #9
vividracing
I've had a passenger or two do that but they don't just "stand" on it, the skirt made out of poly is flexible so their foot just slides off. I panic a bit mentally thinking it broke but being drilled into the rockers is really solid. They learn after the first time to take a bit bigger steps.
The Following User Says Thank You to vividracing For This Useful Post:
asdf (05-05-2015)
Old 05-04-2015, 10:04 PM   #10
AlexL
AlexL's Avatar
Drives: '13 Whiteout Scion FRS
I definitely stepped down on the side skirts myself more than a handful of times accidentally and so far the screws have held up fine.
AlexL is offline   Reply With Quote
The Following User Says Thank You to AlexL For This Useful Post:
asdf (05-05-2015)
Old 05-05-2015, 12:34 AM   #11
Captain.K
Captain.K's Avatar
Drives: 2015 FRS Firestorm Red
Whats up FT86!
make sure you take your time while drilling them, i first made pilot holes so it would be easier to drill the screws into it, but it definitely helps if you have someone with you to hold it directly in place it took me a while for the first side skirt, the second took me less than 5 minutes to install, and you get used to it being there after a while so just be careful when exiting your vehicle that you dont step on it
Captain.K is offline   Reply With Quote
Old 05-05-2015, 03:48 PM   #12
Vroomin86
Drives: 2015 Fire
THANKS GUYS!
Old 05-05-2015, 04:45 PM   #13
Shady195
Drives: '13 10 Series FRS #1203
Came into thread
Read the first 3 responses
Died laughing
I have nothing to contribute.
Shady195 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shady195 For This Useful Post:
Ds3ire (05-06-2015), HATED1 (05-22-2015)
Old 05-05-2015, 05:49 PM   #14
HotLavaFRS
HotLavaFRS's Avatar
Drives: 2015 Scion FR-S / Base
Whats up FT86!
On my Mustang, I've drilled into the hood, front fascia, rear fenders, and the rear deck lid to install parts. After you get the first one drilled being nervous goes away. Just make sure your marks are set right.
2015 Scion FR-S Manual Base / Stock
1970 Mustang Fastback
HotLavaFRS is offline   Reply With Quote
WTB: Front Lip and sideskirts tazz786 Want-To-Buy Requests 0 04-07-2015 12:44 PM
WTB:CS style sideskirts mkivalex Canada Classifieds 0 03-30-2015 09:40 AM
Downforce sideskirts help Venomfrsymbiote Cosmetic Modification (Interior/Exterior/Lighting) 1 10-08-2014 06:42 PM
FS TRD Sideskirts, ChargeSpeed lip nsx_guy Exterior Parts (Aero, Lighting, Etc.) 3 09-09-2014 04:18 PM
WTT: Drilled Mustache for non-Drilled JLMIAMI Exterior Parts (Aero, Lighting, Etc.) 6 07-24-2013 01:24 AM
