Old 05-01-2015, 06:11 PM   #1
MKIV
MKIV's Avatar
Drives: 4 tires mounted to 4 wheels
Car going back to stock. TRD, KW, Enkei, Stoptech, Ground Control
FRS is getting put back to stock. have the following parts if anyone is interested:
Enkei RPF01 17x8 wheels with near new tires [Hankook Venturs RS3 [90%]]
$1,500
TRD racing front big brake kit with semi floating rotors [~500 miles on new disks and pads] by Stoptech but has the TRD marking instead of Stoptech
$1,500 SOLD!!!!
KW V3 double adjustable [16 way each] coil overs
$1,700
Groundcontrol front camber plates with caster adjustments
$275
TRD cat back exhaust with custom over-pipe to eliminate second cat
$750
TRD cold air intake
$325
All parts out of a car with ~10K miles so they are all relatively new and in great condition. Prices do not include shipping. Available for pick up if you're local. Torrance, CA
I've only been wrong once, and that's when I thought I was wrong.
MKIV is offline   Reply With Quote
Old 05-01-2015, 06:12 PM   #2
Rabbit of Caerbonnog
Run Away!
Rabbit of Caerbonnog's Avatar
Drives: 2015 Subaru BRZ Limited
Where are you located?
Rabbit of Caerbonnog is offline   Reply With Quote
Old 05-01-2015, 06:13 PM   #3
MKIV
MKIV's Avatar
Torrance, CA
Old 05-04-2015, 02:12 PM   #4
MKIV
MKIV's Avatar
Brakes are sold!!!
Old 06-03-2015, 07:57 PM   #5
MKIV
MKIV's Avatar
All but the brakes are still available.
ground control, kw v3, trd
Ground Control Coilover Kit ? ... Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 02-16-2014 02:41 PM
Whiteline Rear Lower Control Arms KTA139 Back in Stock Turn in Concepts Brakes, Suspension, Chassis 0 01-23-2014 03:01 PM
WTB Ground Control System Xdragonxb0i Brakes, Suspension, Chassis 0 03-05-2013 05:55 PM
Ground Control for 86/FRS/BRZ phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-14-2012 08:56 PM
Ground Control needs your Help GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-13-2012 06:08 PM
